Homemade Hot Tub
46,405
291
41
Do you like keeping warm? Do you like doing so in hot tubs? If so; this might be the Instructable for you!
I will detail how my friends and I designed and built a wood-fired hillbilly hot tub that reached 112 degrees (F) within an afternoon using items from my local Home Depot!
Step 1: Building the Frame
To make this tub easy to set up and tear down, we decided to use a combination of old railroad ties and fallen logs that I had laying around for the frame. It is important to grade the ground underneath and check for anything sharp that could puncture the tarp.
We simply used twine to lash the logs together at the corners to prevent them from moving too much.
We placed bricks and other stones around the bottom layer to prevent the tarp from bulging out into the gaps left by the log-cabin style construction.
Step 2: Building the Heating Coils
This was the most expensive part of the hottub: using 35 feet of 1/2" diameter copper tubing to make the coils. Onto each end of the coil, I soldered a 2 foot straight copper extension to get out away from the fire, and to have a cooler area to attach the vinyl tubing for the pump.
The pump is a submersible 250 gph pump that I found at Home Depot. Do note that a pump such as this is much less expensive from Amazon, so I would recommend getting one there instead.
If you are iffy on soldering the copper together, remind yourself how with this instructable:
https://www.instructables.com/id/How-to-Sweat-solder-Copper-Pipe/
Step 3: Heating the Tub
This step can take awhile. You'll want to fill the tarp with water: we have done it with both pond water and city water from a garden hose, it really doesn't matter: you won't notice the difference, I promise.
I recommend using bricks or some other weight to hold the tarp up at first: we tied it using twine and the weight of the water ended up ripping the eyelets out of the tarp. Using weights allowed the tarp to be adjusted as it is filled. Once the water is in, it shouldn't move around too much.
Once it's full, start a large fire and the pump. Depending on how hot your fire is, this can take different amounts of time: in my experience, around 3-4 hours to achieve hot tub status.
One thing we did to speed it up was attach a steel pipe to the end of a vacuum on "blow" and stick it in the fire. The oxygen being shot directly into the fire really got it cooking.
One suggestion I would make would be to place the hot tub a bit further from the fire, and account for the wind direction that day. Depending on wind, you can end up with a lot of smoke and ash blowing right towards the tub, making for a poor experience. By making the vinyl hoses longer, the tub could also be moved further away from the fire.
NOTE: If the copper coils are in the fire, you need to have the pump running and water going through it, or else your solder will melt.
Step 4: Happy Hot Tubbing!
Good luck with your hot tubbing adventure! Also, Here is a parts list compiled:
(I spent a total of about $250 on these parts, but you could probably spend a lot less if you were thrifty about it)
30-40 feet 1/2" diameter copper coil
2 foot straight copper tubes (1/2" diameter) X2
2X 1/2" copper couplings
10 feet of braided vinyl
250 GPH submersible fountain pump
2X hose clamps (3/4")
Acid core soldier
Flux
Blowtorch
Twine
Bricks/stones
Logs, railroad ties, or a big hole
Large Tarp (big enough to fit your tub size of choice)
Water
Fire
Shop vac or leaf blower with a metal tube at the end to stick into the fire (optional)
Brave the Elements Contest
Second Prize in the
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    • Gardening Contest
      Gardening Contest
    41 Discussions
    johnr86
    8 months ago
    I like the creativity!
    Only risk with your design is that the hot water or one of you moving around in there could damage the water pump or wire, then 220v/110v shocks all of you. Maybe to death. This is why aquarium or pond pumps put in their instructions that you must unplug the pump before touching the water.
    What I did for a new years party is I used an inflatable pool, a 12v "camping shower" pump that was powered by a car battery and a gas powered camping water heater. worked well!
    warriorethos2
    3 years ago
    suiterelliot, Fire, earth, air, and water -- the Brave the Elements Contest is about all the things you make and do to withstand or take advantage of the elements. Your project involved all four elements. You used a fire pit, a vacuum as a wind turbine, pond water which is a combination of a rain collection systems and earth collection system, and you used logs which are part of the earth. You and your friends were able to harnesses the power of nature heating water with fire and you did it when there was snow on the grown. Your project hit all the areas of the contest and it was easy to follow your instructions both with the pictures and the writing. Well done and good luck in the contest.
    ILykMakinPurplepanther
    Reply 3 years ago
    That he's being sardonic or serious.
    Is it that tough to suss?
    downs
    3 years ago
    rather than spending $$ on copper a salvaged car radiator works....while yer at it grab the water pump and the whole thing will run off a car battery. there's also this: http://thehomesteadsurvival.com/build-5-gallon-bucket-sink-diy-project/ home made foot pump can be operated under water
    ellitnomeddowns
    Reply 3 years ago
    Would the radiator stand up to flame heat??
    downsellitnomed
    Reply 3 years ago
    there are several folks demonstrating this technique on the web. youtube etc. google hot tub car radiator...of course you wouldn't want a plastic radiator (never heard of such a thing, how does it conduct heat?)
    jprobst2downs
    Reply 3 years ago
    With most car radiators now adays being aluminum and plastic, I doubt see that being a solution. Also every production car I've ever worked on uses the engine to drive the water pump not a separate electric motor. You can however buy one for racing applications which would most likely cost more than what the author of this article spent on the entire project.
    Mark 42
    3 years ago
    Move the pump outside (a 12V bilge pump would be safer)
    ryanrivas
    3 years ago
    Good one...Were you one of the dudes in the picture? Do you wish you were..? Seems odd someone NOT in that photo would make an original, super inspired (and hilarious) comment like that.
    Spokehedzryanrivas
    Reply 3 years ago
    Nah man, I hear that hot water helps with sick burns though. There looks like there is just enough space in the tub. Go on. Let the warm water soothe you.
    ryanrivasSpokehedz
    Reply 3 years ago
    I read they have open mic on Sundays. If you're in the area, you should really go and check it out. I think you may have what it takes.
    http://hollywood.thecomedystore.com/DirectionsMapParking-Info
    spark master
    3 years ago
    Oh I fergit, coroplast is available free after most election cycles. big political signs made of it they do not rot or get mushy. And after a nasty election cycle AFTER it is done go out and harvest away, as most politico's leave their crap laying around forever.
    Spokehedzspark master
    Reply 3 years ago
    Check with your local municipality, but most places consider them "Unclaimed Trash" even during election season... I used to make airplanes out of them back in the day.
    I MP
    3 years ago
    Not to seem a spoil sport but based on my time in Japan you can make a hot tub with a stock tank and a terra cotta U pipe. The U pipe is mounted in vertically in holes in the stock tank with the protruding portion going into a firebox with the water flowing through it. Convection from the fire heat causes the water to circulate and the tub gets warm.
    keldredge
    3 years ago
    I would have second thoughts about a power cord in the water with me, even if its meant to be.
    spark master
    3 years ago
    Oh of you are al cherapo like me you could use layered corrigated cardboard to insulate the outer walls Just make pillows with plastic bags, and seal them from water. Can do the same with the floor.
    sweet party trick!
    papatait
    3 years ago
    I would suggest to add Styrofoam insulation sheets to the bottom and sides of the hot tub (outside the tarp against the wood frame ) to make the bottom softer and smoother to sit on and the sides smooth and hold in some of the precious heated water longer. Another suggestion is to make stove out of a 55 gallon drum or 20 gallon grease drum ( like a burn barrel standing upright ) and put a short chimney on it to keep any smoke off you if the wind changes.
    spark masterpapatait
    Reply 3 years ago
    grest idea I was just about to say that! You make stadium seat, or winter camping hot seats out of foam. Ugly , but highly effective.
