Gesture Control Car Using Mpu6050 and Arduino
9,821
9
37
About: An engineering student
here is a hand controller gesture control car, made by using mpu6050 and arduino. I use rf module for wireless connection.
Supplies:
Step 1: THINGS REQUIRED :
•1.arduino uno
•2.micro Arduino
•3.rf module(transmitter and receiver)
•3.mpu6050(accelomitter)
•4.motor driver
•5.2 dc motor
•6.robotics chassis
•7. Arduino cable
•8.one hand glapse
•9. motor driver
•10. LiPo Battery
•11. 9V battery
12.USB cable
Step 2: Connection:-
•1.connection for rf transmitter:-
•GND = GND
•DATA = 12
•VCC = 5V
•2.connection for mpu6050:-
•VCC = 3.3/5v
•GND = GND
•SCL = A3
•SDA = A2
•INT = 7
•mpu6050 need 3.5V voltage.but we can give it 5V voltage.i give here 3.5V voltage to mpu6050 because in micro arduino there
•are two voltage pin first is 5V and another one is 3.3V.rf reciever have to need 5V.so i use 5V pin for rf transmitter.and
•mpu6050 can run 3.5V.
•3.connection for rf receiver:-
•GND = GND
•DATA = 12
•VCC = 5V
•4.connection for motor driver:-
•motor one:-
•int enA = 11
•int in1 = 7
•int in2 = 6
•motor two:-
•int enB = 3
•int in3 = 5
•int in4 = 4
Step 3: Working Principal:-
1.mpu6050:-
MPU-6050 Triple Axis Accelerometer and Gyro Breakout Board.it read three angles.we can give them name X, Y, and Z, here we
use here only two angles. here we use Y and Z.Y for forward and Z for left, right.
this part of code read the angle.
•mpu-6050
reads the angles in radian, this "* 180/M_PI" make it in degree.
Step 4: ​•Rf Transmitter:-
•Rf
transmitter:-
Mpu6050 read the angles. then I make one “if” loop and make a condition.in then make two buffer.one buffer sends condition for forward. and in the second one, I send the angle, for control the speed by the angle. this part of code sends the message. And I map the angle.
Step 5: RF RECEIVER:-
•Rf receiver:-
the receiver receives the message in the buffer. Again I make a condition on the first buffer for forward. And the second one I use for control the speed. And I again map it. This part of the code is doing this work. and for the speed control, I use the second buffer and, the angles mapped (0,9), I map speed in (50,255). you can see all things in code.
Step 6: Let's Run the Car:-
  • now the time has come to run the robot.make sure that all connection is correct. now connect your glapse's micro arduino to your computer. open the serial monitor, now you can see angles reading.now send any input from the transmitter to the receiver. now your robot is ready for a run.
Step 7:
if you fill difficulty in those codes. you can use these code. I make these because I fill you will difficulty fill in the transmitter code. so I make these easy code. and you won't need to follow 6th step. just connect the power the transmitter's Arduino and your robot is in your control.
    • Classroom Science Contest
    • Arduino Contest 2019
    37 Discussions
    YazeedH
    6 months ago
    Would you please send by email Transmitter & reciever codes with Ada fruit motor shield instead of Motor Driver & 433 mHz RF To
    Hassouna@yazeed@yahoo.com
    YazeedHYazeedH
    Reply 4 weeks ago
    MPU6050 not working
    I checked wiring ,power and everything
    A.k.sYazeedH
    Reply 5 months ago
    I think you just have to check the pins meaning in ada fruit motor shield... And connect them with Arduino....
    SrinathS17
    Question 2 months ago on Introduction
    Why cant we directly connect the MPU6050 to RF transmitter part?
    AlvanR
    5 months ago
    Can i use 9v battery to power up the motor driver instead of LiPo?
    A.k.sAlvanR
    Reply 5 months ago
    Yupe, you can use.
    HossainA2
    5 months ago
    I'm using uno with motornshield that control 4 motors and receiver in car
    and nano with mpu6050 with transmitter.
    what changes should I make in the code?
    can you help me with the code? I will be very grateful.Thanks in advance :)
    A.k.sHossainA2
    Reply 5 months ago
    I don't think so that you have make any changes in code.... because motorshield and motor drive work in same way. And nano and micro also..
    HossainA2A.k.s
    Reply 5 months ago
    JibanP1
    7 months ago
    hey can you provide me the circuit diagram of RF434 Mhz transmitter receiver with arduino
    mail id is jjp04012000@gmail.com
    A.k.strana21
    Answer 8 months ago
    If you can control led than you also control motor. What type of problem actually you are facing?
    trana21A.k.s
    Reply 8 months ago
    i fixed it. it must same ground ( l298 and Uno)
    anht60
    Question 8 months ago
    Hi. i want a code to all. please help me. thank you.
    A.k.sanht60
    Answer 8 months ago
    What type of you actually need?
    anht60A.k.s
    Reply 8 months ago
    transmiter and reciever. when i load code motion_transmitter.ino or MPU6050_DMP6_gesture_MAIN , MPU6050 always connect failse. I don't understand.
    A.k.sanht60
    Reply 8 months ago
    First of all Chack your connection. And then chack your jumpers wires. If they all are ok. Than chack your mpu6050.
    anht60A.k.s
    Reply 8 months ago
    everything is ok. Can you sent for me code with Uno, Mpu6050 and 433 transfer.
