How to Make a Penny Battery
1,952
29
This is a short Instructable that will demonstrate how to create power for a calculator from common household items. Feel free to do this process for any small electronic device such as a flashlight, battery powered clock, Tamagotchis, etc. Ensure the device in question is low voltage (3V or less), or you may not be successful. Lets get started!
Step 1: Collect Supply
All of the supplies needed should be pretty easy to find:
- Zinc Washers (3)
- Pennies (3)
- Cardboard Circles (penny size)
- Wire (2)
- Tape
- Ziploc Bag
- Water
- Salt
- Device Requiring Power
*NOTE*
In this project, we at least needed 1.5 Volts of battery for the calculator to work. Each penny battery is 0.6 Volts. Therefore, we needed three penny batteries.
Step 2: Cardboard Soakin'
In this step, you will need three cardboard circles (the size of a penny) and place them in the Ziploc Bag. Add some water and a good amount of salt to the bag. Let the cardboard soak for a few minutes while you continue on to other steps until these pieces are needed. (This step may take some trial and error)
Step 3: Set Up
In this step, you will need those two wires (preferably different colors) and the object needing battery(calculator). Attach the two wires to the positive and negative side. For me, I connected the white to the positive side and black to the negative side.
Step 4: Taping
You will need to add a piece of tape to the end of the positive side and place the penny on top, making sure the wire and penny are touching.
Step 5: Adding All of the Needed Items
Now stack the little items in the following order until you have no more (I had to do this three times but you may need more or less Volts depending on what you chose to power):
1.Penny(you have already placed)
2.Cardboard (soaked in salt water)
3.Washer
Step 6: The Product
Voila! Your little penny battery should be working and you can use your little gadget for awhile, when it starts fading, repeat Step 2.
    • Woodworking Contest
      Woodworking Contest
    • Party Challenge
      Party Challenge
    • Classroom Science Contest
    3 Discussions
    gm280
    2 years ago
    I am sure it works because making little power supplies like that do work. But the electronic item you are powering is also solar powered as well. It says so on the unit. So did you disconnect the solar power first? Certainly not complaining, just asking.
    mrsmerwin
    2 years ago
    We made these years ago but we never tried them on anything other than a tiny light bulb. I did not realize that these could actually be used.
    That is really cool that you could power s calculator with pennies.
