GIANT Bubble Blower
294,457
270
78
had enough of those puny little bubbles you can blow with those store bought sticks...
well now ill show you how to easily make bubbles 2m in diameter easily and BIGGER! for under $3
Step 1: MATERIALS
for this instructable you will need
2 peices of dowling/ bamboo ( i used 1m peices)
1 spool of string (any string will do as long as it is slightly absorbent and not woolen)
1 roll of tape (i used gaffa tape)
Step 2: First String
you will need a piece of string just larger than the peice of dowling you are using.
tie one end of this string to a peice of dowling and the other end to the other peice of dowling approximatley 1cm from the top.
Step 3: Tying String #2
you will need a peice of string just larger than the length of you forearm.
tie one end of the string to the bottom of forst peice of dowling and the other end to the other peice of dowling both approx 2cm from the base.
Step 4: Tying String #3
for this you will need a peice of string just larger than 2 lengths of one of the poles you are using.
tie one end of the string about 1cm away from the pole onto the first peice of string you tied. tie the other end the same way.
Step 5: Bubble Mix
now you have made your bubble blower, you now have to make you bubble mix. i have found using a dish washing liquid in a 3:1 ration of water:liquid produces the best bubbles.
however if you are willing to go the extra mile for you bubble you can use 1.5 gallons of boiling water dissolved in, half a teaspoon of J-lube, a small tube (4.5 ounces) of surgical lube and a 1/4 cup of glycerine (99.5% pure), 16 ounces of dishwasher liquid, 1/2 a cup of manual dishwashing liquid.
see its hard but if you are willing to spend the money on them it should give you self-healing bubbles which means you can blow smaller bubbles inside the big one, and they are stronger.
Step 6: ENJOY!
now with a little bit of practice you will be blowing giant bubbles.
i would advise using the tape to secure down the four peices of string on your dowling so they dont come off. and also the string on the botom of the dowling is merly for practice purposes you can take it off in the future i simply had mine there to stop me from making the top rope taught and popping the bubbles.
to form the membrane to start blowing you bubbles simply pull the sticks appart so that a small triangle is formed in the middle of it and then widne as you bubble blows.
the best way to do it is to either walk with it, or let the wind do it for you. remember to pull the string out so there is no hole in the loop to start with then slowly open the loop to make big bubbles. Also to detach the bubble simple close the loop.
NOTE: the string on the bottom is only for training reasons, it is not nescesary to the design its just there to stop you pulling the sticks to far appart.
Added information from other big bubble enthusiasts;
Chr1st1an:
The string should be something that absorbs a good deal of solution, I tend to use upholstery edging. Also I have found that a weight in the center of the hanging material provides easier use when there is a breeze and that a couple of knots about 2 inches below the attach points to the dowels allow for easier separation once the bubble has formed and you close it.
    • Fat Challenge
      Fat Challenge
    • Woodworking Contest
      Woodworking Contest
    • Trash to Treasure
      Trash to Treasure
    78 Discussions
    hieuwey
    6 years ago on Step 5
    I have a question...
    when you say "16 ounces of dishwasher liquid, 1/2 a cup of manual dishwashing liquid", what is the difference?
    can you clarify what is dishwasher liquid and manual dishwashing liquid?
    Thanks!!
    poknik
    the kids are waiting...
    wmkcross
    6 years ago on Introduction
    here is one of many youtube videos
    http://www.youtube.com/watch?v=5bjggctu3kw
    renailee
    10 years ago on Introduction
    An easy bubble solution that I have found works well is 10 parts water: 1 part liquid detergent : 0.25 glycerine ( 1 litre of water, 100ml detergent, 25ml glycerine) The bubbles retain their shape with this solution!
    Bubbleguyrenailee
    The 10:1:.25 ( parts water:detergent:glyc) recipe Renaliee suggests is fine for baseball sized bubbles. Maybe a bit bigger on days with high humidity.
    It would never work to make satisfactory bubbles with the set-up described in this instructable.
    Minimum, you need the higher percentage of detergent as described.
    To get the biggest bang our of your bubble efforts, include the polymers suggested.
    10:1:.25 was the standard recipe developed sometime decades ago. We have learned a lot about how to supersize our super performing bubbles since then.
    If someone is going to make a try-string rig like this, they might as well brew-up a solution capable of making bubbles that will rock their world.
    In my opinion.
    llauren
    10 years ago on Step 5
    Hi!
    Would it be possible for anyone to make a quick translation of the bubble recipe into culturally neutral English? What is J-lube (and surgical lube)?
    I'll pitch in by translating the volumes:
    1.5 US gallons = approx 5.7 liter,
    4.5 ounces = 1.33 deciliter,
    16 ounces is just below half a liter (0.47 l),
    1/4 cup is nearly 0.6 deciliter.
    Having kids who spill their bubble solution (don't they all), it would be fun to make their own!
    eulaliaaaa!llauren
    Wow.  The metric system and all that what-not is very confusing.  I mean,  four and a half ounces is 1.33 deciwhatameanerif?  How would you measure that!?!  In America, we have straight numbers instead of all that 6.53147 and the 4.578km and 15.1234567890 and the old 7.55 and all that.
    dobos111eulaliaaaa!
    are you kidding? the metric system is SO MUCH MORE LOGICAL. 1 kilometer = 1000 meters 1 meter = 10 decimeters 1 decimeter = 100 millimeters 1 meter = 1000 millimeters water boils at 100 degrees celsius and freezes at 0 degrees celsius. They all relate to each other perfectly numerically and by the actual words NOW THE US SYSTEM 1 mile = 5280 feet 1 yard = 3 feet 12" = 1 foot then you start talking fractions for partial inches? 3/32" is just a little bigger than1/16" - you'd never know by looking at those numbers. now we talk about ounces, and cups, and gallons which dont convert logically either Water boils at 212 degrees fahrenheit and freezes at 32 degrees? Where is the logic with that?
    laxapmerijnvw
    I'm a metric system lover!
    The metric system has more beauty and practicality, whereas the imperial system has more history...
    But in the end, for the daily life, it's a matter of habit.
    MediaMarclaxap
    Reply 8 years ago on Step 5
    Fully agree with Dobos111 And I prefer to refer to both systems as the Imperial and the Rebel system.. =D
    greasyjesusMediaMarc
    i fully agree that the metric system is more practical, but I have no intrest in using it. i learned the imperial system, and it works fine. i have no problems working with metric, so its good where it is. the only purpose to having both is so we can argue their faults on the internet. which I am also okay with....
    GameNoxgreasyjesus
    Anything metric makes so much sense i mean 32 degress farenheight at the water frezzing point?
    sneakyparasolmerijnvw
    fully agree! also america is the only place in the world where imperial is still used. what's practical about that?
