High-Range Wireless Power
98,240
875
113
Build a Wireless Power Transmission system that can power a light bulb or charge a phone from up to 2 feet away! This uses a resonant coil system to send magnetic fields from a transmitting coil to a receiving coil.
We used this as a demo during a sermon on Maxwell's Four Great Equations at our church! Check it out at:
https://youtu.be/-rgUhBGO_pY
Supplies:
Step 1: Things You'll Need
  • 18 gauge magnetic wire. Note that you can't use regular wire, you have to use magnetic wire (which has a very thin enamel insulation on it). One example is available on Amazon here:
    http://www.amazon.com/gp/product/B00BJMVK02
  • A 6W (or less) AC/DC 12V Dimmable LED light bulb. One example is here:
    http://www.amazon.com/Original-Warranty-Dimmable-R...
  • 1uF capacitors (not electrolytics, must be non-polarized). You have some choices here. If you build a low power version, you can get 250V 1uF capacitors from Radio Shack or Frys. If you want to build a high power version, you will need to get special 560V capacitors from Digikey.
  • 0.47uF Capacitor (not electrolytics, must be non-polarized)
  • Some kind of power amplifier. We used a 450W HI-FI power amp. You could use anything from that down to a PC speaker. The power more you use, the more range you'll get out of it.
  • Solder & Solder iron. Wire cutters
  • A piece of plywood and some small nails (used for winding coils)
  • Black Electrical tape
  • Measuring tape & ruler
  • Insulated wire
  • Hammer
  • Audio source with variable frequency and amplitude that generate an 8khz sine tone. It's easy to use a PC, Laptop or phone with freely available tone generation software and connect to the headphone jack. I used a Mac with this software:
    https://code.google.com/p/audiotools/downloads/det...
    Or you could use this software for a PC:
    You could also use a function generator if you have one (expensive piece of test equipment)
NTE Capacitor Part List (for the low power version). You can get these parts at Frys.
3 x 1uF 50V capacitor, NTE CML105M50 (to attach to the light bulb and the small coil)
1 x 0.47uF 50V capacitor, NTE CML474M50 (to attach to the light bulb & small coil in parallel with 1uF caps)
1 x 1uF 250V capacitor, NTE MLR105K250 (to attach to the big coil)
Digikey Order (for the high power version)
Attached is a Digikey Part List that you can use for the higher powered version. These capacitors go up to 560V, which allows you to use a ~500W amplifier, and get up almost two feet of range. The attached version only includes the bare minimum parts. As long as you're making a Digikey order, order some extras in case you make a mistake or blow one up (that's particularly true of the TVS protection diodes, which I smoked several times).
Step 2: Make the Coil Winder
In order to wind the coils, you need a frame to wind them around.
On a piece of plywood, you need to use a compass to draw out a precise 20 cm circle and a precise 40 cm circle.
Hammer nails evenly spaced around the circle. For the 20 cm circle, I used around 12 nails and for the 40 cm circle, I used around 16. At one spot in the circle, you'll want to make an entry point that will hold the wire while your beginning the first winding. At that spot, hammer another nail close to one nail, then another a couple inches away.
Step 3: Wind the 40cm Coil With 20 Turns and the 20cm Coil With 15 Turns
You'll first make a few loops with the wire on the outside nail to anchor the wire, then start the loop around the coil. Make sure you leave a lot of extra wire at the beginning and end of the coil. Leave 3 feet to be safe (you'll need this to hook up to electronics).
It's surprisingly hard to keep track of the number of windings. Use a friend to help you.
Make the windings REALLY tight. If you end up with loose windings, the coil will be a mess.
It's really hard to keep the windings in order (especially if you use 18 guage wire, 24 wire gauge is easier to handle but has a lot more loss). So you'll need a few people to help you hold it down as you wind it.
After you finish the turns, you'll want to twist the inlet wire & outlet wire to hold the coil steady. Then tape the coil with electrical tape in several spots.
When you're done with this step you should have two coils, one coil with a 20cm diameter and 15 turns and one coil with a 40cm diameter and 20 turns. The coils should be wound tightly, and secured with tape. You should be able to pick them up and handle them easily without them falling apart or unwinding.
Step 4: Add the Lightbulb & Electronics to the 20cm Coil
Next, you're going to attach the light bulb to the small coil. You need to solder three 1uf (1 microfarad, or said different way 1,000nF) and one 0.47uF (said a different way, 470nF) capacitors to the light bulb posts. That's a total of 3.47uF (capacitors add up in parallel). If you're doing the high power version, you should also solder a 20V bidirectional TVS diode between the light bulb posts as protection against overvoltage.
After you solder the capacitors, you need to twist the ends of the coil wire all the way across the center of the coil. The wire is stiff enough to support the light bulb. After you twist the wire all the way across the diameter, you're going to just cut the ends of the wire and leave them open.
Then you'll place the light bulb in the center of the twisted wire. You'll pull apart the twists, so that each wire touches one terminal of the lightbulb. Then you scrape off the wire enamel with a knife and then solder the cleaned wire to the light bulb posts. Make sure you use rosin core solder. You might want to add extra rosin, which will help clean the bits of enamel.
Step 5: Attach the 40cm Coil to the Electronics.
Next you'll need to connect the 40cm coil to a 1uF capacitor. Shown here is the high power version, where I've connected 10x 0.1uF capacitors in parallel to make one 1uF capacitor (capacitors in parallel add up). The capacitor goes between the coil and the power amplifier positive output. The other side of the coil goes directly to the power amplifier GND.
Step 6: Connect a Sine Wave Source to a Power Amp and Try It Out!
The last step is create a sine wave. You can download a function generator app on your phone or laptop or desktop. You'll want to experiment to find the best frequency of operation.
You connect your sine source to the audio power amp, and then connect the audio poweramp to the 40cm coil and 1uF capacitor, and then everything should work!
If you use a high power audio amp (100W or greater), BE CAREFUL! It can generate very high voltages in excess of +/-500V. I tested with a high voltage scope to ensure I wasn't going to blow up the capacitors. It's also easy to get shocked if you touch an exposed lead.
Also, if you use a high power audio amp, you can't get the 20cm coil too close to the 40cm coil. If they are too close, the TVS diode or LED light bulb will burn up due to excessive power.
Step 7: Create the Wireless Phone Charger
You can easily modify the circuit to charge a phone. I built a second 20cm coil and then added all of the circuitry. The same 3.47uF capacitor and TVS diode is used. That's followed by a bridge rectifier (Comchip P/N: CDBHM240L-HF), followed by a 5V linear regulator (Fairchild LM7805CT), followed by a 47uF tantalum capacitor. With a high power amplifier, the circuit can easily charge your phone from a distance of a foot and a half!
Step 8: The Results
The measured voltage versus distance curves are attached.
Design Measurements, and comparison to simulation & theory
40cm Coil
  • Main coil = 0.2m radius, 0.4m diameter. 18 gauge wire 20 windings
  • Theoretical resistance = 20.95e-3*(2*pi*0.2*20+0.29*2) = 0.5387 ohms
  • Actual resistance = 0.609 ohms. Variance from theory: +13%
  • Simulated Inductance = 0.435mH Actual Inductance: 0.49mH. Variance from simulation: +12%
20cm Coil
  • Receive coil = 0.1m radius 0.2m diameter 18 guage wire 15 windings
  • Theoretical resistance = (2*pi*0.1*15+0.29*2)*0.0209 = 0.2091
  • Actual Resistance = 0.2490. Variance from simulation: +19%
  • Simulated Inductance = 0.105mH. Actual Inductance = 0.1186mH. Variance from simulation: +12%
Step 9: Simulation, Optimization & Discussion
How we simulated the design
We simulated and optimized the design in a 2-D mangetostatic simulator, and with SPICE.
We used the free 2-D mangetostatic simulator called Infolytica. You can download for free here:
http://www.infolytica.com/en/products/trial/magnet...
We used the free SPICE simulator called LTSPICE. You can download it here:
http://www.linear.com/designtools/software/
Design files for both simulators are attached.
Discussion
This design uses resonant magnetostatic power transmission. The audio power amp produces an electric current that flows through the transmitting coil and generates an oscillating magnetic field. That magnetic field is received by the receiving coil, and turned into an electric field. In theory, we could do that without any components (i.e. no capacitors). However, the efficiency is extremely low. We initially wanted to make a simpler design that used only the coils and no other components, however, the power efficiency was so poor it couldn't turn on the LED. So we moved to a resonant system. The capacitor that we added resonates at one particularly frequency (in this case about 8kHz). At all other frequencies the circuit is extremely inefficient, but at the exact resonant frequency it becomes very efficient. The inductor and capacitor act like a transformer of sorts. On the transmitting coil, we put in a small voltage and a high current (10Vrms and 15Arms). That ends up producing >400Vrms across the capacitor, but at a much lower current. That's the magic of resonant circuits! Resonant circuits are quantified by the "Q factor". In the 40cm diameter transmitter coil, the measured Q factor is about 40, meaning that's pretty efficient.
We simulated & optimized the coil with Infolytica's 2-D magneto static simulator. That simulator gave us a simulated inductance for each coil, and the mutual inductance between the two coils.
Magnetic Simulated Values:
  • Transmitting Coil = 4.35mH
  • Receiving Coil = 0.105mH
  • Mutual Inductance = 9.87uH. K=6.87e-3 (with the coils separated by 0.2m)
We then took those numbers and fed them into SPICE to simulate the electrical characteristics.
You can download the simulation files attached, and try to make your optimizations and measurements!
Also attached are field plots, that show the magnetic field produced by the coils. It's interesting that even though we're putting in a lot of power, the absolute fields are pretty small (in the milliTesla range). That's because the fields are spread out over a large surface area. So if you add up (integrate) the magnetic field over the large surface area, it would be substantial. But at any given point in the volume it's tiny. As a side note, this is why transformers use iron cores, so that the magnetic field gets concentrated in one area.
    • IoT Challenge
      IoT Challenge
    • Gardening Contest
      Gardening Contest
    113 Discussions
    Josan007
    3 months ago
    Hi, I'd like to know what exactly need and to do when light up a few warm white LED's with approx. 5mA and 3 Volt and distance approx. 2 meters? Many thanks in advance Armin
    DenisB114
    Question 3 months ago on Step 9
    How high was the power output on the second coil ? What do I need to reach 400W or Higher ? I want to build a big coil to power a Notebook.
    CephalonOvelord.
    Love the design! I'm actually citing this project page for a power transfer network for a Swarm Network of mini robots. One quick question, though, did you find that 3.47uF in parallel worked for all voltages? If not, how did you find the necessary capacitance in your system?
    Thank you in advance!
    Ali Bukhari
    1 year ago
    This one is wonderful..
    What if at primary coil for high frequency source we use AC-AC Cyclo-converter or High Frequency transformer?
    KhalidA85
    1 year ago
    good job...
    I install Magnet infoltica V 7.4.1.4 but attach file haven't work. can you help me pleas...
    aquired101629
    1 year ago
    Hello!!!! Great Project .... i want to reproduce this using different values for my inductance etc. and i've checked your formulas and the like ...well i'm stucked with the coupling coefficient (k)...can you please tell me what formula did you use for the coupling coefficient?
    Mei-MeiCaquired101629
    Reply 1 year ago
    Hello there! The coupling coeficient k doesn't effect the value of the inductor & capacitor (at least to first order). The value "k" gets smaller as the coils get farther apart. If you want to know the equation for the inductor and capacitor, you can read about it on this website:
    https://www.allaboutcircuits.com/textbook/alternat...
    You can always tune the values for different resonant frequencies.
    GabrielC115
    2 years ago
    Hello, AWESOME INSTRUCTABLE, can i ask how you get the formulas? thanks:)
    Laral
    3 years ago
    What a fantastic Instructable. I viewed the video. What a wild church! Teaching Maxwell's equations and demoing them in action! Why didn't my church teach that? :)
    billy_kolbLaral
    Reply 3 years ago
    Some churches are busy proving that God made the universe only a few 1000 years ago.
    Laralbilly_kolb
    Reply 3 years ago
    Exactly. Despite all the scientific evidence to the contrary. That is precisely what makes this particular church quite progressive by allowing one of its members to actually teach science, albeit with a religious slant.
    jimmie.c.boswellLaral
    Reply 3 years ago
    their teaching technology, not science here. technology is the art, of putting scientific principals to use.
    Laraljimmie.c.boswell
    Reply 3 years ago
    Well, when I studied Maxwell's equations, it was part of a physics major curriculum. Doesn't get any more 'science' than that… As for technology, this is a demonstration of Tesla's idea of wireless power transmission, which was soundly based on Maxwell's equations, at a time when none of the players in the nascent wireless industry even knew about them, let alone understood them.
    Reply 3 years ago
    studying what scientists have already done, does not make you a scientist. scientists, are the ones with the original never before done or thought of ideas. they, are the forerunners of all technology and scientific education.
    _soapy_jimmie.c.boswell
    Reply 3 years ago
    That's the worst job description of a scientist ever.
    An inventor comes up with new things, & an engineer fixes existing things. But the boundaries blur. And both can be scientists.
    You know what we can people who keep trying to find ways around relativity, Maxwell's equations, how things create "free" electricity, etc when they've not learned what things are and how they work properly? Cranks. Eccentrics. And that's at best.
    Science is discovery. But if you don't learn what's already known, you'll never get far. You have to stand on the shoulders of giants to see further.
    jimmie.c.boswell_soapy_
    Reply 3 years ago
    sorry but technology, is the application of known scientific principals. and inventors, and engineers, are designers of technology. repair technologist, and technicians are the ones who fix and or assemble things for engineers. scientist are the discoverers, of things that were not known before.
    very few scientists, are also engineers, designers, and engineering technicians like Tesla.
    as far as relativity goes, that is a scientific family rivalry matter. and the only possible way, around relativity is the fraction left over from Einstein's equation. and technically speaking, it would not be circumventing the equation.
    and as far as, free energy goes. it has always been so far, way to expensive or fraudulent. since we seem, to limited to less than unity. thus is the basis for the search, for greater efficiency. such as with Edison, is we know it works but how can we improve it?
    Reply 3 years ago
