Felt Bear
2,626
58
9
There are a person good at sewing and a weak person.
I thought if anyone could let a thread go through equally that I was glad, and made it with a laser cutting machine.
Supplies:
Step 1: Create the Data
The point of the data making...
1.
When I process felt, limit width occurs around 1.5mm(In the case of felt of 2mm).
So, it is necessary to offset a pass 0.75mm beforehand.
2.
I make a dashed line from the pass which offset in the 0.5mm inside.
Step 2: Cut the Felt
Process ​​by using a laser cutting machine.
The felt to process with a laser cutting machine has good thing of 100% of polyester.
Step 3: Sew
I was able to sew straight it with equal distance when I put a thread in conformity to the hole which a machine opened.
Step 4: Sew It a Lot, Heh-heh
Step 5: Completion
    • Classroom Science Contest
    • Arduino Contest 2019
    9 Discussions
    Thank you!
    Wish thought so that even the person who was weak in sewing could sew it neatly.
    If it is this method, any development is possible.
