How to Get Started With CNC
34,186
422
24
About: I'm an inventor / maker / designer based in the Bay Area. My background is in residential architecture, film set design, animatronics, media arts, exhibit design, and electronics. I use digital design and fa...
This instructable is a lesson in my free CNC Class. To enroll, click here.
In this lesson, we'll go over how to get started with CNC. We'll get acquainted with the basic concepts of CNC by turning a photograph into a 3D relief sculpture. I'll demonstrate this process using a script with Fusion 360.
What You'll Need
Fusion 360 (Mac / Windows)
What You'll Do
  1. Download and install Fusion 360. Sign up as a Hobbyist / Enthusiast / Startup to get it for free.
  2. Get a quick orientation of the user interface.
  3. Download and install a script that will let you turn a 2D image into a 3D surface.
  4. Use the script to create a 3D surface for CNC milling.
Step 1: Why Fusion 360?
Fusion 360 is pretty much all I use nowadays in terms of 3D software. FULL DISCLOSURE: Fusion 360 is an Autodesk product, and Instructables is an Autodesk company, so this might seem like a biased choice. That's not exactly the case, and here's why:
  1. It's easy to learn. The UI has been carefully designed from the ground up to be clean, minimal, and simple. You can go from zero knowledge about 3D modeling to making simple objects in an afternoon.
  2. It's powerful. Once you get through the basics, there's really no limit to the complexity of the things you can design with it. It's easy to create simple models with it, but there's nothing holding you back from modeling a fully articulated gas engine if you want to.
  3. It's cross-platform. It's available on Mac and PC, and it's proven to be very stable on both platforms in my experience.
  4. It's great for CNC. Fusion has a super sophisticated CAM environment that lets you create all kinds of tool paths, which we'll get into later. It's really awesome to have the CAD and CAM together in the same program, because when you change your model, the tool paths update automatically.
  5. It's free. If you make less than $100K per year using it, you just renew with a startup license every year and keep using it free of charge.
  6. It's not a web app. Though all your files are backed up on the cloud and rendering is taken care of there, you don't have to rely on a high-speed internet connection to use the program.
I've been 3D modeling for over 13 years, and I can tell you honestly that this program is perfect for the kind of work I do: furniture, toys, machines, household products, etc. It makes digital fabrication a breeze, especially laser cutting.
There are a number of other programs out there that could be used to produce the same results, and if you're comfortable with something else (especially if you've already paid for it), there's no reason why you shouldn't stick with it. But if you haven't spent any money or invested time in another program, believe me when I say you won't be sorry you went with Fusion 360.
Step 2: You Got This!
3D modeling can seem intimidating if you've never done it before. Like anything else, though, if you start slow with a simple project and keep practicing, you'll be creating complex designs before you know it.
Here are a few pointers to help you along:
  1. Be patient: 3D modeling can be frustrating in the beginning because the process is foreign. If you can get in the habit of asking yourself why the program isn't doing what you want instead of getting mad at it, you'll learn faster and enjoy it more.
  2. Learn the vocabulary: Like anything else, a quick Instructables or Youtube search will likely answer your questions quickly when you're stuck. Do they call it a "line" or a "curve"? Is it a "surface" or a "face"? The tricky part is knowing what to search for! Pay attention to the terminology, and you'll learn much faster.
  3. Think in steps: Everything you create can be broken down into a series of steps. The lessons in this class will lay these out for you with all the example projects, but when you move on to your own work, continuing to think this way will be very useful. How do you eat an elephant? One piece at a time!
  4. Solve one problem at a time: The most difficult part of 3D modeling is translating what's in your head to what's on the screen. If you think of your project as a series of connected parts and tackle one of them at a time, you'll save yourself from being overwhelmed.
If you practice regularly and challenge yourself, you'll be designing your own work in a matter of weeks. I promise.
Step 3: Get Fusion for Free
  1. Follow the link to download Fusion (don't use the App Store on Mac).
  2. Enter your email and download the free trial.
  3. Install and setup a free Autodesk ID account.
  4. When you open Fusion, select the Trial Counter in the upper toolbar.
  5. In the next dialog box, select "Register for Free Use".
  6. Sign up as a Start-Up or Enthusiast (Free). You can also Sign up as a Student or Educator (Free) if you're a student or educator at a registered institution.
  7. Select the "I accept Terms and Conditions" checkbox and click Submit.
Step 4: The Fusion Interface
Fusion 360 has a great Youtube channel with lots of helpful videos. If you're the type of person who likes to learn software by going through every function it can perform, this channel is a good place to start. The overview here should get you pretty well oriented to the interface and give you an idea of how the program works.
But before we dive into a full-fledged 3D model, I'll quickly run through the interface.
PRO TIP: Use a 3-button mouse! It's so much easier than using a trackpad.
  1. Application bar: Access the Data Panel, file operations, save, undo and redo.
  2. Profile and help: In Profile, you can control your profile and account settings, or use the help menu to continue your learning or get help in troubleshooting.
  3. Toolbar: Use the Toolbar to select the workspace you want to work in, and the tool you want to use in the workspace selected.
  4. ViewCube: Use the ViewCube to orbit your design or view the design from standard view positions.
  5. Browser: The browser lists objects in your design. Use the browser to make changes to objects and control visibility of objects.
  6. Canvas and marking menu: Left click to select objects in the canvas (the space where you make your models). Right-click to access the marking menu. The marking menu contains frequently used commands in the wheel and all commands in the overflow menu.
  7. Timeline: The timeline lists operations performed on your design. Right-click operations in the timeline to make changes. Drag operations to change the order they are calculated.
  8. Navigation bar and display settings: The navigation bar contains commands used to zoom, pan, and orbit your design. The display settings control the appearance of the interface and how designs are displayed in canvas.
Step 5: Canvas Navigation
There are three ways to manipulate the view of your design:
  • Navigation Bar
  • ViewCube
  • Wheel button on a mouse
Navigation Bar
The navigation bar is positioned at the bottom of the canvas. It provides access to navigation commands. The menus on the right end control Display Settings and Layout Grid options.
To start a navigation command, click a button on the navigation bar.
Navigation Commands
  • Orbit: A set of commands that rotate the current view.
  • Look At: Views faces of a model from a selected plane.
  • Pan: Moves the view parallel to the screen.
  • Zoom: Increases or decreases the magnification of the current view.
  • Fit: Positions the entire model on the screen.
Display Settings
Set of commands that enables you to specify desired visual style, visibility of objects, or camera settings, for example.
Grid and Snaps
Commands that allow you to specify increments, grid settings, and show / hide the layout grid.
Viewports
Viewports are windows that display your design. You can show up to four viewports in the canvas at once. Displaying multiple viewports allows you to work in one view and see the changes from other camera positions.
ViewCube
Use the ViewCube to rotate the camera. Drag the ViewCube to perform a free orbit. Click faces and corners of the cube to access standard orthographic and isometric views.
Mouse: Use mouse shortcuts to zoom in/out, pan the view and orbit the view.
  • Scroll middle mouse button to zoom in or zoom out.
  • Click and hold the middle mouse button to pan the view.
  • Shift Key + middle mouse button to orbit the view.
Trackpad: If you have a Mac with a touchpad or an Apple Magic Mouse, you can use multi-touch gestures to navigate the view.
  • Pinch to zoom in.
  • Spread to zoom out.
  • Two finger drag to pan.
  • SHIFT + two finger drag to rotate.
For more help with the UI, click here.
Step 6: Image-2-Surface Script
"Script" is shorthand for a bit of code that you can plug into the program to give it a new tool that wasn't included by the software developer. There are dozens of scripts that allow you to do some pretty awesome things.
To translate a 2D bitmap image to a 3D surface for CNC milling, we're going to use the Image-2-Surface script written by Hans Kellner.
The script is very simple. All it does is translate the value (level of lightness or darkness) of a bitmap image to the height of a point on a mesh surface. The white parts of an image will be the highest points, and the black parts will be the lowest points. This script will work with any photo, but I find it's best to use grayscale images because it's easier to predict what it will look like in 3D.
INSTALL THE SCRIPT
First, download the Zip file attached belo and unzip it in a location of your choice. I would advise keeping it some place other than the Downloads folder, or any other folder that is regularly cleaned out.
To load the script in Fusion, follow these steps:
  1. Start Fusion 360 and then select the ADD-INS > Scripts and Add-Ins... menu item.
  2. The Scripts and Add-Ins dialog will appear and display the My Scripts and Sample Scripts folders.
  3. Select one of the My Scripts folders, then click on the + icon near the top of the dialog.
  4. Locate the Image2Surface.js file in the folder you copied, select it, and click Open. The script should now be installed and ready to be run.
Scripts and Add-Ins Menu
Step 7: Use the Image 2 Surface Script
RUN THE SCRIPT
After opening Fusion, I save the untitled file with a new name.
With my file saved, and the Workspace set to MODEL, I go to ADD-INS > Scripts and Add-Ins... I select Image2Surface from the list and click Run.
CHOOSE A BITMAP IMAGE
The script opens a window where you can choose a bitmap image. I'm using a topographical map of the Monterey Canyons in Santa Cruz.
IMPORTANT: the image should be a small size. The higher the resolution, the more points on the mesh, which means slower performance or crashing. The image I'm using is less than 300 X 300 PX and seems to work fine. Notice also that the image is blurred- this makes for a smoother mesh.
To find good images for practice, just do a google search for "depth map image" and you'll see lots of images that are ready for this kind of work.
If you want to follow along, you can right-click and download the image below and use it to create your 3D surface.
Monterrey Canyon File: 288 X 288 PX
SETTINGS
When you've selected your image, click OK and you'll get the Image2Surface script dialog. Here's a breakdown of the settings and what they mean. There's a lot of technical jargon that we won't get into here, but I find that a good place to start learning about this kind of thing is to just play around with the settings and see what happens. The settings shown in the screenshot below seem to yield the best results.
You may want to invert your image depending on what it is. When your settings are dialed in, click OK, and the script will make the surface. IMPORTANT: Export format must be set to OBJ in order for the surface to be usable for CNC work later.
Mesh created by the Image-2-Surface script by Hans Kellner
TROUBLESHOOTING
Is Fusion freezing or crashing when you try to run the script? Chances are, your image is too large. Keep it under 300 X 300 pixels and it shouldn't be a problem. The smaller the image, the faster the processing.
Step 8: Convert Surface to T-Spline Geometry
The surface the script creates is a Polygon Mesh surface. This type of surface is made up of facets with edges and points. If you zoom in, you'll see that there are no curved surfaces.
This type of geometry can't be used to make g-code toolpaths, so we'll need to convert it to T-Spline geometry. A t-spline is a type of NURBS geometry that works with control points that affect a flexible surface.
You're going to need a T-Spline geometry to create your CNC tool path, so click the CREATE > Create Form tool from the menu. This tool takes you into the SCULPT workspace.
Next, click UTILITES > Convert and select Mesh Body in the Selection Filter. Now click the mesh surface that the script created and click OK. Now it's time to be patient and let the program do its work converting the surface to a T-Spline body- it might take a couple of minutes.
Click FINISH FORM and Fusion will go back to the MODEL workspace.
PLACE THE SURFACE WITHIN A BLOCK
In order to better visualize what you're going to cut out on the CNC, it's a good idea to create a solid form. First, select the surface in the Bodies folder in the BROWSER on the left-hand side of the screen. Then Right-Click anywhere on the screen and select Move from the menu.
Looking at the surface from the side, rotate it 90º so that the top of the surface is facing up.
The size of the surface is based completely on the original bitmap image, so now you'll need to scale it to fit the actual size of the piece you want to cut out. To do this, make sure the body is selected in the BROWSER and go to MODIFY > Scale in the menu. Click Point and select the model origin.
NOTE: You may need to turn on Origin in the browser in order to see it.
Looking at the surface from the Top view, change the Scale Factor so that the surface fits within the size of the piece you want to cut out. I'm going to use a 3" X 3" piece of wood, so I'm looking for a scale factor that will give me a surface that's just slightly bigger than 3" X 3". I can see how big it is on the layout grid.
Now that the surface is in place, create a box to represent the material to be cut out. I'm using a 3" X 3" X .76" square, so I go to CREATE > Box and click the model origin as my starting point. The box command asks for a width, a depth, and a height, which you can enter by typing a number and pressing Tab.
I can see that the surface to be cut is actually taller than the material to be cut, so not I need to scale the surface down in the Y dimension. I use the Scale tool again, and change Scale Type to Non Uniform. This option will let you scale in any dimension independently. For Y Distance, Choose a number that gives you some breathing room for the surface to fit within the block.
To move the surface closer to the top of the block, Right - Click > Move the surface up in the Y direction so that it's just below the top of the block.
CREATE A SOLID SURFACE
With both the block and the surface in place, go to MODIFY > Replace Face. Like every other tool in Fusion, it tells you what it needs to work. First, select the Source Face, which in this case is the top surface of the block. Then, click Select under Target Faces and select the surface you just converted from the original mesh. Click Okay, then turn off the original body in the BROWSER and you'll see the finished surface that you'll be making on the CNC.
Step 9: Recap
So far, this is what we've covered:
  1. How to download and install Fusion 360 with a free license.
  2. A quick orientation of the user interface.
  3. How to install a script for extra features.
  4. How to generate a 3D surface from a 2D image for CNC milling.
In the next lesson, you'll learn how to create a toolpath (cutting instructions the CNC machine can read) in Fusion 360.
  • Fandom Contest
    Fandom Contest
  • Party Challenge
    Party Challenge
  • Classroom Science Contest
24 Discussions
benge10
2 years ago
Having fun with this class but get the following error message when trying to convert surface to T-Spline geometry. Any help would be appreciated.
JON-A-TRONbenge10
Reply 2 years ago
Fusion can't convert triangular faces, only quads. The script should turn the image into quads automatically. I'm not sure why you're getting triangles, but an easy way to convert the mesh is to export it as an STL, open it in Autodesk Remake, then export it from there as a Fusion - OBJ - Quad file. If you upload that back into Fusion, it should convert to t-splines with no problems.
RalphxyzJON-A-TRON
Reply 2 years ago
could you send me a nag for taking the class, it is all so interesting and someday I will need it but not now, so it is not high on my to-do list but maybe with some nagging....
Ralphxyz
2 years ago
"I can see that the surface to be cut is actually taller than the material to be cut, so not I need to scale the surface down in the Y dimension"
Shouldn't that be Z dimension?
JON-A-TRONRalphxyz
Reply 2 years ago
You would think so! For some reason, just about every 3D modeling program has Y as the up-axis. You can change it in preferences, but it's so common you actually spend less time rotating things if you just stick with the default.
RalphxyzJON-A-TRON
Reply 2 years ago
Great article thanks. None of my 3D experience ever had Y as the up-axis. X front back Y left right Z up down. If you do not believe Y should be up down why promulgate the idea? Or is that Fusion references the axis?
JON-A-TRONRalphxyz
Reply 2 years ago
I used to always set the up axis to Z in every program I used, then once when I was working at an architecture animation company, one of my colleagues pointed out that if I worked that way, all of the other assets the company already had and most of the assets that we would import from elsewhere would come in with the wrong orientation. Since then, I just stuck with Y-Up for everything to avoid having to reorient other objects that come in from elsewhere.
JON-A-TRONJON-A-TRON
Reply 2 years ago
That being said, if you're starting out with a new program and not planning on coordinating a lot of models for import, it makes way more sense to have the Z up for the rest of the time you use it.
RalphxyzJON-A-TRON
Reply 2 years ago
Thanks for the replies, that is very interesting.
I will stick with X Left/Right Y Front/Back and Z Up/Down
lassensurf
2 years ago
In the email I saw the picture and thought to myself, that looks like the underwater Monterey Bay Canyon.
I'm kinda a nerd like that (if I'm right)
JON-A-TRONlassensurf
Reply 2 years ago
Good eye! I looked it up and you're right. Thanks for catching the error.
lassensurfJON-A-TRON
Reply 2 years ago
I got distracted before I could even finish reading all your steps the other day, I didn't see that you did name it! I didn't mean to call it an error, I don't have any problem with what you did call it. It's all good. :-)
I'm either proud or ashamed of myself for recognizing it so readily. (It is a REALLY cool looking formation, after all. Good choice) Super cool project!
Reply 2 years ago
No, you were right- you just saw it after I corrected it.
agate9999
2 years ago
The download page does not have a space for hobbyist or Enthusiast. How do you get to the free download if your a senior adult whose hobby is to use machine equipment to make things?
FloridaJo
2 years ago
Another option for software is Blender. There is also a script for CAM in Blender. And it's free open source software. It's a steep learning curve, but if you keep at it, you'll love it. 3D, 2D laser cut scripts, as well as an amazing render engine.
JON-A-TRONFloridaJo
Reply 2 years ago
You can do a lot of cool stuff in Blender, for sure. I prefer Fusion because it's got mechanical assemblies, solid modeling, and an awesome sculpting environment.
