Faux Nixie Tube Clock
32,416
213
41
About: I am an incoming freshman at ASU studying robotics. I love to make things and perform music. I am always working on several projects at a given time.
I love retro tech. It's so much fun to play with older tech since they are usually larger and more aesthetic than modern equivalents. The only problem with old tech such as Nixie tubes is that they are rare, expensive, and generally difficult to work with. Since the library near me just got a laser cutter for the public to use, I knew I had to make a project to learn how to use it. What better thing to do than combine my passion for old tech with lasers. These LED "Nixie" tubes are much cheaper, less dangerous, and can be powered off of USB power.
The template I used for my PCB was provided by Connor Nishijima on github (https://github.com/connornishijima/lixie-arduino)
My original inspiration for this was the version that Make did (https://makezine.com/projects/led-nixie-display/), but Connor's PCB was much cheaper to produce as the PCB's are smaller.
Supplies:
Step 1: Materials and Tools
Materials:
Electronics:
  • Arduino Nano
  • 10K Resistor
  • Pushbutton
  • Toggle Switch
  • WS2812B LED's
  • Misc Wire
  • Mini USB cable
  • USB-B extender (commonly used for 3D Printers)
  • Coin Cell Battery
  • DS3231 RTC module
Other:
  • 3mm Plywood
  • 1/16" Acrylic
  • M3 Screws and Nuts
Tools:
  • Laser Cutter
  • Sandpaper (220 Grit)
  • Mouse Sander
  • Allen Keys
  • Utility Knife
  • Super Glue
  • Solder Reflow Oven (A toaster oven will also work)
  • Wire Cutters
  • Soldering Iron
  • 60/40 Lead solder
  • Syringe and Tips
  • Solder Paste
  • Hot Glue and Glue Dun
Step 2: Laser Cutting
Using the SVG files (or Fusion360 file) that I have provided, cut out the pieces of the frame.
The pieces that have text on them have a separate svg file that includes the text in it. These pieces are 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, Back, Bottom, Top.
You will need:
  • 4 x 0 (acrylic)
  • 4 x 1 (acrylic)
  • 4 x 2 (acrylic)
  • 4 x 3 (acrylic)
  • 4 x 4 (acrylic)
  • 4 x 5 (acrylic)
  • 4 x 6 (acrylic)
  • 4 x 7 (acrylic)
  • 4 x 8 (acrylic)
  • 4 x 9 (acrylic)
  • 1 x Back (wood)
  • 1 x Bottom (wood)
  • 3 x Button (wood)
  • 4 x Feet1 (wood)
  • 4 x Feet2 (wood)
  • 1 x Front (wood)
  • 2 x Side (wood)
  • 4 x Slot (wood)
  • 1 x Spacer (wood)
  • 2 x Top Cover (wood)
  • 2 x Top Slot (wood)
  • 1 x Top (wood)
In making this I used the Glowforge at my local makerspace, but any laser cutter will work (Duh!). If you are using a Glowforge these are the settings that worked for me. With the wood I used 250 speed, 100 power, and 2 passes (for the more delicate pieces you might want to use less power and slower). For cutting the acrylic I used 200 speed, 100 power, and 1 pass. For engraving the wood I used 250 speed, 10 power, and 1 pass. For engraving the acrylic I used 500 speed, 50 power, and 1 pass. I recommend messing with settings and find what works best for you before cutting out all of the pieces.
Don't peel the protective layer off the acrylic, leave it on until a later step.
Step 3: Making the Digits
Order or make the PCB's for the digits using the gerber or Eagle files I have provided. I used the PCB files developed by Connor Nishijima as a base, the only edits I made were to add the 5v line in (since the original files dint have a 5V line for some reason) and change the silkscreen a bit. Using either a syringe filled with solder paste (the method I chose) or a stencil and a spreader tool, apply solder paste to the pads on the PCB's. When applying the solder paste a little bit goes a long way, you only need just enough to coat the pads. You'll need to make four of these, and it might be a good idea to make an extra to test on or in case one of them breaks. Carefully place the WS2812B LED's on the pads, being careful to note the orientation of the LED's. They don't have to be perfect since when they are cooking the surface tension of the solder will straighten them out. It is very difficult to remove an LED if it is put on wrong (I did this on my first board and spent close to a half hour trying to fix it without ruining anything. After placing all the LED's on the board, put them in the reflow oven, or in my case a toaster oven and then turn it on AFTER placing the boards in. Keep a close eye on the oven when it cooking, you don't want to exceed 220 degrees Celsius or you'll start to damage the boards. The solder should start to melt around 200 degrees Celsius. Once the solder joints have melted, turn off the oven and wait for it to cool off. Don't try to remove the boards until the have cooled, if you don't the LED's will move and the board will be ruined. After they are complete I recommend plugging them into an arduino and using one of the NeoPixel example codes to verify that the boards indeed work.
Step 4: Programming the Arduino
Plug the arduino Nano into your computer and open up the Arduino environment. Open the sketch and upload the code, making sure that you have selected the right board and COM port. If you ever need to update the clock's firmware you can do it through the USB extension cable and not disassemble it.
To make sure you are using the most up to date code check my Github here: https://github.com/ZGoode/Faux-Nixie-Clock
Step 5: Electronics
Connect all of the wires to the Arduino Nano as shown in the Fritzing diagram. Double check all wiring before plugging in to power. Fixing a burnt Nixie display is very difficult and annoying to have to deal with.
When mounting the toggle switches you will need to sand off about a millimeter from the top side (the side that is facing the PCB's making up the Nixies). This is to make them fit properly without interfering with the PCB.
You will also need to splice together the USB-B cable and the Mini-B cable. This serves two purposes, one to power the clock, and two to give you USB access so as to reprogram or update it without disassembling.
DS3231 Pinout
  • SCL - A5
  • SDA - A4
Lixie Pinout
  • DIN - 7
Buttons
  • Hour - 9
  • Minute - 8
  • Color - 10
Switches
  • Daylight Savings - 11
  • Time Set - 12
  • 24 Hour - 13
Step 6: Final Assembly
After all of the electronics are tested and working and the wires have been cleaned up, prepare to close up the box. Tape down or glue the Arduino and RTC so that they don't end up touching one of the bolts or other wires. Make sure that everything that should be plugged in is plugged in. Super Glue the box shut, putting the bottom piece on last. After closing the box insert the feet pieces into their slots on the bottom.
At this point you need to take careful precautions to keep the acrylic clean. Before peeling off the protective plastic I recommend using rubber gloves to keep your skin oils from getting on the digits. Peel off the plastic protection and insert the numbers in the slots in this order (from front to back): 3, 8, 9, 4, 0, 5, 7, 2, 6, 1. After the digits are in place put the top slot piece onto each side to keep the acrylic number aligned and then super glue the top piece on to finish the clock. At this point you are done with assembly and ready to start setting up the clock for use.
Step 7: How to Use It
  • To set the time: Toggle the set switch to on (making sure the DST or Daylight Savings Time is set correctly) and press the hour and minute buttons to change the time. After the time is set toggle the set switch to off and it should function correctly.
  • To change the color/pattern used in the digits: Press the button labeled color
  • To turn on or off Daylight Savings Mode: Toggled the switch in the back labeled DST
  • To change to 24 hour mode: Toggle the switch on the back labeled 24HR
Because of the RTC used, you should only have to set the time when either the battery dies or when plugging it in for the first time.
Faux-Real Contest
Second Prize in the
Faux-Real Contest
    • Classroom Science Contest
    • Arduino Contest 2019
    • Gardening Contest
      Gardening Contest
    41 Discussions
    pzucarelli
    2 months ago
    Zachary,
    Great project and well done.
    I'm definitely filing this away as a project to build when I get some free time. One thing I can't seen to find is the overall wiring diagram. You referred to it as a Fritzing diagram in step 5. The list of connections in step 5 probably gives me enough info to recreate this, but I was wondering were the three 10K resistors went. I'm assuming that the switches ground the designated UNO pins when actuated. Probably can figure that out from the code anyway.
    Phil
    Sanadospzucarelli
    Reply 2 months ago
    Was about to say... pol-filter on the camera could have removed the reflections.
    But even the glimmer makes it more interesting!
    Awesome project!
    Zachary Goodepzucarelli
    Best Answer 2 months ago
    I forgot to upload the diagram that I made. I'll get that taken care of
    You are right that the pins connect to ground when not high. Due to how the frame was designed I don't think an uno will be small enough to fit inside btw. I just uploaded a fritzing diagram both here and in step 5. If you have any more questions just ask.
    CraftAndu
    2 months ago
    Looks awesome!
    fstedie
    2 months ago
    A lot of work went into this, I don't deny that. But am I the only one that thinks this doesn't look very good? Maybe it is the lighting? All the engraved letters light up enough to be distracting and it all ends up looking like a jumbled mess. If there was a way to keep the non-active digits completely dark, maybe it would look better...
    Zachary Goodefstedie
    Reply 2 months ago
    That's just how it looks on camera. In real life while that effect is still there it is much less noticeable. I could probably minimize it by tuning the laser settings even more. This is one of those things that is just difficult to photograph properly.
    In addition, the parts where the numbers are engraved aren't clear. So even if they are turned off with no light you will be able to see the engravings
    jcushard
    2 months ago on Step 7
    Well it is much prettier than the real nixie tube clock built in my electronics class in 1964 it too used micro electronics, flip flops divided the 60 hertz line down into seconds then minutes then hours then AM/PM then reset to do it all again then there were the driver circuits the high voltage supply ... little larger than a shoe box, it was a tech wonder of it's day .... over heating was over come with a very loud fan setting the time not user friendly but it worked, we were emulating the engineers that took man into space ... our class bore out 6 engineers several teachers and young men who could thing through problems in design and function ... you did well, your work has an artistic appeal I envy your tools what might my old group have done with such? good luck to you dream, design and build and never stop.
    alcurb
    2 months ago
    Nice Nixie work-alike concept, but if you know Nixies, you know that they are nearly never any color than red-orange. I would have liked to have seen a pic of it, glowing orange, and be momentarily confused about whether it's a true-nixie or not. To me, that moment of confusion is what I would call an effective Faux. That said, your project is wonderfully designed and constructed and it shows you spent much effort and dedication to it.
    Zachary Goodealcurb
    Reply 2 months ago
    Here is a picture I just took of the Nixie's glowing orange.
    esilkyalcurb
    Reply 2 months ago
    I totally agree. I have two 'actual' Nixie clocks in my house that I have built. With as much effort as you put into this, you should at least have an option to switch the color to 'glowing orange'. I'm fine if you also want blue/purple (to be different/modern) - but you really need 'glowing orange'.
    Other than that - excellent work!
    I wish I had easy access to a laser cutter - I would probably build one to add to one more room in my house (in addition to the two 'real' Nixies.
    Also, one question?...
    When the digits change, does one fade out while the other fades in? You had photos, but without a video I can't tell. That is another distinguishing thing of the Nixie tubes - they aren't instantaneous. So when the time changes, you can detect that one digit is 'fading out' while the other digit is 'coming on'.
    Zachary Goodealcurb
    Reply 2 months ago
    I can very easily upload a picture of them orange when I get home today. Since I used RGB LEDs for this I just need to make a change in code to do that. I only chose the blue-purple that i did because because it showed up well on camera.
    VincentV81
    2 months ago
    Nice ! Good job, have you any video on the web, this should confirm your nice project.
    Thanks.
    Zachary GoodeVincentV81
    Reply 2 months ago
    I just uploaded a video showing a timelapse of a few minutes
    pbbaker
    2 months ago
    Really nice project. I made a clock a while back and used an atomic clock module and some helpful code I found in an Arduino forum. The clock would set itself based on the atomic clock signal. Might be a nice improvement for this very cool nixie clock.
    Zachary Goodepbbaker
    Reply 2 months ago
    That actually sounds pretty cool. If I ever decide to make and sell these on Etsy or something I will definetely try and make that change to it.
    DrewL31
    2 months ago
    Super cool idea!
