How to Get Fresh Water in the Wild
26,056
166
41
When you're in the wild with no immediate source of water you might wanna try this method. Of course if you want to live. Dehydration will kill you if you don't have a good water source. You may survive without food for a while but, if you are dehydrated you will surely die soon. In this Instructable you will learn how to collect water through evaporation. This method is easy and can be done fast.
You'll need a few things:
  • a shovel ( if you don't have one and you're in the wild you can always use something else. e.g. Your hand)
  • a cup
  • vegetation
  • a tarp/some sort of plastic covering
  • rocks/can also use the soil you've dug up
Supplies:
Step 1: Diggin' a Hole
Dig a hole about the size of the one in the picture. It doesn't have to be big. The depth of the hole should be about 1 1/2 feet deep. Do this in the morning because the more water you lose by sweating the more you need to replace.
Once you've dug a hole take your cup and put it in the center of the hole. The cup should be pretty shallow, not like 2 inches high, 'cause you won't collect enough water and it will overspill.
As you see in the picture I used a tin can. I cut in the middle about 2 inches deep so that it will not be level with the surface above the hole. You will see why later.
Step 2: Vegetation
Find really green leaves around your surroundings. Put them in your hole around the cup that you've placed in the middle. Make sure that you fill the hole with a lot of vegetation. When the sun rises in the morning and all the way until sun set the sun will make that water inside the plants to evaporate and collect at the top of the covering.
Step 3: Covering
Make sure that you're covering will stretch over the hole and cover everything. Place rocks or dirt on the side of the covering so that the covering will stay in its place. Carefully place a small pebble in the middle of the covering above the cup. The pebble will channel the water that evaporated on the inside of the covering into the cup.
Over tidewater will be sucked out of the vegetation and into the cup.
AAHHH!
Sorry was I too loud?
I just had a fresh, clean drink from my cup.
You should try this if you have no source of water around. This method is easy, cheap, fast, and reliable, so use it!
Live off the Land Contest
Runner Up in the
    • Woodworking Contest
      Woodworking Contest
    • Classroom Science Contest
    • Party Challenge
      Party Challenge
    41 Discussions
    JpsManCave
    2 years ago
    Great Instructable!
    PaulS28
    2 years ago
    Clear plastic is absolutely critical as it allows the infrared rays
    to enter and warm the soil/vegetation rather than being converted to
    heat on the plastic which escapes to the surrounding air.
    While
    the hole doesn't have to be deep, the deeper it is the greater the
    surface area from which water can be extracted and the more moist will
    be the soil. A hole four feet in diameter is preferable to one that is
    two feet in diameter for the same reason but would have to be deeper to
    maintain the slope of the plastic down to the can.
    Seal the edges of the plastic with a mound of soil to prevent as much vapor from escaping as possible.
    A
    rubber tube from the cup/can up and out of the hole at the edge of the
    plastic sheeting allows you to drink without destroying your setup.
    Always recycle your urine and this works with salt water also (deserted island scenario :) )
    RobertP231PaulS28
    Reply 2 years ago
    It will work better with clear plastic, yes, but it is NOT "absolutely critical." It will work with opaque plastic as well. In the Army, we learned to use dark green plastic ground cloths for this as well as both green rubber and camouflage nylon ponchos as well. All will work. The key is to trap heat and moisture beneath a smooth covering that will funnel condensation to the low point of the covering for collection.
    PaulS28RobertP231
    Reply 2 years ago
    I explained why you want to use clear plastic - you want the infrared rays to reach the foliage and the soil inside the hole. Will opaque work? Probably but not as well. If I have the choice of wearing a transparent rain poncho or an opaque one as I bug out, I'll choose the transparent for precisely that reason or I'll carry a sheet of transparent plastic in my BOB if I feel I need to wear camo rain gear.
    At any rate, there's no need for us to argue the point, everybody should go out and actually do it to develop the skills and practice is a great time to try both ways to see which works best so you know what to carry.
    RobertP231PaulS28
    Reply 2 years ago
    There is,nothing to argue about. I already said clear plastic eill work better, but simply pointed out that it is not "critical" as you said it was. It definately (not just probably) does work with opaque materials, including materials that are not made of plastic. They only have to be water resistant. We were taught, demonstrated and practiced this as part of basic survival training. I only made the point because people need to know you can still do this in an emergency even if you don't have clear plastic.
    MADsighNtist
    2 years ago
    Note: many places speak that you must "Boil Water" for five minutes, to be safe.
    This is simply not true, no pathogens live beyond 186 degrees, and there are several companies that sell a special gauge that identifies that heat.
    Also the Least Expensive piece of equipment one can own for outdoor water, is made by Sawyer Products. Originally designed for Kidney Dialysis machines, it was Too Narrow to pass blood, so they studied their invention, presto, good for 100,000 Gallons. yes 100,000 Gallons. less than $30.00
    RoBear613MADsighNtist
    Reply 2 years ago
    "no pathogens live beyond 186 degrees"
    This may well be true, but you cannot SEE the difference between 100 degreed F and 186 degrees F. But you CAN see the difference between 210 degrees F and 212 degrees F because the water boils. So, without any "high tech" devices (like a thermometer, lol) you can just boil the water.
    MADsighNtistRoBear613
    Reply 2 years ago
    Yes, a Well Taught person can differentiate those tempetkres, I have spent a Life Time studying Thermal Output of a variety of materials, Water being only one of them.
    But Please Note: OLD thought BOIL for five Minutes
    RoBears613 suggestion: "you CAN see the difference between 210 degrees F and 212 degrees F because the water boils." NO Mention of time . . . In the situations being spoken of, the Addition use of Fuel is a WASTE, as is the the thermal motions above 186 degrees.
    In Survival Mode a PRIME Factor is ~To Conserve~ Everything Practical . . .
    However, its your life, Live it your way by all means.
    Me: making Camp since 1962.
    RobertP231MADsighNtist
    Reply 2 years ago
    To MadsighNtist: The point was that if you boil the water, you don't need to know the temperature because the boiling tells you that the temperature is more than high enough, so no thermometer needed (and no, you can't tell the difference between 100 F and 186 F water just by looking at it, no matter HOW "well taught" you are). Also, both bacterial and fungal spores can survive even boiling water for a few seconds, and may survive 186 F water for an extended period of time; but neither will survive boiling for five minutes. That's why that recommendation exists. Also, boiling for five minutes will also rid the water of toxic volatile chemicals that will boil away quickly at 212 F.
    jooly4MADsighNtist
    Reply 2 years ago
    Thank you for your information. What was the piece of equipment called?
    MADsighNtistjooly4
    Reply 2 years ago
    the Sawyer Company makes the Newest Concepts in Water Purification. a Variety of Prices, based upon size, etc.
    In my Rural Setting I Must use Water Purification, and I use a $30 Sawyer, it removes the RUST from the +80 year old piping, and provides clear water.
    I trust the water for showering, dishwashing, etc, but like rust free for drinking.
    Sawyer Filtration systems are sold in Wal-Mart and other large stores as well as online.
    Hope that helps
    ~~ Old Geezer
    bart01jooly4
    Reply 2 years ago
    https://sawyer.com/products/sawyer-mini-filter/
    RobertP231
    2 years ago
    Of course, if you're dying from thirst you probably won't worry about such things, but otherwise you need to be careful to use very clean plastic for sanitary reasons or you could wind up with dysentery or worse. You should also ideally use a non-toxic plastic like polyethylene or polypropylene. If you use something like industrial grade vinyl, toxic plasticizers can leach into the water you collect. It may not kill you, but it wouldn't be good for you either. Also, while you will get more water by lining the hole with vegetation, it will still work without any vegetation at all, so long as you dig deep enough to reach even slightly moist soil.
    bannerjoseph
    2 years ago
    It is amazing that there are so many incredibly talented people that create new ways to solve problems on Instructables.
    RobertP231bannerjoseph
    Reply 2 years ago
    While a goid Instructable, there is nothing new about this. Soldiers and survivalists gave known this trick for centuries (perhaps even millennia, because tanned leather and waxed burlap or other fabric will work in lieu of plastic, not as well, but they will work). I learned to do this over 50 years ago in the Boy Scouts, and again 40 years ago in the US Army.
    flaming fox
    2 years ago
    nice one my friend
    good job on your work
    Dawsie
    2 years ago
    i remember doing this when we went camping in the GirlGuides back in the 70's lol it was a fun project to do we also learned how to make a bush oven to cook bread and meat ? I voted for you just for bringing back some very fun memories when we did bush servival lol thanks
    Blue-JazzIFIAandy
    Reply 2 years ago
    Thanks IFIAandy. Pls tell others to vote too. :)
    IFIAandy
    2 years ago
    nice one blue-jazz.
