How to Make a Bandsaw Scoop
6,352
138
11
About: i am Patrick from Patrick's Work Shop on youtube where i like to build lots of cool shop projects and other fun projects click on the link to see more https://www.youtube.com/user/Patricksworkshop
I came up with a really cool way to make a wooden scoop with a bandsaw.
its a really fun and easy project you should try
things you will need :
-chunk of wood ( I used a piece of fire wood) but you can get fancy
-bandsaw
-beltsander
-sand paper
-a finish of your choice
Step 1: Preparing the Material
In the first step you want to square up your board using a table saw and you will want to make sure you get this piece square on all six sides .the size of the scoop determines how big of a board you will use in this project
Step 2: Lay Out and Cutting Out the Handle
In the step you will draw a "U" shape on the end of your blank.
And now using your bandsaw cut on the line as clean as possible doing the cut in a single smooth pass staying on the line
this step is critical the "U" shape you first cut out will be the handle so be sure to make a clean cut
Step 3: Cutting the Scoop
in this step cut the outside 'U' shape doing the same as the last step
you will be left with this last picture shape, thats the scoop part
cutting this step close to the line will make for less shaping and a thinner "U" shape makes for a nicer looking scoop
Step 4: Setting Up for Glue
ok now that you have the 2 pieces you need you will put them back together and pull the handle piece back to form the scoop
check for a tight side that will be the side you glue together
Step 5: Marking Handle Depth and Glue Up
now you will need to mark a line about 3/4 inch inside the scoop to have a spot for glue without getting glue past that point
this is the time to sand the inside of the scoop so grab some 150 sandpaper and sand the inside smooth to the touch.
and now your ready to glue the handle piece in ,apply a small amount of good glue to the spot you marked out with a pencil and join the handle to the scoop then clamp it with a clamp or in my case my bench vise
( take note any glue past the line will make the finish blotchy so be sure to clean up all squeeze out )
Step 6: Handle Layout and Cutting
ok now that the scoop has dried you can start to shape it
first mark on the handle a nice handle shape then take it to the bandsaw to cut all four sides to shape
be sure to not cut in to the scoop past the handle
Step 7: Shaping and Sanding
ok now its time to refine the shape by sanding it
I used a bench top belt sander to do this and it made it fast and easy
you will shape the handle and the scoop to final shape and round over the top as well take you time and try to get it as nice as possible
Step 8: Applying a Finish
after you finish sanding with the belt sander you will sand with finer sandpaper till it feels good in your hand
after all the final sanding is done you can apply a finish
if you plan to use this on food you will want to use a food safe finish
I used a spray lacquer on mine as it was on hand
now you have a awesome scoop you made by hand enjoy and thanks for checking out my Instructable
thanks for checking out my bandsaw scoop please check out my youtube channel for more awesome builds
Link in my bio
    • Tape Contest
      Tape Contest
    • Gardening Contest
      Gardening Contest
    • Arduino Contest 2019
    11 Discussions
    WaltF2
    1 year ago
    good job on the scoops, going to have to make a bunch for Christmas
    Bolajidal
    3 years ago
    Good Patrick
    KellyCraig
    3 years ago
    I just made a stack of scoops for friends. Mine had apple scoops, acacia backs and fir or other handles. In short, they were three pieces.
    One advantage of my approach was, I could sand the inside of the scoop with my spindle sander. Of course, this approach also allowed me to incorporate some contrasting woods.
    From the first run, I decided I wanted thicker backs so I could have more options for attaching handles. In short, I have been mulling over different approaches to mass producing these [on a small scale for friends and associates]. As such, I was glad I came across your approach.
    I really like the simplicity of your approach and the soft flow of your scoops to their handles. Too, I see how the handle portion could be turned, on a lathe, then returned to the scoop for assembly.
    Great job. Thanks.
    CurtR
    3 years ago
    Well done video, easy to follow and a nice little project , thumbs up .
    HobbyJim
    3 years ago
    Great scoops. I have a few questions:
    What model is your bandsaw? It looks very efficient.
    What grit do you have on your belt sander? It works fast but not too aggressive.
    Great vice. What make is it?
    patricksworkshopHobbyJim
    Reply 3 years ago
    thanks Jim ok first off my Bandsaw is a harbor freight 2006 model year 4 speed and I like it, it runs great
    my belt sander is my dads old one from 1988 and it has a 3/4 hp motor and i keep a 120 belt on it and it seems to work real good
    the vice was my dads as well he had it since 1968 and now i have it in my shop it is a Colombian machinist vice
    i hope that answers all you questions if you have any more feel free to ask thanks so much
    Lauchazo
    3 years ago
    Great instructable! Thanks for sharing. Would you mind telling us a bit about the jig you used on the tablesaw?
    patricksworkshopLauchazo
    Reply 3 years ago
    i have a vid on my Youtube channel about that here is a link https://youtu.be/14RZ8JHw5AE thanks for checking out my page and if your looking for more awesome stuff subscribe to me on youtube
    bricobart
    3 years ago
    Very intelligent. You gave me another argument to invest in a bandsaw.
    seamster
    3 years ago
    This is an excellent technique. Gonna have to make a couple myself. Thanks for sharing the idea!
    acheide
    3 years ago
    Well done instructions and nice scoop.
