French Press Cold Brew Coffee
150,646
424
53
About: I love biking, hiking, nature, puppies, and coffee!
I love coffee - but my addition gets pricey when I've got to shell out $4 for a small carton of cold brew coffee from my favorite local coffee shop. I also love iced coffee, but cringe when a barista pours hot coffee over ice: it's bitter & now it's just diluted.
Solution: make my own cold brew coffee using a french press!
The key to cold brew coffee is that it uses time - versus heat - to make a perfect cup of joe.
Grab your french press and let's get started :)
Step 1: Materials
- French Press
- Filtered water (you can use just tap water, but coffee is 99% water, so ya might as well use the best tasting water you can get your hands on)
- coffee: coarsely ground!!
- measuring cup
- rubber band
- plastic wrap
- coffee creamer (optional)
- sugar (optional)
- recycled glass bottle to put all of your delicious coffee concentrate into once you're done
Step 2: Let's Get Brewing!
- Add 2 cups of coarsely ground coffee to your french press
- Add 4 cups of (filtered) water on top
- Stir!
- Place plastic wrap over the top, seal off with a rubber band
Step 3: Wait... Patiently.... Then Press It!
The recommended time for cold brew is between 12 - 18 hours. I brewed mine for 18 hours, and it turned out perfectly!
Once you've waited oh-so-patiently for the perfect cup of coffee, press it!
Step 4: Prep Your Perfect Cup of Cold Brew Coffee!
With this recipe, I recommend diluting it 1:1 (coffee concentrate to water ratio).
For those who get the jitters from strong coffee, I'd kick the water portion up a notch, as this is quite strong.
Grab some water, ice, a cup, and creamer and/or sugar, and kick start your morning with this coffee! Store your coffee concentrate in the glass bottle you're re-using, and now you'll have coffee concentrate for your work week.
You can even use your coffee grounds in your garden as compost if you want!
Thanks for reading my Instructable, and if you try this, let me know!
  • Pie Contest
    Pie Contest
  • Fat Challenge
    Fat Challenge
  • Jewelry Challenge
    Jewelry Challenge
53 Discussions
dutchlady
1 year ago
I love my French Press. I started using it when I lived in the Netherlands and now use it, along with my other cold brew appliance, for my coffee. It makes delicious coffee and I buy my coffee, ground coarse, at the local grocery store.
celtliams
2 years ago
I will be trying this tonight!
thenateO
2 years ago
Do you need to refrigerate it overnight?
autumnphoenix2
2 years ago
Just made this last night/am drinking it this morning....PERFECT ratio of coffee to water. Most cold-pressed coffee recipes have the ratio for unground beans to water, and I only have ground coffee.....thanks! Excellent :)
JessicaS217
2 years ago
Awesome! Thank you. I love coldbrew coffee and want something I can keep in my tiny fridge by my desk and not share with anyone! lol. Really though, this is great. =)
PW5
2 years ago
You can scale this up to a gallon easily using a plastic or glass jug; let the coffee mixture sit in the fridge for 24 hours then strain. Med and Dark roasts work best - really brings out the chocolate flavors. Doesn't need sweetener or ice or anything.
StinkyPete1211
3 years ago
Just curious if you measure the coffee ground or whole? My 8 cup press was 3/4 full after adding 2 cups of ground beans.
GenerallyOdd
3 years ago
If you dont have course ground coffee you can use regular - you can simply pour it from the pot into a jar (I use a wine bottle) through a coffee filter.
peads92470krisprince
Reply 4 years ago on Introduction
I love coffee milk, but I LOVE my iced coffee. Would this be diluted with water or more milk? Maybe the answer is obvious, but I can't figure it out. But then, I haven't had my coffee yet either.
peppypicklekrisprince
absolutely! milk is a great substitute, almond milk or soy milk are great additions too :) Thanks for your comment!
Wilferno
3 years ago on Introduction
I made this and it's so good! It's so smooth and delicious! Thanks for the instructable!
jaimepedro
VERY ECOLOGICAL and ANTI Global Warming +++ TASTY..!!! Congratulations..!
WilliamL17
3 years ago
For Coffee on the go a nice addition to our Bus
MicheleS10
3 years ago
What size French press are you using. I want to be sure measurements will work in mine. Also do you dilute w water THEN add cream? Or would i dilute w cream?
When I brew coffee, I weigh it. How much coffee in weight (oz or grams) did you use? I find that depending on the coffee beans you use, it can vary significantly!
cavenoid
3 years ago
Thanks! This also solves the problem of coffee grounds going stale on the counter or in the freezer. Once brewed, the concentrate keeps just fine! !!
Wow, looks like I am going to try this over the summer! Thanks for sharing!
