Foam Walkalong Glider
86,473
112
31
This instructable shows you how to make a walkalong glider by thermoforming a styrofoam sheet. The foam sheet used here was obtained from the Owens Corning Raft-R-Mate product available in the insulation department of most home building supply stores. Here's a video of the X-Surfer foam walkalong glider inside:
...and when there is no wind outside, here's a flight down the sidewalk:
It is reccomended that first timers start with the tumblewing walkalong glider design as it is much simpler to build and easier to fly because it is slower.
Supplies:
Step 1: Cut Out the Pattern Outline of the Wings
First print out the half wing outline twice and cut each form. Turn one of the outlines upside down and tape the two pieces of paper together at the wing root. The resulting outline should have a wingspan of about 28cm (14 inches):
Step 2: Cut Out Piece of Raft-R-Mate Material
the Owens Corning Raft-R-Mate product can be found in the insulation department of most home building supply stores. Alternatively, thin (1mm) depron or other foam may be used. If the material is already in sheet form, this and the next step on thermoforming the Raft-R-Mate into a sheet can be skipped.
The Raft-R-Mate product does not come in nice flat sheets and must be cut and thermoformed. The pink foam is cut so all bends are parallel to each other. This makes thermoforming the material into a flat sheet easier. Here's how to cut the foam:
Step 3: Thermoform Raft-R-Mate Into a Sheet
Using a house hold iron set to a temperature suitable for acrylic, Gently heat each bend in the Raft-R-Mate material. Do not apply pressure, but wait until the material gives. Rock the iron to evenly heat the bent material, holding the iron flat against the seam. If the iron is melting the material, it will get sticky and the iron should be set at a slightly lower temperature. Not enough temperature and the material will not give when heated. Just the right temperature and the material will give and the iron will still slide over the material. Applying too much pressure or force on the iron will buckle the foam, creating creases which will affect the material's structural integrity. Here's a video of the cut material being thermoformed into a sheet:
Step 4: Cut Out Foam Sheet According to Pattern
In this step the flattened foam sheet is cut according to the pattern created in step 1. There should be enough material for 2 gliders in the Raft-R-Mate material used in the video (if the cut lines do not overshoot the angles too much):
Step 5: Draw Lines for Elevon and Airfoil Bends on Top and Bottom of Wing
In this step the lines creating the elevons are drawn on the top of the wing cutout and lines creating the airfoil are drawn on the bottom of the wing:
Step 6: Thermoform Dihedral and Washout Angle
Step 6 involves thermoforming a twist and upward bend (also called [http://en.wikipedia.org/wiki/Dihedral_(aircraft) wing dihedral]) to each wing. The wing root will have a higher angle of attack than the with tip which prevents tip stalls when applying control inputs about the [http://en.wikipedia.org/wiki/Roll_(flight) roll axis] (also called the [http://en.wikipedia.org/wiki/Washout_(aviation) wing washout angle]). The dihedral in an airframe design makes the aircraft more stable in the roll axis.
It is important to do this step before bending the airfoil.
Step 7: Thermoform Airfoil Shape to Wing
In step 7, an airfoil shape is thermoformed in the wing. Here's a video of making the first bend along the line closest to the leading edge of the wing:
Do the same for the remaining two lines:
Step 8: Thermoforming Elevons
Thermoform the elevon surfaces to the trailing edge of the wing:
Step 9: Flatten Out Airfoil, If Needed
If needed, flatten out the airfoil and elevon surfaces. This thermoformed model has airframe design features exagerated for clarity and needs to have them flattened out to improve its glide ratio.
Step 10: Fabricate a Nose Boom Ballast
A paper clip is straightened out to make a forward ballast to be attached to the nose. This weight will allow adjustment of the weight and balance:
Step 11: Test Flights
The following step involves elevon and ballast adjustments to get the glider flying slowly, smoothly and in a straight line. Initially, the ballast should be as forward as possible.
Test fly the glider, launching it with a slight nose down attitude and at approximately walking speed:
adjust the elevons to get the glider flying straight. In the last video, the glider flies too much to the right, so the left elevon needs to be flattened:
The turning tendency has been corrected. Here is the second test flight:
In the last video, the elevons are trim too nose up and need to both be flattened:
How does it fly now? Let's see:
After more elevon trimming, the glider flies like this:
For general flying information, see the instructions at:
How to fly the x-surfer type walkalong glider
Step 12: Flying Lessons
Step 13: First Controllable Soaring Flight
The launch of the glider should be as close to the glider's trim speed and altitude as possible to avoid pitching the nose up (too fast) into a stall or entering too steep a dive (too slow). The glider should keep flying straight out of your hand. Once the glider is in stable flight, bring the controllable slope (here a 50cmX70cm piece of cardboard) so as to position the glider in the rising wind at the top edge of the controllable slope. Here's a video of an indoor flight (same as from first page):
    • Arduino Contest 2019
    • Woodworking Contest
      Woodworking Contest
    31 Discussions
    wingnutzsteri love aircraft
    Reply 2 months ago
    Not a walkalong, it would fly and be stronger but quite a lot heavier and not float as well as lightweight foam, get some meat trays or disposal foam plates
    wingnutzsterdelonzo
    Reply 2 months ago
    For what? To replace the foam? no absolutely not, you could however replicate this with poster board but it will not fly as well or stay up as long - there's a reason foam is used and lightness is a fundamental of aeronautics.
    delonzo
    5 years ago
    Awsome
    ilpug
    7 years ago on Introduction
    Okay, way too many videos. Maybe you should have cut them together into one long movie?
    anyway, great glider. i love these things. i wonder how large you could make one of these to scale and have it still work?
    mikeasaurus
    9 years ago on Introduction
    What fun, I love the concept! The type of foam used is genius, as is the method for forming the wing. The instructions were awesome, a bit heavy on the video though. Maybe just an edited video of the process, supplemented by a few pictures. Looks like a lot of fun to fly!
    Glad you liked the concept. There are lighter foams available so this design is a compromise. It really flies too fast for my aging body and gets away from me often (nice aerobic workout, though). Between getting the weather right (no wind) and the glider trimmed properly and the effort and coordination involved, this glider probably looks like more fun to fly than it is (kind of like playing the violin). If a flying animal does not need flight for survival it quickly loses the ability to fly (like one generation or so). But hey, "everything is impossible until somebody does it". That's what makes the tumblewing so much better: able to turn on a dime, no weight and balance issues, able to be constructed and flown at a moments notice.
    masteruke
    8 years ago on Introduction
    the glider is nice however instructional needs to be worked on. For example it doesn't say how much angle should be put on the nose or on the wings etc. Maybe if he slowed down and explained the steps he took would help.
    toxicwolf
    ive used your design and put a motor on it it worked but i had to up scale it i also mounted a radio controll system
    J-Five
    Cool, but when I saw the picture to get to this Instructable it looked like it was your tongue!!!
    cyuen
    9 years ago on Step 2
    The foam sheet is big....i dont know if i need that much...
    walkalongaviationcyuen
    Reply 9 years ago on Step 2
    With the pattern given, there should be enough sheet material for two gliders in the cutout resulting from this step. That way you can have your own pylon race with a friend!:
    frollard
    You should really add a video that shows a side-view during flight to help explain the updraft gliding concept. Really really cool!
    zaphodikus
    Hmmm, definitely needs a better introduction. without one it's just a cool video. It's a bit like showing the end of the movie before the beginning. Seriously now, where do we go to learn how to debug our glider?
