How to Repair a Dremel VersaTip's Igniter
17,804
31
20
After a couple of years of heavy use my Dremel VersaTip's igniter broke, allowing me to use the tool but having to use a lighter or a match to fire it up, since it's an excellent and handy tool, i couldn't let it go that easy without at least trying to fix it.
The Result:
The tool is back in business!
Supplies:
Step 1: Tools Needed for the Job
- An old lighter (or new, but you have to make sure to empty it first carefully).
- A Torx #7 screwdriver.
- Spare tiny cable (single wire)(you can even use the one that came with the original igniter).
- Electrical tape.
- Fine tweezers.
Step 2: The Problem
A broken igniter
Step 3: The Disassembly
Note of precaution: MAKE SURE THAT THE BUTANE CANISTER IS EMPTY BEFORE STARTING
- Unscrew the Catalyst. Flame Guard, Flame Guard Nut and the Ceramic Insulator.
- Use the T7 screwdriver to remove the 4 screws on the side of the Dremel VersaTip.
- Carefully remove the side cover (avoiding that some of the pieces fall from their place).
- Separate the nozzle from the back cover but don't remove the hose
Pay attention to the next step because there is a tiny piece of metal with a rod attached to the center of the trigger.
- Remove the trigger by simply lifting it (Be careful, the big spring attached to the igniter will jump out of it's place).
- Remove the little piece of metal with the rod in the middle (Don't separate them).
- Remove the damaged igniter and save the big spring.
Step 4: Getting the "New" Igniter and the Preparation
Take the EMPTY lighter and start taking it apart using some force, but don't break the whole thing so you won't make a mess or damage yourself (there are a few videos in YouTube).
Recover the igniter from the lighter.
The old igniter's cable is 1 3/4" (4.5 cm), so we need to extend the new one to that length by cutting a piece of the old one, peel it and attach it to the cable of the "new" one make sure you secure it with some electrical tape to avoid risks later.
Make sure to peel the end of the cable so it will drive the current and work the way it is suppose to be, the peeled tip should be around 1/8" (4 mm).
Step 5: Reassembly
- Start with placing the igniter back into place, making sure that the naked part of the cable fits in the proper place (us the tweezers to place the end of the cable where it belongs).
- Slide the metal rod into the trigger.
- Place back the big spring.
- Adjust the trigger back into place.
- Make sure everything fits back where it belongs.
- Place the side cover back in.
- Place the screws but don't tighten too much.
- Screw the Tip, the Flame Guard, the Flame Guard Nut and the Catalyst back.
- Test it.
Step 6: Done!
Hope you liked this Instructable and please leave your feedback.
Thank You.
    • Arduino Contest 2019
    • Woodworking Contest
      Woodworking Contest
    • Party Challenge
      Party Challenge
    20 Discussions
    GavinS53
    Question 9 months ago on Step 6
    Thanks for the photo and info. I have a brand new unit and it won't light. The spark is working is down inside, not up near the gas hold on the shaft. I tried taking it apart and adjusting but nothing I do will make it start lighting. Gas is flowing, but the spark will not strike high enough.
    If anyone has any ideas please advise.
    GavinS53GavinS53
    Answer 9 months ago
    UPDATE: I did make it light my moving ignitor wire around. It seems the flexible one does not have a defined seat point and I'm guessing the spark is jumping where it should not. I moved it up a bit, it's not reliable, but I can get it lit now.
    raulmaesGavinS53
    Reply 9 months ago
    Try extending the metal rod a little bit, then attach the flame guard and it will place the rod where it should be, there is a tiny flap in the metal ring that covers the ceramic catalyst, try pushing it a little bit down, maybe the spark is not reaching the inner tube of the catalyst
    As an additional info, the flame guard needs to be tightly secured because it conducts the current from the rod to the flap
    AzimZ
    Tip 10 months ago on Step 5
    For those having problem with wobbly flame or yellow flame try this out. It works for me.
    Requirements
    1.small syringe
    2.alcohol
    Take out the nozzle that attached to hose, get the alcohol into syringe and attach the small end nozzle to the syringe (it fit really well ) and start pushing :) easy..hope it works for others
    PhilipL64
    11 months ago on Step 6
    My versatip was always really hard to start but I thought that was because I was running propane. I took it apart and discovered the tube wasn't even attached. Thanks for the pics. They were helpful for showing where things should go. Tbh I didn't follow your instructions and I removed the flow rate adjuster screw. I don't recommend this because there is no real need. Anyway if you end up doing this make sure you screw it all the way back in and make sure the circular silver piece of metal doesn't move while the screw is lose or it will put the calibration out. If you have already put the calibration out you can restore this in 1 of 2 ways. The first way is to disassemble the versatip down to the point where you just have the butane tank / handle with brass tube sticking out with a circular brass looking piece of metal at the base. You should see a single dent in the side of the circle. This is where the flow adjusting screw was seated from the factory. So all you need to do is put the circular silver piece of metal on and line up the flow rate adjusting screw hole with the dent in the middle. The other option is to leave it all assembled and losen, adjust, tighten the flow rating adjusting screw until you get the flow range you want. The problem with the second option is you will create multiple dents in the inner brass circle which will remove your option of returning it to the factory setting at a later date.
    raulmaesPhilipL64
    Reply 11 months ago
    I’m glad you fixed the problem with the instructable, and I’m quoting you, because I missed this during the instructable, this is very important: “Anyway if you end up doing this make sure you screw it all the way back in and make sure the circular silver piece of metal doesn't move while the screw is lose or it will put the calibration out.”
    Thanks for the detail
    LuizB19
    1 year ago on Step 6
    You do not even think how this tutorial helped me !!!
    Thank you!!!!
    ZideYT
    3 years ago
    My Igniter broke as well, I might try doing this soon. But there is a second problem. After filling it up with fresh Butane again, the flame looks weird. It doesnt look like strong, stable jet flame, but rather like a wobbly lighter flame from normal lighters. The flame sometimes isn't even blue anymore. Does anyone have a similar problem?
    raulmaesZideYT
    Reply 3 years ago
    I think that you have 2 problems here... first, the tip of the nozzle might be dirty or clogged, try cleaning it with a needle and remove any sediment, and second, the butane you re using might not be from good quality, you should use a good butane to avoid sediments ar anything in the nozzle, you should also check that the hose is in good shape and well attached. Hope this can help you
    ZideYTraulmaes
    Reply 3 years ago
    I tried cleaning the Diffuser, the part that mixes the gas with some oxygen to create a blue flame with abrush, I'll try cleaning it with chemicals soon, maybe with vinegar. So far, the flame is still yellow, kinda looks like a small flamethrower rather than a jet flame. Maybe better butane will work, but I will comment when I finally found a solution.
    By the way, I tried your Instructable to replace the igniter, at least it ignites the flame every time I press now!
    nanodeathZideYT
    Reply 1 year ago
    Have you found a solution? I have exactly the same problem. Everything was cleaned in ultrasonic cleaner, then with acid and alcohol and checked. Gas was removed and tank fulfilled with best what was on market. No change! Flame looks like burning just on a tip and doesn't look like jet flame.
    raulmaesnanodeath
    Reply 1 year ago
    I haven't experienced the problem myself like others that posted in this Instructables, but maybe the problem it's the quality of the gas, quick question, are you sure you are using butane? I was using the butane from the zippo's brand and it works perfect, but I just moved to another country and found another brand that doesn't says it contains butane but just universal gas lighter refill, I hope it doesn't clogs the catalyst
    ZideYTraulmaes
    Reply 3 years ago
    martinhironaga
    3 years ago
    Thanks for the instructable. After opening up the side cover, I tried clicking the trigger and noticed that a spark was being generated but it wasn't coming out at the end of the metal rod but further down closer to where the rod passes through the trigger. I then discovered that the rod was not seated properly within the plastic groove below it, so I pushed it down with my 2mm flathead screwdriver and "voila"—when I depressed the trigger the spark came out at the end of the thin metal rod. After putting it all back together and refilling the tank with butane, I held my breathe, pulled back on the trigger and it lit up instantly! Saved me much time and a little money by not having to buy a lighter. If I hadn't followed your instructions to open up the side cover, I would have never discovered the simple problem with my Versatip.
    hamsammy
    3 years ago on Introduction
    Glad I found this! My ignitor works about 5% of the time and I've only had is 5 months! I click and click and click and finally it will come alive!
    raulmaeshamsammy
    Reply 3 years ago on Introduction
    I'm glad this instructable is helpful, you should check the grounding rod, maybe is not making proper contact with the flame guard which is the one that transfer the current to the catalyst, use a tweezer to slide it out, this has happened to me before, also try to clean the catalyst maybe the butane is not flowing properly, hopefully this might help you, please let me know
    raulmaes
    4 years ago
    I never thought of removing the piece of the child safety, sounds like a really good idea! Sounds like an extra work for my Dremel 400 XPR, jeje thank you petercd for the tip
    And thank you MsSweetSatisfaction for the comment
    petercd
    4 years ago on Introduction
    Thanks, its always nice to see the insides. I got annoyed by the blue child safety piece and cut it off, my youngest is 23yr, so not really something I'm worried about. :)
