Fountain Soda Maker
1,596
19
5
About: How to Everything.
Hi,
Welcome Again !
Today I show You How I make Fountain Soda Maker at Home Using CO2 Cylinder and PVC Pipe.
Materials :
PVC Pipe
Co2 Cylinder
Pen
Bottle
Silicon Pipe 1 cm dia.
Supplies:
Step 1: Cutting Pipe
Take a 15 CM 1 Inch Dia. PVC Pipe and cut as per Picture.
Step 2: Drill Holes
Drill Two 3 mm Dia hole as per Picture using Drill Machine.
Step 3: Take Cylinder
Take one KG CO2 Cylinder and Cylinder adapter.
Step 4: Join PVC PIPE
Take PIPE and CO2 Cylinder Adapter and joint as per Picture using screw.
Then Glue wooden part using Glue Gun.
Step 5: Install Cap to Pipe
Take PVC cape and try this work or not.
Step 6: Connect Pipe
Take 1 cm dia. and 4 feet length Silicon pipe and connect to co2 cylinder.
Step 7: Make Pressure Adapter
Take Pressure adapter and cut some portion then join with pen.
Step 8: Glue With Bottle Cap
Drill Hole through bottle cap and glue pressure adapter to bottle cap.
Step 9: Experiment
Connect bottle cap to bottle and pres PVC handle slowly.
Step 10: Enjoy !
Enjoy Drink !
    • Woodworking Contest
      Woodworking Contest
    • Arduino Contest 2019
    • IoT Challenge
      IoT Challenge
    5 Discussions
    Mousepotato01
    Question 1 year ago
    Is there room on the system for a psi device? I would think that the bottle may rupture seriously injuring someone's hand if over pressurized the cap is fastened tightly on by threads and the fitting has a rim to hold it in place but I have seen what happens to plastic containers when over pressurized. This would be in the case of a child or young adult using it and saying hmm wonder what would happen if??? I mean common with them doing tide pod challenges one needs to think safety with items as of this nature. If you implement safety into the design I think you may have a very marketable item here that would be in the price range for most of the world with today economy. But other than the safety issue very well done I commend you on the build. I have not ever used one of the systems so I really do not know the nuts and bolts of it so to speak I merely make my statement by looking at the design of your magnificent build and wondered about safty in todays world knowing what I know about over presurasation on them containers.
    1 answer
    Mipy
    1 year ago
    This is the simplest design for one of these I have seen, great job!
    Sherriff
    1 year ago
    nice build, where do you get cylinders and adapter from?
    Thorondor95
    1 year ago
    Good idea to save money!
