Giant Inflatable Robot
19,012
63
19
Otherlab has been doing a lot of inflatable fabrication lately, and we thought it was about time to write an Instructable about it.  What better subject to inflatable-ize than the Instructables robot itself?  Here's the high level view of the fabrication process.
Step 1: Design 3D Model and Decompose Into Panels
For us, the first step to constructing an inflatable is designing the 3D model using a CAD program like AutoCAD or Solidworks.  Using artistic license, we added a third leg to make the robot more stable.  Further, inflatable shapes tend towards a sphere when inflated, so some allowance must be made.  For example, to prevent the legs from splaying we pointed them inwards.
With the model in hand, we use Rhino (available as a Work In Progress download for Mac) to unroll "developable" surfaces which lie flat and can be sewn together into the original model.
Next, we need to add 10 mm seam allowances and arrange the parts onto printable pages.  Using Illustrator or Inkscape, we can take the DXF output of Rhino and use 'Path Offset' to add seam allowance.  The panels with allowances can be arranged manually to fit on printable pages.  This method works well but can be really tedious with many panels.
As an experiment, we read the output of Rhino and programmatically added seam allowances and nested the parts on paper stock.
Step 2: Print Panels and Cut Them Out
Now we print out the panels with seam allowances.  We used a Roland Versacam with 48" bed, but any printer will do if you tile the panels across multiple pages.  After printing, the tiled pages can be cut and taped together.
Once the panels are printed, we need to cut the shapes out of the fabric.  For small parts, you can cut the paper and fabric in one step, but for larger ones it is often easier to cut the paper first.  Use weights to ensure the paper pattern doesn't slip around on the fabric while cutting.
Step 3: Sew Panels Together
Using the patterns as guides, identify which panels are connected by which seams.  For most of the robot, we use a plain seam sewn flat.   For large diameter sections (like the belly) the stress on the fabric is higher, and care must be taken to maximize seam strength.  For smaller appendages, strength is not as critical and simpler, easier seams can be used.
To stuff and service the bladder, we need access to the internal cavity.  To this end, we put in a zip down the back side of the robot.  This also provides access for a human driver...
Finally, to access the inflation valve, we reinforced a small hole just below the zip.  For historical reasons, the valve is invariably placed in the standardized position.
Step 4: Stuff Small Cavities With Foam
Some cavities, like the fingers, eyes, antennae, and buttons, are too small to be conveniently inflated by the internal bladder.  For these parts, we just stuff foam inside to give them support, simplifying the bladder construction.
Step 5: Make the Bladder
The fabric envelope is not airtight, so we need an internal bladder to keep the robot inflated.  Like a bouncy castle, though, a continuous blower could keep the robot inflated without a bladder.  This can also be used to quickly test the inflated shape before making a bladder.
The polyurethane bladder is oversized and stretchy so the fabric envelope takes all the force and hence dictates the shape of the robot.  Meanwhile, the internal bladder stays bunched up inside, only providing the airtight seal.  This system is like the tube and tire of your bicycle wheel.   Generally, the bladder should be oversized enough to avoid stretching.
Because of this, the shape of the bladder can be greatly simplified.  We make a simple 2D approximation of the robot that can be easily constructed by heat bonding.  After cutting the panels of polyurethane, we use the impulse sealer to assemble each half before joining them around the edges into a large inflatable bag.
After the shape is done we still must add a nozzle to pump air in and out.  Stick-on one-way valves make this easy and can be bought from kite builders' supply shops like this one.
Finally, to keep the bladder appropriately distributed inside the fabric envelope, we need attachment points at each extremity.  We use the impulse sealer again, bonding small loops of polyurethane at the ends of the arms, legs, and head.
Step 6: Stuff and Inflate
Everything is done now, we just need to stuff the bladder and inflate it.  Starting with the extremities, tie the loops on the bladder onto the envelope.  Push the nozzle through the inflation hole and distribute the bladder evenly around the inside of the envelope.  Talcum powder  helps the bladder slide into position, and sit better.  Start pumping air into the bladder, all the while massaging the robot to eliminate spots where the bladder doesn't properly fill out the fabric envelope.  If all goes well, you'll have a robot punching bag!
    • IoT Challenge
      IoT Challenge
    • Party Challenge
      Party Challenge
    • Fandom Contest
      Fandom Contest
    19 Discussions
    Bert_VD
    1 year ago
    can you tell more about sealing the plastic for the bladder? it's hard to find any info on sealing plastic that is not about tiny plastic bags.
    WillyL11
    1 year ago
    I'm a little late to the party but wanting to jump in, thank you for sharing these tips.
    Can I use another type of
    Polyurethane Film TPU - I'm having trouble sourcing it and was wondering about other materials that would work that are more common. Also, the sealing of the bladder- is this done with a soldering iron?
    thanks again!
    vanduzco
    5 years ago on Introduction
    Could you please elaborate more about the flattening process in rhino? Are you using any especial plug in?
    superpants
    7 years ago on Introduction
    Have you got any recommendations on what type of polyurethane to use for the bladder or where to obtain it?
    Thanks
    Mike
    otherlabsuperpants
    Hi Mike, Thermoplastic polyurethane (TPU) is tough to get your hands on. We used 6 mil (.006") thickness, but depending on your use, you can go up to 20 mil. Macmaster sells very small quantities. You could try following up with one of the manufacturers listed here. We obtained our roll by talking to a major distributor and buying from one of their industrial customers.
    rfrayneotherlab
    Reply 6 years ago on Introduction
    I'm working on another project that also requires TPU that's 6 mils thick. Macmaster only sells 15 mils and up.
    I heard that the bladder inside a football is made of TPU. Any other ideas on where I could scavenge for TPU?
    Thanks, Ryan
    PS- Your info on TPU has already gotten me further than hours of googling, so thanks a million!!
    bob shea
    Is there a less expensive 3D program available? Could you create this in sketch up if need be?
    Probably a dumb question, but I am new to 3D.
    otherlabHonus
    We used 18 oz. for heavy-duty parts and 10 oz. for intricate parts.  It's a PVC-coated polyester as used for tarps.  We bought it here.
    burerexotherlab
    excellent work, can facilitate the filing ed rhino, 3d separation as illustrated in one of the images that you see all the parts for the esamblaje and the file should be printed on plotter to cut and make the templates, I intereza much your idea, you just have to be supplemented to provide a better use, it occurs to me, placing resistant bases and to include real wheels on the feet to include at least two engines to do remote shooting, using all the lighter elements possible to avoid compromising the stability or decrease the size of the robot additionally occurs to me to write a space in the belly, kind transparent window where you can place a laptop or mini laptop according to the firmness you may have, I say this to show some messages or add sound to the robot, (your idea of cushions or airbags as muscle is also very good, would have to see that maybe the chance for deploying a small cylinder of compressed air inside the doll) so I imagine it spinning within a shopping mall as part of an energy-saving advertising campaign, please send me information by mail or Esponda here, thanks
    Edgar
    I wish I had a Dollar for every Inflatable Santa this Instructable will sprout, this Christmas, that's a huge great idea!
    ...And did I mention, Videos, please?
    Edgar
    Kiteman beat me to it, but stil...
    Video, Video!
    TheDodgyLodger
    7 years ago on Step 5
    I actually spent part of my senior sculpture project in college working on inflatables and I have to say, not all fabric is built the same. In fact, very very few are air tight, even if they "feel" like a bouncy castle or those inflatable Christmas Santas. The bladder idea is genius because I just covered my fabrics on the inside with sealant and didn't always get the best results.
