Good Luck Charm Polymer Clay Owl Pendant
1,751
62
15
Owl has been a symbolic animal in many cultures, native indians, greek and egyptian too.
the native indians wore owl feathers and signified as an animal totem( that's what I read....don't want to debate on that )
It symbolizes intelligence, intuition, protection and wisdom. It has thus gained popularity as a piece of jewelry.
I have made an Owl pendant for my daughter of polymer clay as a symbol of wisdom , protection and power which she will need in the high school.
Supplies:
Step 1: Materials and Tools.
Materials for the pendant project.
polymer clay in brown and champagne(20gm each), some leftover pieces of yellow
jewellry wire
pliers
exacto cutter
toothpick or needle instrument
roller
smooth working surface.
oven to harden the clay.
Optional: golden fabric paint
polymer clay varnish
Step 2: Getting Started
draw a rough sketch of what you want your pendant to look like.
Chalk out the exact size.
take a lump of light clay and roll it out between your palms - of the size of the body.
Slightly flatten it with your fingers and pinch at the lower 1/3 to make a "V".
I know it looks almost like a fish at this point.
Step 3: Making Ombre Wings
roll out small lumps of brown, yellow and white clay into rolls.
Place them parallel to each other in an ascending shade order.
roll out lengthwise.
roll back into a log.
repeat this process till the shades have merged into each other to give a beautiful ombre.
Step 4: Making the Tail.
flatten the lower 1/3 of the body
cut out a triangle from the ombre sheet you just made and blend with this tail
With the cutter make vertical lines and cuts into the last end potion.
Round off the slits with a toothpick.
With the toothpick make vertical ridges on each section of the tail followed by "V" markings to resemble feathers.
Step 5: Body
with he toothpick point make markings in the body at regular intervals.
Mark an apple shape for the face.
roll out a very thin tube of brown and white polymer clay apply to the marked apple shape
Holding the point of the toothpick with a gentle pressure pull out the polymer tunes to get small vertical indentations.
make a small v shaped beak and press it firmly in place.
Step 6: Wings
cut 2 pieces of wire to the span of the wings.
push the wires parallel thru the body of the owl
roll up the ends of the upper wire to make little loops.
the lower wire bend it slightly up to overlap the upper wire and then knick the ends over to hold in place.
cut the ombre sheet into 4 wings(use the deign you chalked out earlier.)
place the wings covering the wire wings- 2 in the front 2 at the back.
press firmly
seal the upper and lower open ends by pressing together.
now shape the features of the wings just as you did to the tail.(see pictures)
Step 7: The Beautiful Creature Is Created
I added splashes of golden(fabric paint) to hilight the relief.
make black eyes with a permanent marker, or acrylic paints.
bake the pendant at 110C
remove. allow to cool.
Apply varnish if needed.
Wear it yourself or gift it to your dear ones the beautiful owl jewelry will shower upon wisdom and
Good luck.
  • Fandom Contest
    Fandom Contest
  • Classroom Science Contest
15 Discussions
Sunglowart
2 years ago
Of course you could glue in some dark seed beads for eyes or use tiny bit of black clay for the same.
Actually didn't use a jump rings, instead directly made loops with the wire end which i had used to frame the wings.If you want to use jump rings at the ends attach it into the end loop.
thanks
RavenclawSeeker
2 years ago
Can you use beads for the eyes? And do i just put jump rings at the wing tips to attach to a chain?
Lorddrake
2 years ago
fantastic level of detail. keep up the great work.
fluffy owl
3 years ago
That's beautiful, and I really like the ombre wings idea. The Barn owl is my favourite of all the owls.
SunglowartSunglowart
Reply 3 years ago
Yes it is a barn owl ( sorry for the ?, it was typed as a smiley from the phone shows up as a q mark
ashleyjlongSunglowart
Reply 3 years ago
Ha! I thought the ? meant you hadn't seen labyrinth and that would've needed fixing immediately!
