Fidget Centrifuge
6,631
67
18
About: Analog maker dabbling in digital manufacture
Fidget spinners were a thing. There are now a bazillion lying abandoned, ready for re-purposing into a functional version of their former selves. Have someone who needs distracting, AND a small amount of liquid from which you need a fine suspended solid removed from? Do I have the project for you! Presenting: the fidget centrifuge. Featuring a bearing and a 3D printed enclosure for 10 mini centrifuge tubes, and powered by incessant fidgeting, it will keep an energetic and scientifically-minded person occupied for hours, while usefully reducing the entropy of not more than five milliliters of a system of interest.
Supplies:
Step 1: Tools and Materials
You will need either an old fidget spinner, or some bearings. The bearings out of my fidget spinner were exactly 22 mm in diameter and 7 mm deep, and I believe these 608ZZ bearings are standard. They're not glued in, just apply pressure and pop them out. They can also be purchased directly, if you want a bunch for a class or something.
You will need access to a 3D printer. The best one I've used for reliability & ease of use is Dremel's Idea Builder.
Micro-centrifuge tubes are inexpensive - a cent or two each when bought in bulk.
Step 2: Design
I took a photo of the microcentrifuge tube and uploaded it to Fusion360 (Insert > Attached Canvas). I sketched the outline, scaled it to the correct size based on a single dimension, and then rotated that profile. That got me the shape I needed for the holder. I then sketched a couple of circles (inner 22 mm, outer 90 mm) and made the inside of the spinner 7 mm (to match the bearing) and tapered it to 3 mm at the edge. I moved and angled the tube shape to a position that looked about right, then used the Modify > Pattern > Circle tool to repeat it 10 times around the central axis. The Modify > Combine > Cut tool punched those shapes out. I did some more similar work to create the cog-like outer pattern and to punch out some volume to make the print faster. Some filleting to make the sharp edges rounded finished the design. The animation shows how it went down.
I also designed caps for the fidget centrifuge to make it easier to hold. These files are included in the next step.
Step 3: 3D Print
3D printing of the STL files (attached to this step) does not require supports. Print in whatever material and color you like. It took 2.5 hours to print all three parts on a MakerBot Replicator using default settings.
Step 4: Assemble
The three 3D printed parts assemble around the bearing as shown. Glue (I used E6000) together for longevity. Note how the centrifuge tubes are loaded - the overhang used to pry the lid off tucks into the decagonal slot near the bearing (i.e. the hinge points upwards). This precaution keeps the tubes secure when the centrifuge is spinning.
The taller of the caps is for the top - it is designed to give the user enough room to avoid the tops of the tubes while spinning. The shorter cap is for the bottom - it is just high enough to give the tubes clearance when spinning the centrifuge on a surface.
Step 5: Power Up
Put the suspensions that need separating in the centrifuge tubes, and get spinning! But don't expect too much - at a radius of 3 cm and spinning at a rate of 120 rpm (2 revolutions per second), you'll get a calculated force of about 0.5 g. But you can ask users of the fidget centrifuge though-provoking questions... how do centrifuges make the solid settle faster? What applications might a centrifuge have? In biology? Chemistry? Physics? Water treatment? Space travel? Would it work on molecules? Bugs? Gases? How many tubes can you load in and ensure the centrifuge is balanced, and why might that be important? (2, 4, 5, 6, 8 and 10 for this centrifuge - watch Dr Holly Krieger explain the math, it's a treat).
Best of all, these gadgets look interesting, can be printed cheaply, assembled by the recipients, and taken home afterwards for further experimentation. Nothing is more educationally memorable than a toy whose scientific function the owner gets to explain and demonstrate to their family.
Hat tips to Jon-a-tron, whose fidget zoetrope was influential, and to my friend Becky who helped fully bake a half-baked idea. And to Matlek, who has published a fidget spinner centrifuge that I found out about only after publishing this one!
Toys Contest
Runner Up in the
Toys Contest
    • Arduino Contest 2019
    • Gardening Contest
      Gardening Contest
    18 Discussions
    3DNicholos
    4 months ago
    This is really neat! I do have a request - our tubes are a bit larger in diameter and taller than what these are made for. Can you share the Fusion 360 file for me to modify for our purposes? We are planning to use this in our science museum for demonstrations, specifically when we extract DNA from strawberries. Thanks!
    makendo3DNicholos
    Reply 4 months ago
    Whoa! That would be really cool. Yes, absolutely - here is the public link: https://a360.co/2TrzqQD
    Let me know if you have any questions, would be happy to help.
    MphatsoS1
    5 months ago
    This is awesome! thank you for sharing
    Leo1965
    5 months ago
    Cool project and impressive how the Stanford guys are applying it! They could also recycle old cd's and dvd's to make it.
    Matlek
    5 months ago
    Great to see another one! Do you use it at work, or is it just for fun as a proof of concept?
    With the one I made, people with small hands cannot spin the fidget because its radius is a bit large due to the tubes. Did you face the same problem?
    makendoMatlek
    Reply 5 months ago
    Thanks! I don't, but a friend plans to. This one is usable by people with small hands (the photos and videos feature someone such). But these are 0.5 ml tubes, not 1 ml, so I imagine the larger tube size would be more problematic.
    makendomasterbuilder
    Answer 5 months ago
    Unfortunately not; the plastic is not resistant to UF6
    wilsonjc
    5 months ago
    You could add fins to this build and drive it with a compresses air. you could make it spin much faster and longer with compresses air.
    DennisT33wilsonjc
    Reply 5 months ago
    There is a commercial device that does this, called the AirFuge. The rotor is about the size of a walnut and the tube hold 0.4 ml. It reaches tremendous speeds (60k RPM as I recall) and the decompressing air keeps the whole thing cool).
    makendowilsonjc
    Reply 5 months ago
    true, and a source of compressed air would probably be a delight to your typical fidgeter
    Johenix
    5 months ago
    With 12 positions you could balance 2, 3, 4, 6, 8, 9, or 12 tubes.
    You might want to have a spinning lid on this centrifuge.
    makendoJohenix
    Reply 5 months ago
    In fact only 1 and 11 don't work for a 12 tube centrifuge. 5 and 7 are hard to see until you realise that because 2 and 3 are both balanced, you can overlap them. So thinking about it as a clock face: filling positions 3 and 9 o'clock only is balanced. Filling 12, 4 and 8 o'clock are also balanced. So filling 12, 3, 4, 8 and 9 o'clock is also balanced. 7 tubes is just the opposite, i.e. fill 1, 2, 5, 6, 7, 10, 11.
    The tubes actually stay put pretty well, but a lid wouldn't hurt.
    DennisT33
    5 months ago
    Brilliant! I'd have used this every day when I was in the lab!
    This reminds me of the 'card spinner' that is used to spin hematocrit capillaries. This is a disk of cardboard with holes punched to hold thin blood capillaries. It's powered by a loop of twine through the center, by intermittently pulling the loop apart, the disk spins left then right. Your device could similarly be powered by looping through the middle (without the bearing).
    It also reminds me of the old swinging bucket hand-crank centrifuges that clamped to a bench and swung dangerously close to one's head. If I recall correctly, we called that one the Bonkulator for that potential. Definitely not OSHA approved!
    If your 'fuge spun at a high speed it would be safer if the circumference was filled in so that it wouldn't catch a finger. Always balance your tubes weight wise!
    Thanks for sharing!
    makendoDennisT33
    Reply 5 months ago
    that is really cool. I am sorely tempted to make just such a thing! Thanks for the great tip
