How to Clean Rust Off a Knife
Published
Introduction: How to Clean Rust Off a Knife
About: I'm a Texan living in South Africa as a missionary with my family working along side Samaria Mission
This method may not work for folding knives but it does work on fixed blades
Now let’s get started
Step 1:
You will need:
Rag Vinegar
Bowl or cup
Steel wool
Primer or coating for knife
Warning the vinegar removes any coating you may have on your blade.
Step 2:
Get a rag that can wrap around your blade at least twice
Step 3:
Get a bowl or cup put the rag and vinegar in it
Pull the rag out and wring it out. So it’s wet but not dripping and not damp
Wrap the rag around the blade only the blade and leave it for at least an hour
Step 4:
1 HOUR LATER
Unwrap the blade and use the steel wool on the rusty spots
Once down you can add the coating or primer if you want
I personally left mine the way it was which I think it gives more of a worn look to it
    • Oil Contest
      Oil Contest
    • Game Life Contest
      Game Life Contest
    • Water Contest
      Water Contest
    4 Discussions
    iceng
    3 months ago
    Sadly I have a full rust coated simple plier that coke did not help..
    You could try this method. But make sure the rag is wetter or you could woke the whole plier in a bowl of vinegar
    Yes just normal vinegar. Also if a knife is coated in rust I’m not sure if this will work but if it have rust spots on it it should work
