Fire Pit Coffee Table
20,697
302
13
I fell in love with the concept of having a little gas space heater on my screened in porch. I looked around and noticed a lot of different styles and shapes. But none quite fit my level of DIYness. So, I do the only logical thing. See how they built theirs, copy and paste. I hope that you can learn from my build and have some luck building one for yourself if you want to.
Step 1: Total Costs, Materials, and Tools
This table didn't cost me much out of pocket money. But I was lucky to have a lot of wood scraps, a good friend who has a metal working shop, and an old grill for inspiration and a gas regulator hose.
80# bag of quickrete
20# bag of lava rock
$10
Scrap 2x10's
$free
Scrap angle iron
$free
Tools
Bandsaw
Miter saw
table saw
nail gun
grinder
welder
band aids
planer
Aspirin
Step 2: Concrete Table Top
This is a complicated build for my skills. I'll try and make it easily duplicated but if yyou have any questions just ask away.
The table top is 44"x21". This is made to fit my porch area. I start out with a piece of plywood and set 1.5x1.5 boards as a boarder. The middle is a piece of MDF that is the void for the burner. It is cut to taper on all four sides. This will make it easy to remove once the concrete is cured. Half way through the pour, I put a piece of chicken wire in and then continue pouring concrete. Once it is all layed in the form I tamp(vibrate) all the outside boards to get a good coverage of concrete in the edges. I leave it in these forms for one week to let it properly cure.
Step 3: Burner and Basket
I worked in reverse mode to make this go together.
Firstly the burner and pan had to be removable. This way in the summer months I can take out the fire and add a Zen garden or a dill garden. The south doesn't need a space heater in July. So there is a 1/4" angle iron that is the flange that sits in the center of the table. Then I made a 1.5x1.5 angle thin angle iron stock to make a hanging basket that holds the burner and tray. It's all piece milled from small stuff that my friend had laying around his scrap pile. "
The burner is made of 3/4" rigid pipe with 1/16" holes drilled every 3/8". I welded a piece of 1/2" coupling on for the adapter to a gas grill LP tank. Then had to reduce that to 3/8" and a 1/4" to 3/8" adapter for the final piece.
Step 4: Table Frame
The general plan was to make the table look like a loose stack of lumber with very petite looking pointy legs.
I used mostly scrap 2x10's for this. I had a pile of lumber that consisted of 4' yellow pine 2x10's. The legs are cut square 1.5" and the ends are tapered to a point with a bandsaw, plane, and sander.
I made the sides up first. All of the boards are cut to slightly different lengths, widths, and heights. Then glued and brad nailed to the legs. The ends are made of a bunch of chopped up boards to match the height of the side board. The style is random. So, when I worked this lumber, I didn't use a tape measure. I just sited everything together. I glued up all of my end pieces and then glued them together like a cutting board. Then glued them to a piece of luan plywood. One side is glued and brad nailed to the table. The other side is hinged at the bottom with a piano hinge. Held in place by a 3/8" dowel at the top corner which blends in very well.
Step 5: Voila
Added in a little bit of lava rock that I bought from lowes for about $4. and going to enjoy the last bit of chilly nights and any brisk mornings with a cup of coffee.
Fire Challenge 2017
Grand Prize in the
Fire Challenge 2017
    • Arduino Contest 2019
    • Fandom Contest
      Fandom Contest
    13 Discussions
    ronk53
    1 year ago
    Does your gas line go straight into the burner, or is there an orifice used like with a BBQ? Would it make a difference if the gas hose connection was on the end rather than a middle T connection?
    SeanM324
    1 year ago
    Nice project. You should check if the gas grill LP tank is made to be on the side. Most are not. Those that can are the ones that are found on lifts. This could be an issue for your house insurance.
    kllrSeanM324
    Reply 1 year ago
    ---> Listen to this guy. If this tank is left on its side with the improper hardware you will have liquid propane running to your regulator. At this point the regulator will fail and spray liquid propane all over the place. As the liquid enters the atmosphere the pressure drops and it starts to convert into a gas and then you have an explosive situation on your hands. But assuming you have take all the correct precautions, this is a very cool project, it looks great.
    bknabe81kllr
    Reply 1 year ago
    How can you determine if your tank is able to be used on it's side??
    Mosspaw123
    1 year ago
    SO COOL do not have space to make it yet, looking for a bigger place and will add this to my list of things to look for as more space :D
    gomer394
    1 year ago
    Awesome build! What do you think about having your buddy fab up an ice bucket insert for the summer months?
    dalegribblegomer394
    Reply 1 year ago
    funny you mentioned that. My buddy just made a cooler insert
    wcobb0161
    1 year ago
    Good design, straight ahead construction, I really like the duel use feature for July-August months. Enjoy!
    TomO29
    1 year ago
    Nice project however lying a propane tank on its side can be very dangerous unless designed to be used that way.
    Tcdevine
    1 year ago
    Looks great and the table will work well when you don't have a fire going.
    rayp1511
    1 year ago
    Very well done, I like that it's multi-purpose depending on the season.
    Involved Observer
    1 year ago
    Very nice project, and I love your "wood pile" table design. Well done!
