Hosting Your Own Website
13,606
40
19
It's great to have a website, but most hosting services are outrageously expensive. If you are reading this on the internet, then you can easily host your own website for free! Here's how to do it.
Thanks to sparks4289 for clarifications.
EDIT: If any of you care to see my website, it is at http://173.53.67.217/index.html. It is not quite done yet! By the way, the login scripts on the page are made of the PHP and MySQL from Wampserver, just to show it works.
Step 1: 2. Preparations
To host your own website, you are going to need to do a few things.
PICTURE 1
Log into your routers web page (this is usually http://198.168.1.1)
PICTURE 2
Find both your real IP(What everyone else uses) and your local IP(only you use this one). Be sure to write both of these numbers down.
Step 2: 2. Download the Server Program
To actually HOST the site, you need a good server program. I recommend Wampserver, a program that contains services such as Apache, MySQL, and PHP. First, go to http://www.wampserver.com/en/download.php and click on "Download Wampserver 2.0i" and follow the instructions. When done, click on the task bar icon and you should see a menu like the one in picture 2.
Step 3: 3. Write the Website's Code
Write your website's code (HTML, PHP, etc.) and place it in the www folder. This can be accessed by clicking on the www directory icon on the task bar menu.
NOTE: This can take a while even if you are skilled in PHP/HTML. Don't expect it to be easy.
Step 4: 4. Put Online!
Actually putting the website online is the easiest part. Just click on the "Put online" icon in the task bar menu. To find your website at home, type in your 192.168.1.x IP address. To find it anywhere else, type in your xxx.xxx.xx.xxx IP address. Your website will always be up as long as your computer and internet connection are on.
EDIT: In some cases, you will not have a 'static' IP address. This means that your IP will change every time you go online. In this case, you may need to pay your ISP for a static one.
CONGRATULATIONS! You now have a fully functional website!
    • Arduino Contest 2019
    • IoT Challenge
      IoT Challenge
    • Gardening Contest
      Gardening Contest
    19 Discussions
    sparks4289
    8 years ago on Introduction
    your 'private' IP address as you call it is really just your 'local' IP address. The IP your router assigns to your computer for it to function on the network. The 'public' IP address is going to be your real IP and what your ISP provides to you, which depending on your type of service can fluctuate and change regularly. Some ISP's even require you to pay an extra fee to have a fixed, or static IP. Your local IP address can also change, depending on the settings on your router.
    nil123-3
    1 year ago
    it's really work
    hosting packages are really cheap these days far cheaper than buying a computer and running the power, but great explination.
    austech
    5 years ago
    Just gonna throw this in here, most ISPs will eat you alive for hosting a large server from home
    xhacks
    I've been hosting my site for a while now
    http://modbotix.com
    and a friends site which is under construction rite now
    http://smokenpictures.net
    also if ur isp blocks port 80 outgoing then u can forward any port from the WAN side to ur Local side (ie. port 1337 to port 80)
    schumi23xhacks
    It asks me fir a username/password when I try to go to modmotix
    (And smoken just doesnt load)
    xhacks
    srry about all this as my computer crashed and i replaced it but now smokenpictures is no longer up and modbotix is now hosted by a service however now i have to reconstruct it and i am redesigning it for a diferent purpose
    ______
    Your website must not work i tried going to it but it said a fire wall is blocking it
    RedMeanie
    Thanks! I have 3 full size dell servers ready for a video server type site I want to set up so I can monitor a few DVR systems I have at different locations. I have software for setting up the DVR monitoring and enough drive space with a whole bunch of drives so I can upload video if I need to. Its just hard to make that leap into doing it! LOL it seems hard when you think about it, but your Instructable has explained allot of the stuff I was afraid of. Thanks!
    Ranie-K
    Any idea on how to get it through my router's firewall? I've made perfectly fine websites that will only be visible within my own apartment but my D-link DL-624+ will prevent anyone outside reading it..
