How to Make a Matrix Batch File
369,496
41
113
This batch file will give out random green numbers that resemble the background to "The Matrix"
theres really no point to it except to look cool
Supplies:
Step 1: Creating the Batch File
right click
>new
>>text document
rename "matrix.bat"
>click yes
should change icon to a gear
Step 2: Programing the File
right click
>edit
it should have opened notepad
copy and paste in between the lines
@echo off
color 2
:start
echo %random% %random% %random% %random% %random% %random% %random% %random% %random% %random% %random% %random% %random% %random%
goto start
save
double click and it should create the matrix
Step 3: Additional Creativity to Your Matrix
you can change the color code to make the background and numbers a different color
right now the color code is "2" which can also be written as "02"
its still the same number
"0" make the background black and the "2" makes the numbers green
if you change the code to 15
background would be blue and numbers would be pink
or if you change the code to 47
background would be red numbers would be white
if you wanted to change what the text said just get rid of the "%random%"s and add a bunch of writing.
in the example i wrote "MatrixEagle15" (17 times to get the blur effect)
    • Classroom Science Contest
    • Arduino Contest 2019
    • Fandom Contest
      Fandom Contest
    113 Discussions
    BikashR3
    Question 5 weeks ago on Step 2
    i have to save only matrix ???
    lopez8675
    10 years ago on Step 3
    I'm using windows vista. the file type doesnt change from .txt to .bat how do i fix this?
    MrDestroyer15lopez8675
    Reply 2 years ago
    make sure that under the area where you write the file name you select all files instead of text file also make sure to end the file name with .bat example
    ---> matrix.bat
    dienow239lopez8675
    Reply 8 years ago on Step 3
    goto your files and where it says .txt change it to .bat like your renameing it
    the guardianslopez8675
    save it as matrix.bat then exit then open notepad>file>open>Change "text documents" to "All Files" and you should find it. right click the batch file>send to>desktop
    REAlopez8675
    make the text document, open it, save as Matrix.bat it should work then. the reason it didnt work was because you dont have the "show file type" on. to turn it on go to a folder (any one) go to the tools drop menu, then folder options, then click the "view" tab, and scroll down till you see a check box that says "hide extensions for known file types" and uncheck it.
    Sembot
    1 year ago
    how can i adjust the speed of moving , en make sound
    BitRate GamingSembot
    Reply 1 year ago
    Batch files dont make sound. It runs a code. Thats all
    24ninjas
    2 years ago
    You said the icon is supposed to change? It didn't change so what do I do? Am I doing something wrong?
    TJM31
    2 years ago
    every time I try to add in words save it and open it in cmd.exe it always says "Echo is off." what do I do?
    Mr.M11Mr_Misteerious
    Reply 3 years ago
    :loop
    timeout /t 3 /nobreak >nul
    color {insert color}
    {another color}
    #NOTE: you can repeat the proccess and add more color if you wish so
    goto loop
    hizkiakarta
    4 years ago on Introduction
    i tried to make some folder locker combine with matrix , but somehow when i enter the wrong password it keep open the locked folder. sorry for bad grammar
    this was my code :
    cls
    @ECHO OFF
    color 0a
    title Folder Penting
    if EXIST "Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}" goto UNLOCK
    if NOT EXIST Penting goto MDPENTING
    :CONFIRM
    echo Di
    ping localhost -n .15 >nul
    cls
    echo Di.
    cls
    echo Di
    cls
    echo Did
    cls
    echo Did
    cls
    echo Did
    cls
    echo Did y
    cls
    echo Did y
    cls
    echo Did yo
    cls
    echo Did yo
    cls
    echo Did yo
    cls
    echo Did you
    cls
    echo Did you
    cls
    echo Did you w
    cls
    echo Did you w
    cls
    echo Did you wa
    cls
    echo Did you wa
    cls
    echo Did you wan
    cls
    echo Did you wan
    cls
    echo Did you wan
    cls
    echo Did you want
    cls
    echo Did you want
    cls
    echo Did you want
    cls
    echo Did you want to
    cls
    cls
    cls
    cls
    echo Did you want to l
    cls
    cls
    echo Did you want to l.
    cls
    echo Did you want to lo
    cls
    cls
    cls
    echo Did you want to loc
    cls
    cls
    echo Did you want to lock
    cls
    cls
    cls
    echo Did you want to lock t
    cls
    cls
    cls
    echo Did you want to lock th
    cls
    cls
    cls
    echo Did you want to lock the
    cls
    cls
    cls
    echo Did you want to lock the f
    cls
    cls
    cls
    echo Did you want to lock the fo
    cls
    cls
    cls
    echo Did you want to lock the fol
    cls
    cls
    cls
    echo Did you want to lock the fold
    cls
    cls
    cls
    echo Did you want to lock the folde
    cls
    cls
    cls
    echo Did you want to lock the folder
    cls
    cls
    echo Did you want to lock the folder , M
    cls
    cls
    cls
    echo Did you want to lock the folder , Ma
    cls
    cls
    cls
    echo Did you want to lock the folder , Mas
    cls
    cls
    cls
    echo Did you want to lock the folder , Mast
    cls
    cls
    cls
    echo Did you want to lock the folder , Maste
    cls
    cls
    echo Did you want to lock the folder , Master
    cls
    echo Did you want to lock the folder , Master .
    cls
    cls
    cls
    echo Did you want to lock the folder , Master . .
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    echo Lock This Folder?(Y/N)
    set/p "cho=>"
    if %cho%==Y goto LOCK
    if %cho%==y goto LOCK
    if %cho%==n goto END
    if %cho%==N goto END
    echo Invalid choice.
    goto CONFIRM
    :LOCK
    ren Penting "Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}"
    attrib +h +s "Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}"
    echo Folder locked
    goto End
    :UNLOCK
    @ echo off
    color 0a
    echo I'
    cls
    echo I'
    cls
    echo I'
    cls
    echo I'm
    cls
    echo I'm
    cls
    echo I'm A
    cls
    echo I'm A
    cls
    echo I'm A
    cls
    echo I'm An
    cls
    echo I'm An
    cls
    echo I'm Ang
    cls
    echo I'm Ang
    cls
    echo I'm Ang
    cls
    echo I'm Ange
    cls
    echo I'm Ange
    cls
    echo I'm Angel
    cls
    echo I'm Angel
    cls
    echo I'm Angelo
    cls
    echo I'm Angelo
    cls
    echo I'm Angeloi
    cls
    echo I'm Angeloi
    cls
    echo I'm Angeloid
    cls
    echo I'm Angeloid
    cls
    echo I'm Angeloid T
    cls
    echo I'm Angeloid T
    cls
    echo I'm Angeloid Ty
    cls
    cls
    echo I'm Angeloid Typ
    cls
    cls
    echo I'm Angeloid Type
    cls
    cls
    echo I'm Angeloid Type:
    cls
    cls
    echo I'm Angeloid Type:B
    cls
    cls
    echo I'm Angeloid Type:Be
    cls
    cls
    echo I'm Angeloid Type:Bet
    cls
    cls
    echo I'm Angeloid Type:Beta
    cls
    cls
    cls
    cls
    echo I'm Angeloid Type:Beta ,
    cls
    cls
    echo I'm Angeloid Type:Beta , N
    cls
    cls
    echo I'm Angeloid Type:Beta , Ny
    cls
    cls
    echo I'm Angeloid Type:Beta , Nym
    cls
    cls
    echo I'm Angeloid Type:Beta , Nymp
    cls
    cls
    echo I'm Angeloid Type:Beta , Nymph
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    echo Y
    cls
    echo Yo
    cls
    echo Yo
    cls
    echo Yo
    cls
    echo Yo H
    cls
    echo Yo H
    cls
    echo Yo Hi
    cls
    echo Yo Hi
    cls
    echo Yo Hik
    cls
    echo Yo Hik
    cls
    echo Yo Hika
    cls
    echo Yo Hika
    cls
    echo Yo Hikar
    cls
    echo Yo Hikar
    cls
    echo Yo Hikaru
    cls
    echo Yo Hikaru
    cls
    echo Yo Hikaru-k
    cls
    echo Yo Hikaru-k
    cls
    echo Yo Hikaru-ku
    cls
    echo Yo Hikaru-ku
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun
    cls
    echo Yo Hikaru-kun .
    cls
    cls
    cls
    echo Yo Hikaru-kun . .
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    echo D
    cls
    echo D
    cls
    echo D
    cls
    echo Di
    cls
    echo Di
    cls
    echo Di
    cls
    echo Did
    cls
    echo Did
    cls
    echo Did
    cls
    echo Did y
    cls
    echo Did y
    cls
    echo Did y
    cls
    echo Did yo
    cls
    echo Did yo
    cls
    echo Did yo
    cls
    echo Did you
    cls
    echo Did you
    cls
    echo Did you
    cls
    echo Did you w
    cls
    echo Did you w
    cls
    echo Did you w
    cls
    echo Did you wa
    cls
    echo Did you wa
    cls
    echo Did you wa
    cls
    echo Did you wan
    cls
    echo Did you wan
    cls
    echo Did you wan
    cls
    echo Did you want
    cls
    echo Did you want
    cls
    echo Did you want
    cls
    echo Did you want
    cls
    echo Did you want t
    cls
    echo Did you want t
    cls
    echo Did you want t
    cls
    cls
    cls
    cls
    echo Did you want to o
    cls
    cls
    echo Did you want to op
    cls
    cls
    cls
    echo Did you want to ope
    cls
    cls
    echo Did you want to open
    cls
    cls
    cls
    echo Did you want to open t
    cls
    cls
    cls
    echo Did you want to open th
    cls
    cls
    cls
    echo Did you want to open the
    cls
    cls
    cls
    echo Did you want to open the f
    cls
    cls
    cls
    echo Did you want to open the fo
    cls
    cls
    cls
    echo Did you want to open the fol
    cls
    cls
    echo Did you want to open the fold
    cls
    cls
    cls
    echo Did you want to open the folde
    cls
    cls
    cls
    echo Did you want to open the folder
    cls
    cls
    cls
    echo Did you want to open the folder ,
    cls
    cls
    echo Did you want to open the folder , M
    cls
    cls
    cls
    echo Did you want to open the folder , Ma
    cls
    cls
    cls
    echo Did you want to open the folder , Mas
    cls
    cls
    cls
    echo Did you want to open the folder , Mast
    cls
    cls
    cls
    echo Did you want to open the folder , Maste
    cls
    cls
    echo Did you want to open the folder , Master
    cls
    cls
    echo Did you want to open the folder , Master .
    cls
    cls
    cls
    echo Did you want to open the folder , Master . .
    cls
    cls
    cls
    cls
    cls
    cls
    echo Did you want to open the folder , Master . . .
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    echo Enter The Password, that only Hikaru-kun know's:
    set/p "pass=>"
    if NOT %pass%==95828025a FAIL
    attrib -h -s "Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}"
    ren "Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}" Penting
    echo Folder Unlocked successfully
    goto End
    :FAIL
    echo Invalid password
    goto end
    :MDPENTING
    md Penting
    echo Penting created successfully
    goto End
    :End
    can you tell me how t fix it, please
    FlorianK1Crumble
    Reply 4 years ago
    maybe your processor is overloaded
    zakygames
    this is mine I made:
    @ echo off
    color 0a
    echo W
    cls
    echo Wa
    cls
    echo Wak
    cls
    echo Wake
    cls
    echo Wake
    cls
    echo Wake u
    cls
    echo Wake up
    cls
    echo Wake up
    cls
    echo Wake up b
    cls
    echo Wake up bo
    cls
    echo Wake up bob
    cls
    echo Wake up bob.
    cls
    echo Wake up bob..
    cls
    echo Wake up bob...
    cls
    echo Wake up bob....
    ping localhost -n 5 >nul
    cls
    echo T
    cls
    echo Th
    cls
    echo The
    cls
    echo The
    cls
    echo The M
    cls
    echo The Ma
    cls
    echo The Mat
    cls
    echo The Matr
    cls
    echo The Matri
    cls
    echo The Matrix
    cls
    echo The Matrix
    cls
    echo The Matrix h
    cls
    echo The Matrix ha
    cls
    echo The Matrix has
    cls
    echo The Matrix has
    cls
    echo The Matrix has y
    cls
    echo The Matrix has yo
    cls
    echo The Matrix has you
    cls
    cls
    echo The Matrix has you b
    cls
    echo The Matrix has you bo
    cls
    echo The Matrix has you bob
    cls
    echo The Matrix has you bob.
    cls
    echo F
    cls
    echo Fo
    cls
    echo Fol
    cls
    echo Foll
    cls
    echo Follo
    cls
    echo Follow
    cls
    echo Follow
    cls
    echo Follow t
    cls
    echo Follow th
    cls
    echo Follow the
    cls
    echo Follow the
    cls
    echo Follow the w
    cls
    echo Follow the wh
    cls
    echo Follow the whi
    cls
    echo Follow the whit
    cls
    echo Follow the white
    cls
    cls
    echo Follow the white r
    cls
    echo Follow the white ra
    cls
    echo Follow the white rab
    cls
    echo Follow the white rabb
    cls
    echo Follow the white rabbi
    cls
    echo Follow the white rabbit
    cls
    echo Follow the white rabbit.
    cls
    echo K
    cls
    echo Kn
    cls
    echo Kno
    cls
    echo Knoc
    cls
    echo Knock
    cls
    echo Knock,
    cls
    echo Knock,
    cls
    echo Knock, k
    cls
    echo Knock, kn
    cls
    echo Knock, kno
    cls
    echo Knock, knoc
    cls
    echo Knock, knock
    cls
    echo Knock, knock,
    cls
    echo Knock, knock,
    cls
    echo Knock, knock, b
    cls
    echo Knock, knock, bo
    cls
    echo Knock, knock, bob
    cls
    echo Knock, knock, bob.
    cls
    :start
    @echo off
    color 0a
    cls
    :a
    set /a a=%random%
    if %a% geq 16384 set /a aa=1
    if %a% lss 16384 set /a aa=0
    set /a b=%random%
    if %b% geq 16384 set /a bb=1
    if %b% lss 16384 set /a bb=0
    set /a c=%random%
    if %c% geq 16384 set /a cc=1
    if %c% lss 16384 set /a cc=0
    set /a d=%random%
    if %d% geq 16384 set /a dd=1
    if %d% lss 16384 set /a dd=0
    set /a e=%random%
    if %e% geq 16384 set /a ee=1
    if %e% lss 16384 set /a ee=0
    set /a f=%random%
    if %f% geq 16384 set /a ff=1
    if %f% lss 16384 set /a ff=0
    set /a g=%random%
    if %g% geq 16384 set /a gg=1
    if %g% lss 16384 set /a gg=0
    set /a h=%random%
    if %h% geq 16384 set /a hh=1
    if %h% lss 16384 set /a hh=0
    set /a i=%random%
    if %i% geq 16384 set /a ii=1
    if %i% lss 16384 set /a ii=0
    set /a j=%random%
    if %j% geq 16384 set /a jj=1
    if %j% lss 16384 set /a jj=0
    set /a k=%random%
    if %k% geq 16384 set /a kk=1
    if %k% lss 16384 set /a kk=0
    set /a l=%random%
    if %l% geq 16384 set /a ll=1
    if %l% lss 16384 set /a ll=0
    set /a m=%random%
    if %m% geq 16384 set /a mm=1
    if %m% lss 16384 set /a mm=0
    set /a n=%random%
    if %n% geq 16384 set /a nn=1
    if %n% lss 16384 set /a nn=0
    set /a o=%random%
    if %o% geq 16384 set /a oo=1
    if %o% lss 16384 set /a oo=0
    set /a p=%random%
    if %p% geq 16384 set /a pp=1
    if %p% lss 16384 set /a pp=0
    set /a q=%random%
    if %q% geq 16384 set /a qq=1
    if %q% lss 16384 set /a qq=0
    set /a r=%random%
    if %r% geq 16384 set /a rr=1
    if %r% lss 16384 set /a rr=0
    set /a s=%random%
    if %s% geq 16384 set /a ss=1
    if %s% lss 16384 set /a ss=0
    set /a t=%random%
    if %t% geq 16384 set /a tt=1
    if %t% lss 16384 set /a tt=0
    set /a u=%random%
    if %u% geq 16384 set /a uu=1
    if %u% lss 16384 set /a uu=0
    set /a v=%random%
    if %v% geq 16384 set /a vv=1
    if %v% lss 16384 set /a vv=0
    set /a w=%random%
    if %w% geq 16384 set /a ww=1
    if %w% lss 16384 set /a ww=0
    set /a x=%random%
    if %x% geq 16384 set /a xx=1
    if %x% lss 16384 set /a xx=0
    set /a y=%random%
    if %y% geq 16384 set /a yy=1
    if %y% lss 16384 set /a yy=0
    set /a z=%random%
    if %z% geq 16384 set /a zz=1
    if %z% lss 16384 set /a zz=0
    echo %aa% %bb% %cc% %dd% %ee% %ff% %gg% %hh% %ii% %jj% %kk% %ll% %mm% %nn% %oo% %pp% %qq% %rr% %ss% %tt% %uu% %vv% %ww% %xx% %yy% %zz%
    goto a
    zakygames
    @ echo off
    color 0a
    echo W
    cls
    echo Wa
    cls
    echo Wak
    cls
    echo Wake
    cls
    echo Wake
    cls
    echo Wake u
    cls
    echo Wake up
    cls
    echo Wake up
    cls
    echo Wake up b
    cls
    echo Wake up bo
    cls
    echo Wake up bob
    cls
    echo Wake up bob.
    cls
    echo Wake up bob..
    cls
    echo Wake up bob...
    cls
    cls
    echo T
    cls
    echo Th
    cls
    echo The
    cls
    echo The
    cls
    echo The M
    cls
    echo The Ma
    cls
    echo The Mat
    cls
    echo The Matr
    cls
    echo The Matri
    cls
    echo The Matrix
    cls
    echo The Matrix
    cls
    echo The Matrix h
    cls
    echo The Matrix ha
    cls
    echo The Matrix has
    cls
    echo The Matrix has
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    echo F
    cls
    echo Fo
    cls
    echo Fol
    cls
    echo Foll
    cls
    echo Follo
    cls
    echo Follow
    cls
    echo Follow
    cls
    echo Follow t
    cls
    echo Follow th
    cls
    echo Follow the
    cls
    echo Follow the
    cls
    echo Follow the w
    cls
    echo Follow the wh
    cls
    echo Follow the whi
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    cls
    echo K
    cls
    echo Kn
    cls
    echo Kno
    cls
    echo Knoc
    cls
    echo Knock
    cls
    echo Knock,
    cls
    echo Knock,
    cls
    echo Knock, k
    cls
    echo Knock, kn
    cls
    echo Knock, kno
    cls
    echo Knock, knoc
    cls
    echo Knock, knock
    cls
    echo Knock, knock,
    cls
    echo Knock, knock,
    cls
    cls
    cls
    cls
    cls
    :start
    @echo off
    color 0a
    cls
    :a
    set /a a=%random%
    set /a b=%random%
    set /a c=%random%
    set /a d=%random%
    set /a e=%random%
    set /a f=%random%
    set /a g=%random%
    set /a h=%random%
    set /a i=%random%
    set /a j=%random%
    set /a k=%random%
    set /a l=%random%
    set /a m=%random%
    set /a n=%random%
    set /a o=%random%
    set /a p=%random%
    set /a q=%random%
    set /a r=%random%
    set /a s=%random%
    set /a t=%random%
    set /a u=%random%
    set /a v=%random%
    set /a w=%random%
    set /a x=%random%
    set /a y=%random%
    set /a z=%random%
    goto a
    gata2
    5 years ago on Step 3
    put mode 1000 on this
