FindyBot3000 - a Voice Controlled Organizer
43,190
631
116
About: Software engineer and long time hacker, but new to Instructables! Started tinkering with Arduino in highschool building cool little robots.
As any maker can attest, over the years, one collects a lot of parts. Perhaps it all started with a few resistors and LEDs, a breadboard, and an Arduino. But soon there were motors and motor drivers, IR rangefinders and tactile switches. Accelerometers, microphones, heatshrink tubes, potentiometers, relays, hookup wire, all those things salvaged from that printer you took apart... and the list goes on.
Now, organizing such a collection of goodies is no easy task. Some may have turned to baggies, for others, boxes. And then there were those who filled shelves with boxes, filled with baggies, filled with parts. All intricately labelled, yet still so cumbersome to manage.
This Instructable takes a stab at solving the age-old problem of organizing a bunch of things. So without further ado, FindyBot3000.
Step 1: The Problem
'nuff said.
Step 2: Table of Contents
This project is an Internet-of-Things organizer, designed for hands-free searching and intuitive voice-controlled management of parts.
This Instructable is organized as follows:
Overview - Describing how the tech is all linked
Prerequisites - Required Tools, Software, Electronics, and Parts Lists
Construction
  • Mechanical - Building the organizer
  • Electrical - Wiring it all up
Basic Testing
Software
  • Download and setup necessary accounts
  • Voice-Control - Linking Google Home to Particle Photon
  • The Cloud - Deploying an Azure Function and SQL Database on Microsoft Azure
Future Plans - New features, animations, debugging techniques, etc.
Step 3: Overview
A broad tech stack is used, ranging from lower-level C++ programming (Arduino-style!) to higher-level C# programming for the (Microsoft) Cloud!
Technologies and Languages
While many makers will be familiar with Google Home/Google Assistant, the other technologies may be unknown. Here's a quick summary:
Human - That's you!
Google Home- This is what you talk to, and turns voice into text. Behind the scenes, Google Home uses Google Assistant, which is really doing all the work. This project can actually work with any device that supports Google Assistant, like an Android phone or tablet.
IFTTT - If-this-then-that, a free online service which allows different apps to communicate. In this project, IFTTT is used to connect Google Home with Particle Photon.
Particle Photon - A cheap WiFi capable microcontroller, programmable Arduino-style! This chip drives the LED display on the organizer. Development with this microcontroller has us working with:
  • C++ (Arduino style)
  • Webhooks - Send/receive real-time data between applications (like Particle Photon to an Azure Function)
  • Particle Dev - The integrated development environment (IDE) which is used to code for the Photon.
Azure Function- A piece of code that runs in the cloud. No virtual machines or web apps to worry about. This does all the heavy lifting in terms of processing text, building SQL queries, and any other work that would be much more difficult or (computationally) expensive to do on a microcontroller like the Photon.
SQL Database - Keeps track of all the parts: names, quantities, locations, search tags, dates, etc. The database is queried to insert, remove, find, or update parts.
In the next step, a sequence diagram shows how all these pieces fit together.
Step 4: The Ebb and Flow
In the UML sequence diagram shown, the flow of each component is laid out. There's a ton of technology behind it all, so it's pretty incredible that FindyBot3000 can find parts within a second. This Instructable won't go into the nitty-gritty technical details of how each step is implemented. Instead, we will focus on building the physical assembly, deploying the necessary software components, and configuring everything to work together.
Now this is a pretty complicated drawing, showing how all the software components talk to each other, and in which order. Follow the arrows, noting which lifelines (vertical lines) they are pointing to, to get a sense of what is happening and when.
You may be wondering -- why don't we send the data from Google Home directly to the Azure Function, instead of first to the Photon? The reason is to provide a single source of debugging information. By logging all commands which are incoming and outgoing from the Photon, we can easily identify at which step in the sequence data loss or a bug may have occurred.
We will come back to this diagram in later steps, but for now, on to construction!
Step 5: Parts Lists
Tools:
  • Jigsaw w/ fine wood blade
  • Drill with 1/16th bit, 1/4" bit, and countersink bit
  • Screwdriver
  • Dremel w/ mutipurpose cutting bit
  • Soldering Iron
  • Solder
  • Scissors
  • Retractable utility knife
  • Duct tape
  • Double-sided foam tape
  • Clamps
  • Super glue
  • Sand paper
  • Measuring tape
  • Carpenter/rafter/combination square
Hardware:
ItemQuantityCostTotal CostNotes
8'x7"x3/4" pine board3$8.00$24Hardware Store
AcroMils 64-compartment organizer2$28.65$57.30
AcroMils 24-compartment organizer2$34.95$69.90
1-3/4" Wood screws18$0.10$1.80Hardware Store
3/4" Pan-head sheet metal screws8$0.10$0.80Hardware Store
Square foam exercise pads1$20.99$20.990.5", grey
2'x2' 1/4" plywood1$15$15Hardware Store
Total Cost:$189.79
Electronics:
LED strip7$15.76$110.325V, 2 meter, 60 pixels/meter, 4mm wide, black PCB
Heatshrink tubing1$6.99$6.99An assortment of tubes will last you a while
Servo extention cable, 10cm7$7.99$7.99Pack of 10. Only 7 needed.
16ft 2-wire cable1$8.77$8.77Check hardware store for by-the-foot pricing
Particle Photon1$19$19The microcontroller. Can be bought on Amazon here.
Half-size breadboard1$7.99$7.99Because I didn't want to design a PCB
Jumper wires1$5.99$5.99Hook everything up
25A Solid state relay1$13.99$13.99Turn on/off the power supply to the LEDs. 5V input. Prices fluctuate.
14 Gauge Hookup wire3$0.25$0.75Your local hardware store will sell this by the foot
5V 60A Power supply1$27.77$27.77Powers all 840 RGB LEDs
5V 2A Power supply1$4.77$4.77Powers the Particle Photon
Power cord1$10$10Price fluctuates a lot, any grounded 3-wire cord will do
3.3V - 5V Logic level converter1$2.95$2.95Particle Photon (3.3V) > Converter > LED strip (5V)
Total:$227.28
Accounts needed: You'll need to create an account with each of these services
Software:
  • (Necessary)Particle Dev - Write Arduino-style code to run on the Particle Photon
  • (Optional) Visual studio, community edition - Modify the Azure Function and manually manipulate the SQL database
    • Extensions: Azure Development, .NET desktop development, Desktop development with C++, Data storage and processing
  • (Optional) Postman - For unit testing. Sends HTTP Post requests to the Azure Function.
Step 6: Construction - Design Files and Animation
The short animation demonstrates how FindyBot3000 was assembled.
Fusion 360 was used to design the CAD model, animation, and drawings for FindyBot3000.
By the way, you can use Fusion 360 for FREE as a hobbyist, like I am doing for this project!
I couldn't find an easy way to upload the parts, so the table below provides links to them in the Fusion 360 cloud:
ImagePart
Assembly
Foam Pad
Vertical Board
Horizontal Board
Middle Board
Lower Cabinet
Upper Cabinet
Drawings:
Horizontal board drawing
Vertical board drawing
Middle board drawing
Foam pad drawing
Step 7: Construction - Foam Pads
FindyBot3000 bundles the four individual organizer boxes in a slim wooden frame, sandwiched between slices of foam pad. The foam pads offer an aesthetically pleasing way of concealing all the wiring for the LED strips, as you'll see in later steps.
The first order of business is cutting the foam pads to size, from which the board dimensions are measured. Just lay the foam on a markable surface, then the board on top of the foam, and use a utility knife to cut the foam to the width of the board. With the foam cut out, measure the height needed by propping it up against the organizer box. Use a carpenter square or end of a board to make a square cut.
Great, first step done!
Step 8: Construction - Cutting the Boards
Cut the bottom, middle and top boards to length. Layering the cabinets as shown in the first picture produces the results. Stack the horizontal boards and the cabinets to find the total height of the assembly, and use that to mark the length the vertical boards need to be.
Alternatively, you can use the technical drawings. I've put images of them in this step for convenience.
Step 9: Construction - Frame Assembly
Begin by assembling the horizontal boards with the right vertical board. Remember to drill pilot and countersink holes to relieve strain on the end of the boards.
Step 10: Construction - Prepare the Cabinets
The horizontal supports for all the containers in the cabinet are recessed about a half inch behind the bezel. To route the LED strips along these horizontal supports, a drill is used to make holes in the bezel to thread the LED strips through. I used sandpaper and a dremel to tidy up the holes.
Step 11: Construction - Install the LED Strips
1. Take each of the 7 2-meter long LED strips, and find the middle. The contact terminals in the middle will have solder on them, making them different from all the rest. (There is solder on the terminals every 50cm on these LED strips). Use a pair of scissors to cut the solder pads in half. Do this for all LED strips, leaving you with 14 1-meter long lengths. Leave the paper backing on for now.
2. Critical Step: Find a LED strip length with a male-end connector, as shown. Note: the direction of the little arrows on the LED strip should point away from the connector.
3. From the top-left of the four-cabinet assembly, feed the led strips in as shown. This will produce a zig-zag pattern when connecting all the LEDs. Note: starting from the top, for every odd row the arrows should point to the right. For every even row, the arrows should point to the left.
Step 12: Quick Testing
Before we finish up the assembly, it's a good idea to make sure all the wiring is correct and the LEDs are working.
1. Setup the circuit as shown in the Fritzing diagram.
2. Open up Particle Dev, or use the Particle Web IDE, to upload HelloWorld.ino to your photon.
This test lights up four LEDs along the length of some of the strip, to test that it's working.
WARNING: Do NOT turn on more than 4 LEDs at once. You risk consuming more power than the USB connection can supply. We will address this in the next step.
Step 13: Construction - Install the LED Strip Power Wires
You may be wondering, why have all those power wires? Do I really need them? Yes, for two reasons:
1. To support turning on several LEDs at once, in case the search result turns up multiple items
2. To provide consistent 5V to all LEDs, as there is a small voltage drop across each LED.
To see what happens if you don't apply power at regular intervals, watch this video:
Why have such a large power supply? Do we really need 60A?
Technically, no. But if you want to run the LEDs at full brightness, then yes. So why limit your options?
Power Calculations
How do we arrive at 60A?
The manufacturer mentions 18W/meter @ 60 pixels/meter in the datasheet, and by datasheet, I mean a bunch of text hastily scribbled down on the product page:
Each row on the organizer is exactly 1 meter, and there are 14 rows, so we have 14 meters of LED goodness.
14 meters at 100% brightness, means the total wattage of the strip is 18W/m*14m = 252W.
We can use the power equation: P = IV, to give us a rough estimate of current (Amps) needed. Rearranging:
Power, P, is measured in Watts; I = Amperes; V = Volts
I = P/V = 252Watts/5V = 50.4A.
The next smallest power supply down from 60A was 40A - too small to power all LEDs at full brightness. So 60A it is. It's a good idea to get a power supply that exceeds the power requirements of your system by some margin, a ~12% safety margin (60/50.4 - 1) in this case is sufficient.
But what happens if you don't know how many watts are used per meter of your LED strip? Well, you can estimate it using rough estimates for other LEDs you may have. Most standard 5mm LEDs, like the red ones shown in the demo video, draw around 20mA of current when running off of 5V. Using that information, we can extrapolate power requirements for an LED strip:
1. 20mA (milliamperes) is drawn per LED, that's 0.020A (1000mA = 1A)
2. RGB LEDs have three LEDs each: one red, blue, and green
3. Find the number of pixels per meter, in this case, there are 60 pixels per meter.
At 14 rows, with each row being 1 meter long, that leaves us with:
14 meters * 60 pixels/meter * 3 LEDs/pixel * 0.020A / LED = 50.4A
Hey great, that's the same Amp requirements as calculated in our previous equation!
Step 14: Construction - Foam Pads V2
We're not done with those foam pads just yet. In the first step, we cut them to size. Now we'll route cutouts and channels for all the wiring to run through. Align the pad to the wooden frame, and use a marker to mark the routes the wires take along the foam pads, then use a dremel to cut holes and channels for said wire to run through. Since we haven't fastened the cabinets to the wood yet, you can just slide them length wise along the frame to access both sides.
As you can see, I did a pretty quick and dirty job of this. But no matter, it never sees the light of day once everything is put together.
Step 15: Construction - Final Touches to the Assembly
To aid with wiring, the cabinets were never fastened in place.
With the wiring done, and the foam pads in place, finally install the vertical board on the left.
Nudge the cabinets so they are flush with the front of the frame assembly, and then drill two holes on the bottom of each cabinet into the supporting wood plank below. Fasten the cabinets to the assembly with the 3/4" machine pan-head screws.
Step 16: Construction - Adjusting the Boards
I found that over time, the foam pads applied a little too much lateral pressure to the cabinets. This resulted in the LED strips buckling off of the cabinet rows. To fix that, I used some wooden wedges to push the cabinets apart and pull the LED strips taught.
Step 17: Electrical - Hooking Up the Power Supply and Testing
WARNING: HIGH VOLTAGE - In this step, we attach the beefy power supply up to all the LED strip power lines.
Do not, under any circumstances, wire up the power supply with the power cable plugged in.
1. Begin with testing that the power supply turns on. See the first photo. Then unplug the power supply cable.
2. Wire up only the first row of LEDs to the power supply
3. Disconnect the second and third row of LEDs
4. Repeat the test on Step 12: Quick Testing. If the LEDs work as expected, great! If not, make sure the 5V and GND power supply lines are wired correctly.
5. When the first row of LEDs is tested and working with the power supply, go on and wire up the remaining LED strip power lines. Repeat Step 12: Quick Testing, but make the following modification:
BeforeAfter
This time, the four-led pewpew that zig-zags across the display should maintain the same brightness the entire way through. Like so:
6. Once all the LEDs are working as intended, go on and cleanup the wiring. Use some double-sided foam tape to secure the power supply.
Step 18: Electrical - Wiring Up the Particle Photon
The particle photon drives two important pieces of FindyBot3000:
1. The Relay - this allows FindyBot3000 to operate in low-power mode, by turning on the LED power supply only when needed.
2. The LEDs - the Photon drives the LEDs through the voltage step-up converter.
Step 19: Software - Download and Install
In this step, we link together the Google Home and Particle Photon.
Prerequisites:
- Log into your Github account
- Download and install Particle Dev
- Download and install Github Desktop
Steps:
1. Navigate to the FindyBot3000 repo on Github: https://github.com/Inventor22/FindyBot3000
2. Clone the repo to your computer
3. Open Particle Dev, and load the project folder: FindyBot3000\Photon\FindyBot
3. Plug in the Photon to your computer via USB cable, and select your photon from the devices menu in Particle Dev
4. Flash the particle photon with the firmware
Before we can test to see if the photon is working with the flashed firmware, we need to setup Google Home to talk to the Particle Photon, through IFTTT.
Step 20: Software - Linking in IFTTT
To test the firmware we just uploaded to the Particle Photon, there are a few simple commands we can trigger on the Google Home.
First, we make an IFTTT applet that is triggered when we say "Ok Google, Welcome $", where $ is the name of the individual you would like to welcome.
As soon as the applet has deployed, you can begin testing your FindyBot3000!
Step 21: Software - Remaining IFTTT Commands
Use the table above to create the remaining IFTTT applets.
Currently FindyBot3000 supports 10 commands which require a SQL database, and another 4 commands which run locally on the Photon.
Requires SQL Database:
FindItem - Find an item
FindTags - Find items matching provided tags, colored on a gradient according to number of tags matched
InsertItem - Insert a new item into the organizer
RemoveItem - Remove an existing item from the organizer
AddTags - Add tags to an existing object. Ex: "Add tags diode light emitting to green LEDs"
SetQuantity - Set the quantity of an existing item
UpdateQuantity - Update the quantity of an existing item
ShowAllBoxes - Light up all the boxes which have items in them with random colors
BundleWith - Bundle a new item with an existing item. Ex: "Bundle 8 blue LEDs with red LEDs"
HowMany - Show, in ASCII text on the display, the remaining quantity of an item.
Local Commands:
Welcome - Scroll text across the display, welcoming the specified individual
SetBrightness - Change the brightness of the LEDs
SetDisplay - Turn on and off the display
ChangeColors - Change the color gradient used by the FindTags command
Step 22: Software - Deploy the Azure Function
A picture speaks a thousand words...
Navigate to the Microsoft Azure Portal and log in.
Here we deploy the Azure Function, and set up continuous integration through Github. In this way, when new changes are pushed to the forked repository you created, they will automatically update the Azure Function with the new bits.
Step 23: Software - Link Particle Photon to Azure Function
In order for the Particle Photon to successfully send data to the Azure Function, it needs to know where to send the message. In this step, we setup a Webhook between the Photon and our Azure Function.
Step 24: Software - Deploy the SQL Database
In this step we deploy the SQL Database, and provide access to the Azure Function via the sql_connection string.
Step 25: Software - Create the SQL Tables
So we've got the Photon talking to the Azure Function, and the Azure Function talking to the SQL Database. But We're not out of the woods just yet. In order for the SQL queries in the Azure Function to work correctly, they need to query SQL Tables. In this step, we create the necessary tables in the SQL Database.
Step 26: Final Thoughts
There's a lot more that can be done!
In the future, there will be room for an LCD to display debug information, or animating the lights, beyond just text scrolling.
Step 27: Thank You!
Just a quick update -- Looks like this Instructable has won the grand prize in the organization contest! Thanks for the votes everyone :)
Organization Contest
Grand Prize in the
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    • Arduino Contest 2019
    116 Discussions
    zpaeric
    1 day ago
    This was an excellent project! I plan to make one as well, but I have many more parts than a set of single drawers can hold. If I built my shelves 5 deep, I can use flashing leds in the groups of 4 to identify which bin in that row contains the parts. No flash could be the front drawer and each flashing led would indicate drawer 2,3,4 and 5!
    Thank you for the inspiration! Waiting for parts to arrive to get this started. I will post progress, and may have some programming questions to handle the 3D array...
    Inventor22zpaeric
    Reply 21 hours ago
    Thanks. That sounds great, a 3D setup would definitely be more compact. A bunch of different ideas could be used to represent the Z-axis, I like the flashing LEDs idea you mentioned. For sure, feel free to PM me or post any questions here.
    unbelivable! It is FANTASTIC! thank you so much for sharing, it is so cool! Have a great day :)
    KitP6
    7 days ago
    The linked solid state relay is not one that can work on 5v DC switching input (They may have changed the product listing). :(
    Inventor22KitP6
    Reply 6 days ago
    Thanks, I've updated the Instructable with a new link and price.
    KonradO6
    12 days ago
    Will it work with other languages supported by Google Assistant?
    PortalGamesMais.KonradO6
    Reply 12 days ago
    I’m from Brazil and I tried to test ifttt with google assistant in português and it wouldn’t work because ifttt was set to English. After changing my google assistant to English it worked , so I guess that if ifttt supports your language than you can use it
    KonradO6PortalGamesMais.
    Reply 9 days ago
    Thank you. So currently it's English only.
    Or maybe there's an alternative to IFTTT.
    PortalGamesMais.Inventor22
    Reply 9 days ago
    When using the ifttt app on my iphone and creating a google assistant applet there is a picker where eu can chooose one of 6 languages.
    PortalGamesMais.
    Question 15 days ago on Step 3
    Can I use the google assistant app on an iPhone?
    If I use a nodeMCU instead of photon do I need to change any code?
    Inventor22PortalGamesMais.
    Answer 14 days ago
    Yeah, Google Assistant is available on iPhone: https://itunes.apple.com/us/app/google-assistant/id1220976145?mt=8
    You will need to change some code around if you use nodeMCU, primarily in two main ways:
    1. Use the Arduino-version of the neomatrix.h, Adafruit_GFX.h, neopixel.h, ArduinoJson.h libraries that I make use of in FindyBot3000.ino. These should auto resolve as you load the code into the Arduino IDE.
    2. You can't use the Webhooks as implemented in the code, as they are configured through the Particle website (See Step 23: Software - Link Particle Photon to Azure Function). There will be a way to work around this though, but I couldn't tell you how off the top of my head, as I've never used nodeMCU. You might need to write custom HTTP requests. I did find this Instructable which looks promising: https://www.instructables.com/id/IoT-Air-Freshner-with-NodeMCU-Arduino-IFTTT-and-Ad/ and this: https://docs.microsoft.com/en-us/azure/iot-hub/iot-hub-arduino-huzzah-esp8266-get-started Those should help get you started.
    Reply 13 days ago
    If you plan on using the Akro-Mils cabinets that I linked in the Instructable, I recommend against using LED strips which have 5050 LEDs. The horizontal spacers between rows is only 3-4mm wide, so if you were using a 5mm wide or greater LED strip with 5050 LEDs, you run the risk of snagging the strip when you pull a box open. The 4mm-wide LED strips I linked to don't have this problem.
    Reply 13 days ago
    I live in Brazil $1 US dollar is R$4 Brazilian reais so it’s quite expensive for me. Do you know if I can find them cheaper anywhere? I actually found cheaper, ones here in Brazil but they are 12 v if I buy them and a 12 v power supply can I use sparkfuns Logic level converter with 12 v hv and 3v lv?
    Reply 12 days ago
    Aliexpress is the cheapest place I know of for LED strips. If you really want to save money, you can do away with the LED strips altogether, and wire up individual LEDs instead. I did this with a previous version of this project that I built with a few friends. You can see it in operation here: https://www.youtube.com/watch?v=0K0eq_KBbkQ
    Can you link the model number of the LED strip you're thinking of using - i'll check to see if it's compatible with the libraries I use, and we can go from there.
    Reply 12 days ago
    Thanks a lot for the help, I’ll post link at end but it’s in portuguese so I’ll translate the specs first:
    -3528 rgb led strip
    -12v
    -200 Lumens approximately 180w
    -60 LED’s/meter
    - can cut each 9 LED’s (5cm)
    -9.6 W/M
    It actually comes with a controller but i obviously won’t use it. it costs 40 reais for 5 m which would be like 10 US dollars.
    Link: https://produto.mercadolivre.com.br/MLB-932778194-fita-led-rgb-3528-5m-controladora-fonte-cont-remoto-_JM
    I’ve decided to build my own organizer out of wood and acrylic drawers because I couldn’t find any good ones here in Brazil and the space between rows will actually be 1.5 cm so technically I could use 5v 5050 LED’s. How can I check my self if they will work with your libraries?
    Reply 9 days ago
    I can't tell from the listing whether the LEDs are individually addressable or not. However, given that the product page doesn't show any images of different colored LEDs on the same strip, i'm going to assume that the LED are not individually addressable. There was no sign of a datasheet either, so I really can't recommend this product for this project.
    If the Aliexpress prices are outside your budget, there is a cheaper alternative -- using regular LEDs and an LED driver chip (MAX7219). Although the Max7219 chips aren't the cheapest either: https://www.sparkfun.com/products/9622
    This route does get fairly technical fair quickly though, in terms of wiring and programming.
    audrius-a
    Question 9 days ago
    Really awesome and well made project. I was dreaming to make something simar and this might be just enough to inspire me to finally do it.
    What do you think of Akro-Mils drawers quality? They look reasonably priced, but are they well built?
