How to Make a Go Kart / Electric Car Using PVC Pipe at Home
21,187
35
26
Build your own Go-Kart at home. Now just because you don't need a full welder, you will still need some power tools to cut wood. Go-Karts: They're the most fun a kid can have on four wheels. I have got the plans and list of parts you need to build one for your family and have the kids cruising around before sundown.
source: Navin Khambhala # crazyNK
Supplies:
Step 1: List of Materials
1. 1" (25mm) PVC pipe and coupling
PVC pipe: 30 feet, PVC Tees: 27 pieces, Elbow: 16 pieces, 4-Way: 6 pieces, 45 degree Elbow: 8 pieces, PVC cap: 5 pieces
2. Plywood
Size: 120 cm X 64 cm
3. 18V DC Mega Torque Geared Motor
Speed: 300 RPM, Watt: 250W, Torque: 92 kgcm
4. Bicycle wheel
Quantity: 4 pieces, size: 14" (inches)
5. Motor Shaft Coupling
Quantity: 2 pieces, size: 8 mm to 10 mm
6. Ball Bearing
Quantity: 10 pieces, Type: 6201-2RS
7. Door hinge (360 degree)
8. PWM DC motor speed controller
Ampere: 40A
9. 12V DC Battery
Up to 40Ah
Step 2: Make the Base Structure From Wood and PVC
Step 3: Arrange the Wheel on Base Structure Also Attach Motor to It
Step 4: Make a Turning Mechanism and Attach the Steering
Step 5: Attach the Battery and Speed Controller
Step 6: Attach Seat to Go Kart
Step 7: Go Kart Is Ready for Ride !!!!
2 People Made This Project!
  • IoT Challenge
    IoT Challenge
  • Gardening Contest
    Gardening Contest
26 Discussions
Blechgourmet
Question 20 days ago on Introduction
Hello. Where can I order the motor? In Germany I can't find one with 250w and 18v.
LIKHITAJAY
2 months ago
CAN WE GET THE TOTAL PDF OF THE GO KART WITH THE PREMIUM
I MEAN THE COMPLETE PROJECT REPORT
CraigS183
Question 2 months ago
What do you call that metal bar in the front that turns the wheels from left to right
CraigS183
Question 2 months ago on Step 4
What do you call that pipe things that turns the front tires from left to right
AylahI
What are the dimensions of the wood cuts?
uthayyan
Question 4 months ago on Introduction
Can I get the circuit of the pvc go kart ...?
KetulP5
What is the DC motor & dc motor control's cost ..?
sudhirk40
5 months ago
How much weight it can carry easily??
ErtrE1
Question 6 months ago
can you link to all the parts?
Legends4321
Question 8 months ago
When I attached my front wheels I used a different hinge and the wheels keep falling out every time I sit on it and the are also really wobbly. Can you please give a link to the hinges you used.
niraj.lalsangi
8 months ago
from were u purchased motor and price
total project cost ???
Bilotta
8 months ago
What kind of switches did you use to make it go and adjust the speed?
ClaudianIss
Question 9 months ago on Step 7
Disculpa venderás el kit completo, para que yo sólo lo arme ?
TigistA
Question 9 months ago on Step 3
What kind of moter use inside the wheel Base stracture
Kendre kelly
Question 9 months ago on Step 4
Your screws the dimensions u used for go kart
Rajkanna
Question 9 months ago on Step 5
How to fix speed controller with motor
