How to Archive Sewing or Other Types of Patterns.
4,672
58
About: I Exclusively Work The Renaissance Faires . Quality Of Life Not Quantity Is What 's Important.
Working with the same pattern, altering multiple ways and making all the size ranges ( xs to xl) I ran in to a problem. This cant be done with one pattern. Rather than buy many of the same pattern, I came up with this method.
   This Instructable is for a fabric pattern I am going to augment and use as a leather pattern. Archiving the original pattern and all variations helps in the metamorphosis of your design ideals.
Supplies:
Step 1: Tools and Materials
 Tools & Materials
       Scissors and  or a roll cutter
       Ruler
       Pen and a Sharpie
       Transparent Tape
       Clear Packing Tape
       Card Stock  8.5 x 11  67 to 110lb.
       Scanner not shown
       Pattern
Step 2: Paper Layout
Using a pen and ruler draw a 1/2" border around the Paper. This is for alignment and squaring purposes.
Step 3: Pattern Cutting
Cut your pattern on at least two edges square Internally and leave at least 1/4 " on the outer edges. Remember to cut within the new borders you drew on the paper ( 7 1/2 x 10" maximum size for a cut pattern piece ). I try to not to cut apart words or other information on the pattern that I think  should stay on one section even if I use extra paper.
Step 4: Pattern Layout and Marking
Tape the pattern squarely on the paper with translucent tape inside the boundaries and mark pieces.
Step 5: Scanning
Scan all pieces as .jpeg  at  100%. I scan in color then render in grayscale on the computer. On my scanner the scan in black and white setting often produces undesirable results.  I Use Photoshop to adjust and render the image into grayscale. Here is how to do it in windows photo gallery.
   1.   Open image in photo gallery.
   2.  Open Fix ( Pic 2)
   3.  Go to Adjust Color ( Pic 3)
   4.  Adjust Slide Bars To Zero Value.
Step 6: Before and After Scanning to Printing
 Print all pieces at  a 1 to 1 ratio (100 % ). You now have a completed pattern .
Step 7: Putting It Together.
Cut Tabs off on one side leave other side on for attachment
Step 8: Align and Tape
Align and tape all pattern pieces with translucent tape.
Step 9: Laminating
I use heavy duty clear packing tape to laminate both sides of my finished pattern. This gives me a nice thick edge to trace or cut around.I Can also make notes and adjustments on the pattern with a dry erase marker .
Step 10: Adjust at Will
The adjustments I make on the pattern will be cut out and re- scanned on the layout paper from step 2 and taped back in to position or I will just re print the pattern. These patterns can now be shared amongst friends.
    • IoT Challenge
      IoT Challenge
    • Arduino Contest 2019
    • Classroom Science Contest
    2 Discussions
    seamster
    9 years ago on Introduction
    Very nice!  This is a very handy technique.
    Plus, if a person wants to share their archived patterns (sewing or otherwise) here on this site, all they have to do is save them as a PDF and include them with their projects. I've included patterns with a few of my instructables, and seen others do the same thing. It takes a little extra work, but it makes what we share back and forth that much more useful.
    bevmo63seamster
    Thanks for the comment.  Sharing ideas and techniques is what I believe this site is founded on.
