Hidden Wire Art Light
7,027
58
5
About: I am an author and a maker. My current project is Santa's Shop. I'm working on a science fiction type book--more later. @EngineerRigsby
You've been looking for the "killer application" to justify purchasing a 3D printer? Think about lighting fixtures, the unique ones that can't be found in "big box" stores. A 12 volt LED picture light and invisible wire (metal tape) will cost over $800. A lamp, socket, tape, transformer and plastic to make your own costs less than $30., which leaves $770. to purchase a printer. Install a few of these lights and, well . . .
Supplies:
Step 1:
First things first. Whether you "do it yourself" or "purchase commercially," the invisible wire is actually foil tape and the walls will have to be painted to hide the tape. This tape and its sticky backing:
http://www.amazon.com/gp/product/B00CBPK0FW/ref=oh...
is half the thickness of a sheet of printer paper (after you remove the paper backing). Obtain this tape and place a small piece in an unobtrusive place (or dummy sheet of drywall). Press it down firmly, then paint over it with two coats of paint. This will probably hide it. If not, try again with a smear of spackle before painting.
Step 2:
Now that you are confident that the tape can be hidden, print the lamp parts.
You will need a 12 volt 2.5 watt LED bulb:
http://www.amazon.com/gp/product/B002L2AIIE/ref=oh...
and a long wire socket:
http://www.amazon.com/gp/product/B0036ZA93Y/ref=oh...
Step 3:
Insert the socket wires through the bulb holder.
Step 4:
Drill two pilot holes and secure the socket using 2-56 machine screws.
Step 5:
Push the wires through the arc.
Step 6:
Place the diffuser ring on the bulb (it stays in place using gravity).
Step 7:
Place the bulb assembly on the arc. Secure the swivel point with a 2-56 screw and nut. This allows you to aim the light and tighten it.
Step 8:
Take a servo motor extender cable:
http://www.amazon.com/SODIAL-Remote-Control-Servo-...
and cut it so that about two inches of wire is left extending from the black connector.
Step 9:
Solder the two outside wires to the wires coming through the arc tube. Use heat shrink tubing to cover the connection.
Step 10:
Crimp space lugs on the outside wires of the other piece of connector.
Step 11:
Insert the cable and connector through the hole in the wall box.
Step 12:
Glue (super glue gel) the pieces together or melt them together with a soldering iron.
Step 13:
The fixture is now complete.
Step 14:
Secure the wall bracket to the wall. The screws should enter a stud or a plastic drywall screw insert.
Step 15:
Run two pieces of copper tape from the wall mount to the place where 12 volt power will be available.
Step 16:
Fasten the connector lugs to the tape using screws. I predrilled a starter hole through the tape so that the tape wouldn't bend and twist around the screw.
Step 17:
Press the tape (using your finger or something soft) until it conforms to the wall. Spackle and paint (or just paint) until the tape is hidden.
Unlike my example (done in the garage), I recommend using paint that matches the existing wall, unless you want to repaint the wall.
Step 18:
Attach lugs to the end of the wires from your 12 volt power supply and screw the lugs to the end of the copper tape. The 12 volt power supply should be capable of providing 250 milliamps or more of current.
Step 19:
Cover the power source end with the power box. Secure it using two screws.
Step 20:
Cover the screw holes using the printed caps.
Step 21:
Bring the fixture to the wall bracket. Plug the connector inside the fixture to the connector at the wall bracket. Push the wires inside the fixture, then slide the fixture over the wall bracket.
Apply power and tilt the lamp to suit your taste. Tighten the screw on the bulb holder so that the tilt angle will stay in place.
The foil tape should handle more than two amps, so you can place up to ten (12 volt 2.5 watt) lamps on one run of tape (this will require a 12 volt, 2 amp power supply).
Of course, you can design your own fixture using LED light strips or multiple bulbs--or you can print the fixture in different colors or paint the fixture.
    • Gardening Contest
      Gardening Contest
    • IoT Challenge
      IoT Challenge
    5 Discussions
    schabanow
    4 years ago on Introduction
    How much wattage produce your "12 V LED lamp"? Let me give an answer...
    10 items * 0,17W = 1,7W. Well, we have virtually 2W. It is pretty good wattage (if your "LED lamp" was not quietly "drosseled" to lower wattage' rating by manufacturer Le Yu Yun' & Co).
    Let's measure the consumption current. If we see 55 mA or so then we have a real 1,7W of LED efficiency. Bingo!... But... But LED efficiency requires not less than a hundred square centimeters (100 cm2) of aluminum heatsink per watt, just in order to successfully work out declared by average Chineese manufacturer 50 000 hours of LED' lifespan.
    Has your LED lamp got such a heatsink? I haven't noticed any on your pictures. If not, be ready to buy a new "12V LED lamp" in a couple of years, ecpecially if your LED lamp's activity is supposed to run at higher than average ambient temperatures. o_0
    guidess
    4 years ago
    Brilliant!
    tomatoskins
    4 years ago
    Such detail! I love it!
