Fluorescent to LED Conversion Under $30
144,188
701
56
Welcome to my first 'ible. I have done a lot of projects, but this is the first time I've documented one well enough to create an 'ible. The purpose of this was to create an LED lighting fixture that was as bright as a the original fluorescent, and even more economical on power. The side benefit would be getting rid of the need to climb a ladder to replace fragile mercury-filled tubes.
First off, if you are not comfortable working with real electricity, DON'T DO THIS.
Second, read the whole thing before starting work. Some steps are optional and if you actually do some planning, you can probably do this better. This was kind of a seat-of-the-pants proof-of-concept thing.
What I did was to remove all the fittings to hold the fluorescent bulbs and all the normal wiring from an overhead lighting fixture in my kitchen. I replaced them with a self-adhesive string of ultra bright LEDs and an old 12V power adapter from an old cable TV box.
Supposedly one 32 Watt fluorescent tube produces 2600 lumens, and there were two tubes in the fixture. The LED strip is supposed to produce a total of 2600 lumens, but my impression is that the LEDs were brighter than a pair of tubes. Perhaps my eyes adjusted, or the fluorescent tubes may not have been performing as they should. Since the fixture was defective when I started this project I find myself unable to do a comparison. I hope that someone else will be able to do a before and after test.
Enjoy!
Supplies:
Step 1: Parts & Tools
The parts that I used included:
  • A dead fluorescent lighting fixture ($0)
  • A 16.4 foot high density roll of 600 LEDs - 5000K, 164 Lumens per foot ($23)
  • A spare 12v power adapter I had laying around ($0)
  • Salvaged wiring from an old computer power supply for jumpers ($0)
  • A zip tie ($.02)
  • A bag of veggie strings as snack food, since I was figuring this out as I went along ($4)
The tools that I used were as follows:
  • Wire strippers
  • Slip-joint pliers
  • Screwdriver
  • Scissors
  • Clamping tweezers
  • Angle cutters
  • Needlenose pliers
  • Soldering iron & solder
You may need other tools depending on the model of lighting fixture that you are working on. Other fixtures around my house would have required nut drivers in order to access some of the nuts. On the kitchen one I was able to use slip-joint pliers for all the nuts.
Step 2: Disassembly
This is another point where I will say that if you aren't comfortable with real electricity (AC in the wall) then don't do this. Also, if you are not mechanically inclined enough to strip out the ballast resistor and other wiring from the fixture on your own, you probably shouldn't be doing this yourself. Before you complain that I'm leaving stuff out, I have looked at the three fixtures in my house and they are all quite different. I'm confident that the instructions to disassemble my lighting fixture would bear only passing resemblance to what needs done to clean your fixture of its old guts. I ended up only needing a screwdriver and some slip-joint pliers.
Step number 1 is to find the circuit breaker that controls the thing you're going to work on. Since I was working in the kitchen, I got the unfortunate news that the light above the stove and the one over the sink were all on the same circuit. It crossed my mind that I could possibly work on the lamp wiring by relying only on the light switch for the lamp so that I could still have a couple lights to work by. Then I realized how stupid that would be and left the circuit breaker off while I worked. If you're wondering why I had to use flash... there you go.
Once you have removed everything down to the frame of the fixture, go through the wiring and see if it is suitable for use for jumpers. If so, hang onto it. If not, then you will need another source of wire. I used a bunch of wire that I took out of an old computer power supply.
Step 3: Install LEDs
The string has an adhesive backing. The peel off backing was buckled because the strip is shipped on a spool. It took some work to get the string stuck down well. If I do this again, I will probably add something as insurance to make it stick better.
You don't have to cut the string apart, but I did in order to avoid curving the string. Play with how you want to line them up and see if the bend radius is acceptable. I wanted all the LEDs aimed down because of the way the fixture was designed and I thought the soldering would be pretty trivial for me. If soldering is a weak spot, then you don't need to cut the strip. Just stick it in place and call it good. It was a 4 foot fixture, and I had a 16.4 foot long string of lights so I ended up with a few inches left over after I got them all put in.
The important part is making sure that the power connector is in a good position to reach the power supply.
Step 4: Solder the Jumpers If Necessary
If you cut the string apart, then you will need to make jumpers. Measure the distance you need and use the wire cutters or the cutting surface on the strippers to cut your jumpers. Strip them back about 1/8". Another reason I used the computer wiring was so that I could be careful about the polarity. + is red and - is black. This is important because the way I arranged the light string, I ended up with the polarity reversed across each jumper bridge. That's what happens when you're making it up as you go along.
Put a drop of solder on the ends of the jumpers. This is called "tinning" the leads. I use the clamping tweezers for holding the jumper while I tin it. It normally takes a little while for the flux to get the solder to wick into the strands of the wire. Make sure the soldering iron is hot enough and work quickly. The first jumper I tried to tin was done with an iron that was too cold. I went ahead and held it in place long enough to make the solder flow, and the heat soaked down the wire and melted the insulation. If you do the same thing on the string of lights, you can burn the nearest LED, or melt the solder that holds it in place. Work with a hotter iron and move fast for good technique. Do all of the jumpers before you start tinning the light strip to get "into the zone".
Then tin the copper jumper points. Put a drop of solder on the copper and get a nice shiny little dome.
Having solder on these two parts separately will make it so that you can join them together quite easily. Since you are soldering close to surface mounted components, you don't want to spend too much time soldering and overheat anything.
Then hold the jumper against the solder point (verify polarity!!!!!) and hold the iron against it just long enough to melt the two together. As soon as the solder melts, take the iron off the puddle and hold the jumper in place while it cools. I used the needle-nose pliers to hold the jumper without risk of burning my fingers.
Step 5: 12V Connection
Since the fixture hangs from the ceiling and the top is reasonably well concealed, I decided to just throw a zip tie around the power brick and secure it that way. I ran the 12v connector down a hole in the fixture and plugged it together.
This is the time to test all your soldering. Plug the power brick into a working outlet. I had one in the living room that was controlled by a switch, so I plugged it in there and threw the switch. Everything lit up nicely and there was no sparks.
So far so good.
Oh, and it's BRIGHT!!!
Step 6: 110v Power Connection
The hanging wires were secured to the old fixture wiring with twist caps. If your fixture plugs directly into an outlet in the ceiling then you won't need to cut off the plug. Just use the plug if you can. In this case I had to cut off the plug and strip the wires back the correct amount for the particular twist cap in use. The dangling wires were stripped back 3/4" so that's what I did to the cord for the power brick.
The connector that I cut off the power brick was not polarized, so I didn't worry about polarity at all. I just connected the ceiling wires to the wires of the power brick with the same twist caps that were used for the original fixture.
Once I was confident everything was connected properly, I turned the light switch on and went out to enable the circuit breaker. I watched through the kitchen window for a minute to see that nothing sparked or caught fire. It would have been much faster to get the circuit breaker back off if anything had gone wrong. Nothing did, so I closed the panel on the circuit breakers and went back inside.
Yay!!
2 People Made This Project!
  • Gardening Contest
    Gardening Contest
  • Arduino Contest 2019
56 Discussions
bobchabot
3 years ago
I did this conversion in the nasty light box in my kitchen. Worked great but to be honest the amount of light from the led strips half the fluorescent put out. It's ok. I'm satisfied I did it. My ugly kitchen box needs to come down eventually. I'll move the led strips to the closet or shop table light after. Great inspiration!
bobwojo
4 years ago on Introduction
I just purchased two 4" LED shop lights from Sams Club for $35 each
5000K, 4200 lumens. Sell the old fixtures and buy new!
ChrisP14bobwojo
Reply 3 years ago on Introduction
Finally spotted this myself. Don't need to change out tubes now that these are on the market. I'll be replacing the one in my shed instead of rewiring. Any problems, I'll post here. The ones at Costco are 3700 lumens, so I suspect a different manufacturer.
bobwojomikeyc.2009
Reply 4 years ago on Introduction
The manual says no.
Lights of America #8140SE-WH5, Not on their web page, probably made exclusively for Sams.
KROKKENOSTER
Hi! A friend of mine was able to get me lamps for about $3.00 and I replaced the NEW fluorescent lamp with just two of the LED bulbs that gave me a brighter light than the dual fluorescent fitting eating 80 watts while the LED only consumed only 7 watts each.They look just like frosted incandescent lights. I opened the one to see the PSU and the real voltage of the led's and I found that there is thirty five of then in series and the PSU is just a series capacitor full wave rectifier and smoothing electrolytic. (We use 240 volts as mains). I then replaced all my lamps with these lamps. The (LONG LIFE) CFL's only lasted between 9 to 24 months and they are only half the price of the LED lamps.I had on one circuit a CFL and an incandescent lamp and the CFL had an average life of nine months and the older incandescent still working after 25 years!! If you want to claim on the warranty of 24 months they have a whole library of reasons why it is your fault that they fail!!.Fantastic idea and now to find a source here where I stay................................??
Fluorescent tubes dim over their lifespan, so the 2600 lumen figure you found is probably "initial lumens." Depending on their age, they may have dimmed considerably.
I'd been considering replacing some fluorescent cove lighting that reflects off a ceiling as the room's primary light source, but hadn't considered trying the tape LEDs. The LED tubes are still very expensive. I appreciate knowing from someone's actual experience that a reel of tape is comparable to two tubes.
The vendors always say "20,000 hours" or some made up number, but that is dependent on heat. Cool those chips well, and they'll last longer than you will. I see a lot of flashlights and toys that overcurrent the LEDs with no decent heat sinks, and they dim fast.
ac-dcwalter.warren1
LEDs also dim over their lifespan but the lifespan rating for fluorescent takes this into account, that they don't just fail at that point, rather dropping below a % of rated output.
Odds are that if they were used for several hours at a time, the T8 fluorescent tubes would outlive the LEDs. LEDs "can" have equal or better lifespan but only if kept at a lower, cooler, drive current.
starphire
I did note that the sweet spot between cost, mass availability of the latest generation of LEDs, and "good enough to beat the competition" is where the money is in retailing of "light bulbs" to home and small business users.
Big box stores such as you mention have long used "high bay" lights throughout their cavernous spaces - those huge fixtures waaaay overhead are high wattage HID lights, which have long been more efficient than fluorescents in such applications, for a variety of reasons. They are also in the same ballpark as LED lightbulbs are currently, but consumers can't just screw an HID bulb into their fixtures, can they?
Also, because they are retail operations they need the entire space brightly lit during store hours. So while there would be *some* payback in energy savings and less frequent bulb changing, it's not yet a slam-dunk for them to replace their HID fixtures with LED ones. But it will be soon enough, as HID isn't going to get any better, it maxed out its potential decades ago.
In storage warehouses and other large locations where "smart light" technology can selectively dim or shut off lights in spots where nobody is currently working, there is HUGE energy savings to be gained from switching to LEDs (HIDs can't do that, and fluorescents also suck at it) and in fact many corporations are doing just that.
In other retail locations, there has been an ENORMOUS shift towards LEDs, though it may be difficult to tell if you don't look too closely. Also, pretty much every refrigerated display case you look at is LED now, and display cabinets in clothing and jewelry shops, and the list goes on and on. Most of the towns where I live have switched over their streetlights to LED, or are in the process of it. Also, LED retrofit tubes that fit into a standard fluorescent fixture are also popular now. Offices, schools, and all sorts of institutions and corporations with large electric bills have already switched.
Your question was well-placed if you meant to throw doubt on the future of LEDs, in that you asked about one of the small niches that will probably be among the last to go because the payback will take longer than in other applications.
ChrisP14
I had taken the cover off the fixture and looked at the strip while powered. My recommendation is not to do that. Like I said, it's BRIGHT. I couldn't tell any difference in brightness. Of course there will be a voltage drop, so I got out my Fluke DMM and found 11.34v at the first set of LEDs, and 10.35v at the last set of contacts.
Oh, and guess what? The strip is starting to sag, so it looks like I will be ordering glue!
CoreyCoop
4 years ago on Step 1
I have found two strips of the 5000K LED strips ("Bright White") matched with one 3000K ("Warm White") makes for a better tone, not as taxing on the eyes, but still bright and good for detail.
bhirsh
Nice job at re-purposing an old fixture. AS far as the techy side goes, RELAX! It lights and it works for him. That is what is important. If somebody wants to study LED's and come up with a better light, please do it an post so others can learn. In the mean time, this works, good job! IF I was going to mass produce and sell these, then I'd study all about LED's and power supplies and glue, and.......
ve1fsm
4 years ago on Step 6
Great idea, I used some of the self adhesive lights under the counter and use a 12 block . If I do one of these lights I think I would mount a electrical box on top and plug the Box in, My wife would love a extra place to plug in Christmas lights without running cords.
jimvandamme
Seems like LEDs on reels come in either too blue (5000K) or too yellow (2500K). Both look terrible to me. If or when I find some that are neutral white (3500K) I'm going crazy with relamping the house. I've gotten big 10W chips that are just right, but no strip lights.
LaserDaveschmitta
Actually, that ballast is a transformer. The magnetic device in the older-style lamps, that required a starter, would be classified as an inductor.
LaserDaveschmitta
HowToEngineer
4 years ago
Great 'ible! Someone already mentioned deep in an essay below but it's a good note. Wire all of the strings in parallel (like an E shape) instead of in series (like an S shape). This will insure all strips get the same voltage so they all light up the same beightness
Hugu
with less than 6€ you just can buy a led tube lamp and change the fluorescent lamp!.. more cheap and easy!!
http://pd.prlog.org/40044985-1-t8-led-tube-light.jpg
