German Apple Pancakes
52,032
754
45
For as long as I can remember, my mom has made the best German Apple Pancakes. The family recipe uses eggs, apples, and several other ingredients to create a breakfast treat that is rich in protein, fiber, and flavor that will keep your breakfast company clamoring for more. These pancakes are also perfect for the fall, using fall-seasonal spices like cinnamon to create a distinct flavor matched only by the season. When making German Apple Pancakes, it is important to have a fundamental understanding of basic cooking techniques. The procedures are not overly complex, however the quality of the final product and the safety of the individual performing the procedure require the employment of both thoroughness (shortcuts will yield a sloppy pancake) and caution. Make sure you own a good pair of oven mitts prior to making these pancakes, as third-degree burns can occur during removal from the oven. Preparation and baking time take a total of 60-75 minutes. Ingredients should not exceed $10. This recipe yields four servings.
Ingredients:
• 2 apples
• 4 eggs
• ½ cup all-purpose flour
• 1 tablespoon sugar
• ½ teaspoon baking powder
• 1 pinch salt
• 1 cup milk
• 1 teaspoon vanilla extract
• 2 tablespoons butter
• ½ teaspoon cinnamon
• ½ cup white sugar
• ¼ cup butter
Additional supplies:
• Oven
• Oven mitts
• 10-inch oven-proof skillet
• Whisk
• Knife
• Two Mixing bowls
• Cutting board
Step 1: Preheat Oven
Preheat the oven to 425 degrees Fahrenheit
Step 2: Prepare Apples
Use a knife to core and peel the apples. Then, cut into thin (quarter to half-inch thick) slices. Handle knife with extreme caution.
Step 3: Add Eggs
Crack four eggs in a mixing bowl and use a whisk to beat the eggs.
Step 4: Add Flour
Then add 1/2 cup flour, continuing to mix with the whisk.
Step 5: Add Baking Powder
Add 1/2 teaspoon baking powder to bowl and mix well.
Step 6: Add Sugar
Add one tablespoon sugar to the mixture and combine thoroughly.
Step 7: Add Salt
Add a pinch of salt and continue to mix
Step 8: Add Milk
Slowly add one cup milk to the mixture while maintaining a steady stir.
Step 9: Add Vanilla
Add one teaspoon vanilla extract and mix thoroughly.
Step 10: Add Butter
Melt two tablespoons butter and add to mixture. Stir until completely mixed, then set the mixture aside.
Step 11: Cinnamon-Sugar Mixture
Combine 1/2 teaspoon cinnamon with 1/2 cup white sugar in a separate bowl.
Step 12: Melt Butter in Skillet
Add ¼ cup butter to the oven proof skillet and melt on stovetop over medium heat. Spread butter around pan thoroughly.
Step 13: Add Cinnamon-Sugar Mixture to Skillet
Then add the cinnamon and sugar mixture to the skillet with the melted butter, giving the skillet an even coat.
Step 14: Brown the Apples
Spread out the apples evenly in the pan to begin browning. Keep stovetop on medium heat. The browning process should cause a slight bubbling of the cinnamon, sugar, and butter mixture, and the browning is complete once the apples are coated with the mixture attaining a light brown color. Do not leave the apples over medium heat for longer than five minutes.
(Make sure you get as many of the apple slices in the pan as possible: it may appear that there are too many, however the heat will compress the apples so the end result will be less apple-filled than it appears prior to baking.)
Step 15: Add Batter to Skillet
Once the apples have browned, pour the batter from the mixing bowl over the top of the apples in the skillet.
Step 16: Bake for 20 Minutes at 425°F
Transfer skillet to the oven to begin baking. Use oven mitts and extreme caution when dealing with the oven at this heat. Turn on oven light to monitor the pancake’s progress. Bake for 20 minutes at 425 degrees Fahrenheit. The pancake should start to brown around the edges of the skillet and the cinnamon will gently brown the apples.
Step 17: Remove and Cool
Turn off the oven and let the pancake sit in the oven for 10-15 minutes. REMOVE WITH EXTREME CAUTION. Remove with oven mitts and set on counter top to cool for additional 3-5 minutes. The center of the pancake should be soft and slightly gooey, while the edges should be slightly browned. Enjoy!
Baking Contest
First Prize in the
Baking Contest
2 People Made This Project!
  • Jewelry Challenge
    Jewelry Challenge
  • Pie Contest
    Pie Contest
  • Fat Challenge
    Fat Challenge
45 Discussions
jtalvyklj123
Reply 2 years ago
I used Honeycrisp and it was amazing!
Will_Stansellklj123
Reply 5 years ago on Introduction
I believe I used Granny Smith apples for the photos. I have used all sorts of different apples in the past for this recipe, so you should pick an apple that suits your tastes. If you want a tart or sour taste to balance the sweetness of the cinnamon and sugar, I would recommend a Gravenstein or Granny Smith apple, but if you are looking for a sweeter pancake I would try Gala, McIntosh, or Red Delicious apples.
Mielameri
4 years ago
I've made this about a million times since this recipe was posted...only just got around to taking a picture! SO GOOD
14, 8:59 PM.jpg
b-cat
4 years ago
I made this the other night is as good as everyone says! Will be making this a lot more I think.
Sparkfist
4 years ago
Just made it! used a cast iron pan so didn't adjust the heat. Still tasted good.
MayerhoferB
4 years ago on Introduction
I made it!
lovely texture and taste - it got gobbled away before I could take a pic :(
kurnous34
4 years ago
will definately be trying this next weekend. Are these also called dutch babies?
nstancil
4 years ago
wow your last name is stansell my is stancil, what a weird coincidence.
Will for sure try this. Appreciate your wonderful photos & instructions, + meticulous attention to safety! Thank you.
Echinda21
This was amazing i am so glad that i found it!
but i think that apple pie is a better name for it (it was better than any apple pie that i have ever had)
jtalvy
I made this today and it turned out great! I did a lil tweaking to work for my needs though... I used a pyrex dish and heated it in the oven and then put some butter in it and then transferred the apples to it and then the batter. I also used a little nutmeg and 3/4 cup flour. I tried to upload a pic here but it wouldn't work. I might make my version an instructable at some point.
Will_Stanselljtalvy
I've seen it done with nutmeg and flour before, but I can't say I have tried it that way myself. Glad you liked it!
now does the bottom actually cook or not?
have made similar things before and it was just like eating mush in the middle; I want it to actually have body
