How to Fill an Office With Packing Peanuts
109,376
189
64
Ever wanted to fill your co-worker's office with shipping peanuts?
Of course you have. But then you realized just how much work it would take (and how much a pain clean-up would be), and decided it wasn't worth the effort.
We came up with a better way. Here's how to make them think you've actually done it.
Supplies:
1. Roll of tape
2. Scissors
3. Roll of paper
4. Packing peanuts
5. Small box with at least 3 flaps intact
Method:
1. Roll out a strip of paper horizontally along the bottom of the frame
a. Be sure to leave enough space for the tape to overlap the bottom of the frame so the peanuts don't spill out the bottom
2. Tape left, right, and bottom edges
3. Fill the box with packing peanuts
4. Open 3 flaps with the one at the bottom inside the paper
5. Pour peanuts in
6. Pat the paper to help 'settle' the peanuts to fill in the gaps so you don't see the paper backing
7. Roll out next strip of paper
8. Repeat steps 2-6 as necessary
9. To finish it off leave some slack at the top so it bulges out a bit
a. This helps to give some depth at the top so you can make a pile of peanuts at the top, aiding the illusion
Optional:
1. Close the blinds - too much light bouncing around the room reduces the illusion
2. Stuff packing peanuts under door - blocks light as well as discovery that the room is actually empty by peering under the door
3. Rig paper 'tube' from door frame to back of door and fill with peanuts, spilling out when the door is opened
4. Place something heavy behind the door - gives resistance when the door is opened
5. Rig a waterfall of packing peanuts to spill out when door is opened
Thanks to Jim and Paul for masterminding the operation; double thanks to Jim for writing up the instructions, and to Chris for being a good sport!
Supplies:
    • Woodworking Contest
      Woodworking Contest
    • IoT Challenge
      IoT Challenge
    64 Discussions
    max1234ita
    3 years ago
    Nice, but I didn't get one point: after having sealed the door and put something heavy behind it to increase its resistance... how do you leave the room? O-O
    AtrusMmax1234ita
    Reply 2 years ago
    Pull the item with a rope of some kind that you can snake under the door, perhaps? Haven't tried it but that would be my best guess.
    SidA2
    3 years ago
    HAHA this is funny and creative at the same time.
    Researchr
    3 years ago
    That was great! I think that it will work on an office with just a single window. I am going to do it with 1/8" thick birch plywood, popcorn glued to the top edge to disguise the top of the "dam". Just high enough that a passerby, couldn't see over it. I think that it'd be good for a permanent office prop or common room. It brought a big grin to my face... Life's too short.
    mikeb270
    3 years ago
    (and how much a pain clean-up would be) trust me most office people do not worry about this as it is a well known fact that they are not made to clean-up after themselves that's what the cleaning grunts are for
    Nachoman
    6 years ago on Introduction
    That one is one sweet prank! If somebody did it to me, I wouldn't undo it!
    Logic
    11 years ago on Introduction
    This is also possible in a normal, freestanding cubicle! Take a sheet or large strips of paper and tape them about 4 inches down from the top edges of the cubicle walls. You want to create a "roof" inside the cubicle, which you then cover with packing peanuts. Do the same for the entryway, add a layer of plastic wrap and fill in between with peanuts. It looks like the whole cubicle is filled to the brim!
    ToolboxGuyLogic
    Reply 6 years ago on Introduction
    Sweet! I do recommend powering off any equipment in the cubicle before enclosing it.
    winkmanLogic
    Fantastic. :) Can't wait to do this one day. :P Business-associates beware... :P
    RishnaiLogic
    Reply 11 years ago on Introduction
    I would laugh so hard if I saw that done. If it happened to me, I'd want to know why I suddenly have a cubicle, and WHY THE HELL IS MY CUBICLE FULL OF PEANUTS!?!?!?!?!
    Exocetid
    Brilliant. Be sure to be ready with video for that first gasp out of the victim!
    nmcrae1
    I filled a friend's locker at work with peanuts - we laid the locker on it's back on the floor, filled it and stuffed them in tight and shut the door, then stood it back up in it's normal place. When he opened the locker it almost exploded with foam peanuts all over the locker room. it was HILARIOUS, even though we were finding peanuts for years afterwards..... and we still laughed about it whenever we found one....
    im3733
    7 years ago on Introduction
    serves the additional purpose of providing insulation/"curtains" for the office. this looks like it would be a fun one to implement.
    jbenfield
    8 years ago on Introduction
    A more flexible approach (though considerably more work) is to glue a couple of layers of packing peanuts onto large sheets of white construction paper. You can then do things like top off a cubicle, place them on the inside of an elevator door or in the doorway of an office without windows. The effect is even better if you pull some saran wrap over the top of the "tiles" to make it look like the only thing holding them in is the plastic wrap. It also makes for fast set-up and tear down. Great if you have a whiny office mate that's going to complain to management and drag them back to the desecrated office. The evidence is gone in a matter of a minute or two. It's even more fun if you leave one lone packing peanut on the whinger's desk to taunt them.
