Honeyduke's Chocolate Frog Box
88,826
229
37
After many hours of searching the web for the perfect printable template for a Honeyduke's Chocolate Frog box, the web seemed to come up short. I ended up downloading what appeared to be a scan of a used box (crease lines and all) and modifying it heavily in Photoshop myself. I'm providing that edited template along with a star pattern I created for the inside of the box in a zip file with this tutorial. You'll need to download it and extract the files before you continue.
Also, make sure you have the following:
  1. Scissors
  2. Permanent double sided tape
  3. Heavy card stock paper
  4. A printer
If you're interested in making the Chocolate Frog cards as well, you can view those instructions here!
You'll also need to download my free templates available below. I am not referring to the instructables PDF (which requires a paid subscription). You want to download the .zip file.
YOU MAY *NOT* USE THESE TEMPLATES FOR PROFIT
Supplies:
Step 1: Print the Template
The first thing you'll need to do is print the images from the zip file onto a sheet of card stock paper. Print the front of the box on one side, flip the paper over, put it back in the printer, and print the star pattern on the other side.
Step 2: Cut the Template Out
Next, cut out the template. Follow the lines as closely as you can, making sure to not leave any white around the edges. There are small tabs that you can safely cut off. Refer to the images above.
Step 3: Fold and Crease
Now you'll want to fold the flaps and make creases in the bottom side of the box. You will basically want to fold and crease the box everywhere you see the borders with the small circle patterns. Refer to the images for reference.
Step 4: Apply Double Sided Tape
Apply strips of double sided tape around the inside of the box as shown in the images above. You'll want to add small pieces of tape to the little triangle folds in the corners of the box as well, and a couple of thin strips to the top of the box.
Step 5: Fold Again
Fold in the small triangular corners and crease them. You will want to push them against the edges of the double sided tape you applied to the inside of the box and then pinch them so that the smaller pieces of tape you applied to the corners hold them closed (See the first and second image above).
Once that's done, fold the flaps down on all four sides of the box and pinch them against the strips of double sided tape.
Now pull the edge of the top of the box, where you applied tape, under the other side. Line up the word "Frog" and line up the circle pattern at the bottom, then pinch along the overlap to get the tape to stick.
Once you have finished this, close the box.
Step 6: You're Finished!
You're all done!
This was kind of difficult to explain with all the folding, creasing, and taping. I Hope the images help!
Let me know if you liked this tutorial and post your own Chocolate Frog boxes in the comments!
Don't forget to check out how to make Chocolate Frog cards, too!
4 People Made This Project!
  • Woodworking Contest
    Woodworking Contest
  • IoT Challenge
    IoT Challenge
  • Fandom Contest
    Fandom Contest
37 Discussions
RachelS241
6 months ago
Hello! Thank you for this tutorial, we followed all the directions but the box won’t stay closed? :/ is there something you recommend for this?
AlondraR1
Question 1 year ago
Can you send the file since you had to take it down I would really love this and the inside cards
BenjamínP100
1 year ago
Can you upload the files please?
pascalineb
Question 1 year ago
hi! I love these and am throwing a harry potter themed graduation party for my daughter and your chocolate frog boxes would be such a wonderful addition to the party. i am just having trouble finding the zip file you mentioned. where do i find it so i can download and start creating?
ktatak
Question 1 year ago on Introduction
Can you tell me what # the cardstock is? I ordered 80lb. glossy paper and it was too flimsy.
1 answer
TabithaC18
How heavy is the card stock used? I have some basic card stock, but probably a little flimsy for the boxes.
1 answer
21lparis
2 years ago
hi, this is amazing! I was just wondering if we could use a glue stick instead of double sided tape?
Muggle Magic21lparis
Reply 1 year ago
Yes, you can use a glue stick if you prefer. I tried it that way and it was a little more messy, but it worked. I had to keep wiping off my fingers and parts of the box.
DakotaLouise
1 year ago
Thank you very much, these, and your cards as well, are absolutely beautiful! You also give them out for free, like whaaaat? :-) Thanks
HarryPotter50
1 year ago
Hey, These are so great! Would you do cards for Harry, Hermione, and Ron? My kids would really love those.
TheresaR41
2 years ago
I made this too and they look so so so awesome! I'll post some pictures soon. I found that the lid wasn't very tight for my first few. What I ended up doing was only folding the two lid tabs on the sides and leaving the others unbent. I found that this provided just enough friction to keep the lid closed on its own. I'm also using a heavy card stock.
Shanael85
2 years ago
Hi, I'm on my third trial box and no matter what I do I can't get the top to fit the bottom of the box. I did see your comment about the dots bordering the top and bottom of the sides but no matter how I fold it, it makes no difference. Any suggestions? I can't figure out what I'm doing wrong.
Muggle MagicShanael85
Reply 2 years ago
Sorry to hear you're having trouble. From your photo, it looks like the corners of the box are a bit loose. Try folding them in tighter so the sides of the box aren't 100% vertical. They should be at a very slight inward angle. Does this make sense?
Shanael85Muggle Magic
Reply 2 years ago
I'll give it a whirl. I'm determined to make this work. Thanks for the reply!
HeatherD103
2 years ago
This is so great! Thank you for sharing and putting in all of that hard work! It will definitely be great for my daughter's Harry Potter birthday party!
abbymilligan
3 years ago
Amazing! I made it and it turned out awesome
