Gearbox Lamp
27,406
281
33
About: I love making stuff, I love Instructables, I love tools, I love machines, and I love materials. But most of all I love Arnie.
Check out the video to see how the gears move to turn the light on/off and also acts as the dimmer.
This was a result of a need for me to create an example GCSE Engineering project for my students and I really wanted to make something from scrap engine parts I bought of ebay.......Somehow I ended up with this, I am soooooooooooooo pleased with the outcome I thought I would share the joy :)
The project took me 4 days and cost less than £20......... best 20quid I ever spent :)    I also like the fact that most of the main components are reused (gears, bearings, acrylic etc...) this keeps the cost down and encourages creative thinking.
I bought the following
Gears + crank + conrods + bearings - £2
Dimmer switch - £4
Braided flexi hose - £2
Transformer + bulb + holder £4
Bolts £3
Freebies
Acrylic - from a storage unit
Aluminium - offcuts donated to my school from local engineering company
Steel tube - offcuts from our scrap bin
Old speaker wire
Old 240v plug and double insulated wire
The more components you can harvest the better, look in junk yards / boot sales / garage sales / or even look for instructables treasure in your own garage......you will be surprised what you can find, we all keep stuff as one day it might be useful.....guess what this is that day :)
Please note this instructable's dimensions and working drawings are based around the gear box I used (from an FJ 1200) its likely you will have different components and will have to tweak the dims/drawings/design to fit your materials.
Supplies:
Step 1: Important Components
You need the following components:
Gears
Bearings
Con-rods
Dimmer switch
Braided flexi-hose
12v Halogen transformer
MR16 bulb holder
MR16 12v Halogen bulb 20w
240v plug + double insulated mains cable
Old wire....speaker wire is ideal
Terminal block
Selection of materials to make the base etc....
Step 2: Degrease Engine Parts
Degrease the engine components using a solvent based degreasing product, a paint brush is good for getting into the difficult areas.
Step 3: Aluminium Cylinder - Measure and Mark
  • Cut a strip of aluminium 330mm  x  50mm
  • Mark out the measurements as per the working drawing.
  • Centre punch the hole positions
  • Drill all holes at Ø4.5mm
Step 4: Aluminium Cylinder - Rolling
  • Roll the aluminium until the ends touch
  • You will always be left with flat ends where the rollers are unable to reach, use a leather mallet and a Ø2" steel bar to tap the ends into shape.
  • Use a long strip of abrasive paper (150grit) to sand the sides to achieve a 'brushed look'
Step 5: Aluminium Cylinder - Joining Rods
  • Cut three Ø15 x 52mm long aluminium rods
  • Face off one side, the when facing the other side ensure the part measures 50mm long (same height as the aluminium strip you just rolled.
  • Centre drill all 6 ends
  • Drill all 6 ends Ø4.2mm x 30mm deep (this will create a hole all the way through the component.
  • Tap both ends at M5
Step 6: Aluminium Cylinder - Joining Rods
  • Measure and mark the holes on the side
  • support the work in a V block
  • Centre punch the two hole positions
  • Drill a Ø3.2mm hole half way through the rod
  • Tap holes at M4
Step 7: Aluminium Cylinder - Joining Rods
  • Sand the three rods
  • Assemble the three rods to the strip using M4 bolts
  • The joint needs to overlap on the strip and the bolts go through both holes
Step 8: Corner Joints - Feet
  • Using Ø25mm aluminium centre drill on a lathe
  • drill Ø8.5mm 40mm deep
  • Use a parting off tool to part off at10mm
  • repeat the drilling and parting off until you have 4 components.
  • Tap the holes at M10
  • De burr the holes in a vice
  • Cut 90mm of M10 threaded rod
  • File the rough sawn edge
  • Assemble
Step 9: Corner Joints - Middle Spacer
  • Use Ø25mm aluminium
  • Face one end
  • Centre drill
  • Drill Ø10mm 60mm deep
  • Sand the sides
  • Part off at exactly 50mm
  • Repeat until you have 4 identical components
Step 10: Corner Joints - Top Cap
  • Face off
  • Chamfer @ 45°
  • Part off at 20mm
  • Turn the component around and centre drill
  • Drill Ø8.5mm x 15mm deep
  • Tap a M10 thread in a metal vice
Step 11: Gear Shaft Clamp - Feet & Caps
  • Using Ø12mm aluminium rod
  • Face off
  • Centre drill
  • Drill Ø6mm x 20mm deep
  • Countersink to accept a M6 countersink head
  • Chamfer the edge @ 45°
  • Part off at 10mm
  • Repeat until you have 6 components (3 feet & 3 caps)
Step 12: Gear Shaft Clamp - Middle Spacer
  • Use Ø12mm aluminium rod
  • Face off
  • Centre drill
  • Drill Ø5mm x 30mm deep
  • Part off at 50mm
  • Turn component around and repeat drilling on other side
  • Repeat until you have three components
  • Tap both sides of each rod at M6
Step 13: Base - Template
I laser cut my base from 9mm thick acrylic, you could use the following alternatives.
  • 3mm acrylic - It might be worth doubling up the layers to give it a thicker look, could be cut using laser or by hand
  • Hard Wood or Ply wood - Could be cut on a CNC router or by hand.
  • Aluminium / steel / brass sheet - This would be cool but very time consuming to cut by hand, a water jet would be useful :)
The first thing you must do is create a template to gauge the size of the base and more importantly the centre positions of the gears.
When you are happy create a 2D CAD file based on the dimensions of the template.
Step 14: Base - Cutting & Drilling
  • Cut out the base
  • Assemble all the components you have so far, carefully position the aluminium cylinder so it is centred around the dimmer switch hole
  • Mark where the three holes need to be drilled
  • Drill three holes at Ø5mm
  • Countersink the holes to accept the head of a M5 countersunk bolt
  • Screw in the three bolts and then mark the three holes underneath and repeat the drilling / countersinking so both top and bottom halves of the base are attached to the cylinder.
Step 15: Fitting Idle Gear
This is the gear that goes between the dimmer gear and the main gear shaft.
The bearing was slightly too small to fit into the gear so I laser cut a spacer ring to fit them together
It is all attached to the base with Ø25mm aluminium drilled and tapped to take a M6 countersunk bolt.
Step 16: Fitting Dimmer Gear
  • Take the dimmer switch apart to harvest the electrical hardware and the white dial, get rid of the white square faceplate
  • Accurately measure the diameter of the dial and drill the appropriate size hole in Ø25mm aluminium
  • The hole needs to be a friction fit (tight fitting)
  • Assemble the rod, bearing and gear and check it all turns, dont worry about the dimmer mechanism yet i will cover the wiring of that later
Step 17: Fitting Gear Shaft
  • Use the clamps you made earlier and assemble components together
  • The gear shaft has a spring clip, this sticks out and is what the clamps hold onto
Step 18: Lamp Arm Shaft
I found some steel tube that fitted tightly on top of the gear shaft, I wanted a curve in it but didn't have a pipe bender so i did the following.
  • Cut rod to desired length
  • At the point of the bend make a series of cuts 10mm apart, they need to be most of the way through the rod.
  • File off any sharp edges left by cutting
  • To make life easier heat the back edge until bright red then quickly move to a vice and hammer so the gaps collapse and the tube bends
  • Its likely you will need to repeat the heating / bending process a few times.
After making it i decided it was a bit too long so I chopped some off.
Step 19: Lamp Arm
  • Bolt the con-rods together in the arrangement shown in the photo
  • The Flexi-hose just sits in the shaft and is threaded into the top of the light assembly
  • I also machined a cap to hid the top of the bulb and act as a support for the bulb holder.
The cross sectional drawing should be self explanatory on how to create the lamp arm.
Step 20: Sanding the Base
Because the acrylic was used it had a lot of surface scratches so I sanded it with 150grit paper to remove the scratches and give a frosted look
To keep things neat you must always sand in the same direction.
Step 21: Wiring Transformer & Dimmer
NOTE: MAINS VOLTAGE CAN KILL YOU OR IF YOUR WIRING IS DODGY, SOMEONE ELSE....... YOU MUST ONLY TRY WIRING PLUGS & DIMMERS IF YOU ARE QUALIFIED TO DO SO!
The wiring schematic is shown in the images.
Ensure the dimmer wires go though the base before you attach them.
Step 22: Final Assembly
Assemble the lamp in the order shown.
Instructables contest info asks what I would do with a shopbot..........our CNC router at school is on its last legs, we cannot afford a replacement...... this would be ideal :)
It would be used on projects across all year groups including GCSE and A-Level.
Any questions about this build...please ask
Jonny
Make It Glow Challenge
Runner Up in the
    • IoT Challenge
      IoT Challenge
    • Party Challenge
      Party Challenge
    33 Discussions
    pjames9
    3 years ago
    I find that this project I do not have the tools or the skill. I know most of the fun is unfair building the item and being proud that it was your own project but I was wondering if you would consider selling one?
    Moxlonibus
    7 years ago on Introduction
    That is too cool. I recently cleaned the emissions on our 1986 Mazda Pick Up and found some cool parts on the system. Might look into building this from some of the old parts.
    jonnyd55Moxlonibus
    Good idea, old bits from vehicles can look cool, i have a pair of beautiful cast iron axel jacks from 1942, im taking my time to decide what to do with them as they are from the 2nd world war and need to be treated with maximum Instructables respect....... I would love to see what you end up making, dont be afraid to ask if you need any help / advice on design or fabrication :) ....... jonny
    scotchcollegejonnyd55
    Reply 3 years ago on Introduction
    Duddy55 I have no lathe either and I live on a iceberg and need a light to hunt seals at night could you please shed a few tears for me and send me one. I will always be your friend with such a big chesty bond "wife beater" on. Bit of a worry a teacher of your standing having a smoke coming out of your gob!
    duddy I like to watch what you are doing. long break since 2011. Andy says that you have gone soft and you should read your emails
    HoyAus
    buck2217
    This is definitely going into the sometime very soon pile, Awesome love it.
    makeosaurus
    4 years ago
    Did you ever finish the lathe-free version because this looks amazing
    mganpate
    6 years ago on Introduction
    its very aswoom work kindly share the pdf on mahesh.gan.143@gmail.com
    amorarun
    I liked the project so much but anyway I'm not at home so no plans for building one yet.
    Regarding your lathe free version, I'd love to see LED lighting integrated to it :)
    what's not to like about it?? :D
    I think it's AWESOME!!!
    my GF will think I'm nuts but who cares? she's not the first & won't be the last.... :)
    jonnyd55SIRJAMES09
    Dont worry bout other people, my family & wife have always thought i was a bit strange :)
    Its easier to make than it looks, do you have access to a lathe?
    SIRJAMES09jonnyd55
    No Sir I do not....and I know of no place or person that has one that would lathe any parts for me... :(
    Drills, saws, etc., I either have or know a place that will do the work for me...but a lathe I do not have access to....i do not even know how to work a lathe.
    Always wanted one, but money has always been the issue.
    jonnyd55SIRJAMES09
    Hmm, you will struggle to make the above design without one :( your story has upset me to such a level I am going to create a similar lamp.....lathe free version! It will only require a pillar drill, mallet, saws and a few other basic hand tools......but of course it will be done in true jonnyd55 style ............ QUALITY, THAT WORKS WELL. watch this space......its going to take a month or two to make. Please feel free to share any ideas you have.
    Jonny
    SIRJAMES09
    OMG!!! that is just too cool!!!!!!
    I just have to try & build that....
    I think it's a wee bit out of my league, but I want to give it a go ..
    Jonny, you're amazing!!
    action pig
    Hey, where did you pull those gears from? Very nice project, by the way, I'd love to try it myself.
