How to Make a USB Laptop Keyboard Controller
9,093
35
21
About: I am a retired Boeing engineer that enjoys experimenting with Pi & Teensy projects.
This Instructable will provide a step by step procedure for building a USB laptop keyboard controller. I created this guide and video to hopefully make it easier for people to re-purpose an old laptop. A typical laptop keyboard relies on the motherboard for the scanning circuitry. I use a Teensy microcontroller mounted on a connector board to take over this function. Teensies are often used by the mechanical keyboard enthusiasts at Geekhack and Deskthority and the TMK software is the most popular controller code. The TMK code is a bit of an overkill if you just want a simple USB keyboard but it will certainly provide all the features you could ever need. If you would rather write your own keyboard software using Arduino, the Teensyduino functions give you total USB control. Whatever software you decide to use, it will require a key matrix that maps out how your keyboard is wired. One approach, (that I never want to do again) is to exhaustively check every connector pin combination with an ohm meter while holding down each key. I did this when I converted a Sony Vaio into a Raspberry Pi laptop. An Instructable from alpinedelta disassembles the keyboard in order for the connections to each switch to be visually traced back to the connector. Instead of taking the keyboard apart or using an ohm meter, this Instructable will load the Teensy with an automated continuity tester. The Teensy will report over USB, the two pin numbers that are connected when you press a key. After every key has been pressed, the results can be transferred to a row-column matrix and used by the TMK keyboard controller software or a home-brew Teensyduino routine.
I will include download buttons for the relevant files in the Instructable but you can also go to my GitHub repository to view and download all files.
Supplies:
Step 1: Keyboard Cable Specifications
Laptop keyboards use a flexible printed circuit (FPC) that connects all the key switches in an array of rows and columns. The two bins of laptop keyboards shown above are from Re-PC, a local recycling store. About 75% of the keyboards have FPC cables that end with exposed metal traces on one side and a plastic backing on the other side. The plastic backing plus the FPC material measure about 0.33 mm thick. A typical keyboard without a number pad has 24 or 25 signal traces with a 1 mm pitch. If there is a number pad, then it’s common to have 26 traces with a 1 mm pitch. A few of the keyboards at Re-PC had 30 to 34 traces and some had a 0.8mm pitch. Connectors for 24 to 34 pin keyboard cables are readily available from companies like Aliexpress or Digikey. The number of signal traces and the pitch are the parameters you will need when ordering. There were some old keyboards in the bins with rigid printed circuit board connectors and some other keyboards with specialized connectors soldered to the end of the FPC cable. These keyboards will not be the focus of this Instructable.
Step 2: Modify Your FPC Cable As Needed
Some FPC cables need to be modified to fit in a generic connector. Locking nubs on the side of the cable are easy to remove with wire cutters. If the FPC traces don't line up with the connector pins, use an X-ACTO knife to trim along the side of the cable. The Dell Latitude D630 keyboard needed the most modifications. It had a solder-less connector on the end of the FPC cable that was easily removed. Then I pulled off the extra thick plastic backing that was glued on the end of the cable and cut a notch on the side to align the contacts. To bring the thickness back to normal, I glued 2 pieces of paper to the end of the cable.
Step 3: Teensy LC FPC Connector Assembly
I designed a circuit board using Eagle for the Teensy LC that routes its 26 I/O pins to 26 surface mount pads for an FPC connector with a 1mm pitch or a 0.8mm pitch. A 24, 25, or 26 pin FPC connector can be soldered to this board based on your needs. I avoided using the 27th Teensy LC output because it’s connected to an LED and 27 pin FPC connectors are rare.
After soldering the FPC connector to the board, I soldered 4 header posts to the board to support the corners of the Teensy and then I soldered the Teensy to the header posts. The last step was to connect the rest of the Teensy I/O signals to the board with 30 gauge wire. I used wire instead of header posts to make it easy to cut the Teensy off the board, if necessary. The Teensy pads that must be connected to the board are marked with a small line. Don't forget to put a wire on I/O's 24, 25, and 26.
Step 4: Teensy 3.2 FPC Connector Assembly
All of the signals for the Teensy LC are routed on one side of my board so I designed the other side for a Teensy 3.2 with 34 I/O signals and an FPC connector with a 1 mm or 0.8 mm pitch. If you need all 34 pins, you must unsolder the LED on the Teensy 3.2 to free it up for use by the keyboard.
Solder the FPC connector to the 3.2 side of the board and then proceed to the next step.
Step 5: Teensy 3.2 Surface Mount Pads
The Teensy 3.2 uses surface mount pads for 10 of the I/O signals so it’s a little more work to solder them to the board. Solder “flying leads” to the surface mount pads on the Teensy 3.2 and then pass each wire thru the corresponding pad on the board for soldering. Finish the assembly by soldering wires to the remaining I/O signals marked with a small line.
Step 6: Order the Board and Components
You will need header pins, wire, solder, flux, and a USB cable for this project in addition to the main components given below:
  1. The Teensy LC is $15.53 or the Teensy 3.2 is $23.49 from Amazon. You can also order direct from PJRC.
  2. The FPC connectors from AliExpress are about $5 for a lot of 5. An example search on their website would be “laptop keyboard connector 1.0 spacing 24 pin”. Digikey is another possible source for connectors.
  3. The Keyboard_Scanner.brd and Keyboard_Scanner_LT.brd files can be downloaded below or from my repo. The Keyboard_Scanner_LT board file has pads for a 2 bit level translator in case you want your Teensy LC to talk to a 5 volt touchpad (see schematic above). If you don't want the level translator, order the other board or just leave these pads empty. Fabrication of the circuit board costs $18 from OSH Park for a lot of 3 purple boards, or $14 from DirtyPCBs for their "protopack" lot of about 10 red boards, or $7 from JLCPCB for 10 green boards, all shown above. OSH Park fabricates the boards in the United States and my order took 12 days to arrive in Tacoma, Washington. DirtyPCBs are fabricated in China and it took 28 days for the boards to be delivered. JLCPCB is also in China and they took 18 days to ship the boards. If you don’t need to make any modifications, then you can send the Eagle file directly to OSH Park or DirtyPCBs. To fabricate with JLCPCB, I used EasyEDA to upload the Keyboard_Scanner_LT file and convert it to a public project that you can use to purchase boards from JLCPCB (see next step for details). DirtyPCBs and JLCPCB offer HASL for the surface finish which is cheaper than the ENIG finish used by OSH Park. The different PCB surface finishes are explained in this Optimum Design Associates post.
    Check out the next step for information on a Group-Buy that brings the cost of the board down even more.
Step 7: PCB Group-Buy
The first group buy from DirtyPCBs and the second group buy from JLCPCB have sold out. I have ordered another 10 boards from DirtyPCBs that should arrive in a month. If you want a board and live in the United States, send me an email at thedalles77@gmail.com. The cost for 1 board is $2.00 with U.S. shipping. For those outside the US, you should order directly from JLCPCB. I have uploaded and converted the Eagle board file to EasyEDA and made it a public project to make it easier for you. Click on the "Register" button so you can create an account. Once you've registered and activated your account, go back to my public project and select "open in editor" and click on the G in a box that stands for generate fabrication file (Gerber). It will ask if you want to run DRC and you should click "No, generate gerber". There are DRC errors but they are not "real" and don't impact the fabrication process. The next window gives the quantity, thickness, color, finish, and weight that I leave at the default settings. Click the box "generate gerber" then after it downloads the zip file, get back to the same window and click the box "order at JLCPCB". You'll need to allow pop ups so you can see their order form. You can see all the settings and click "save to cart". From this point on it's just like ordering anything from the internet.
One last requirement: Try really really hard to actually build a keyboard controller with the board and send in a picture of your finished project to the "I made it" link at the end of this Instructable. If you have any problems, let me know and I'll help you out.
Step 8: Load the Continuity Tester Into the Teensy
  • Follow the PJRC link for installing Arduino and Teensyduino on your computer.
  • Download the Matrix_Decoder Arduino code. Use file Matrix_Decoder_LC.ino for a Teensy LC or Matrix_Decoder_3p2.ino for a Teensy 3.2.
  • Load the Matrix_Decoder code into the Arduino integrated development environment (IDE).
  • Connect a USB cable from the Teensy to the computer. Your computer should automatically load the necessary USB drivers.
  • In the Arduino IDE, under “tools”, select board: Teensy LC or Teensy 3.2/3.1 depending on what you’re using. Also under “tools”, select USB type: Keyboard.
  • Compile and load the Matrix_Decoder code into the Teensy. If it’s your very first time loading the Teensy, you’ll have to push the button on the Teensy to enable the loader.
  • Disconnect the USB cable from the Teensy.
Step 9: Load the Key-List File in the Editor
Open a text editor on your computer. I like to use Notepad++ on Windows or Geany on the Pi because they have column editing.
Original Method:
There are two “key-list” text files you can download, named Keyboard_without_number_pad and Keyboard_with_number_pad. The “key-list” file should have every key that you will push followed by tabs to make the results more readable and easy to copy into a spreadsheet.
New Method:
Marcel Hillesheim has written a Python program that takes much of the manual labor out of my original process. Marcel's GitHub repo has a Python program and two blank key-list files that use the PJRC key codes. If you're comfortable running Python, download his key list text files and the matrixgenerator.py Python program. It will save you a lot of time.
Modify as needed:
You may need to modify the key list file slightly to match your keyboard’s keys. A non-US keyboard can still use this routine, just make a list of your keys and the Teensy will report pin connections. The GUI key is either the "windows key" from a PC or the "clover key" from a Mac. Place the cursor to the right of the very first key in the list as shown above. This will determine where the Teensy begins to display the pin numbers as you push each key.
Step 10: Connect the FPC Cable
Inspect your FPC connector to determine the correct orientation for the cable.
If your FPC connector matches the picture on the left, use your finger nail to gently lift the connector locking bar to the open position. Slide the FPC cable into the connector with the bare metal contacts pointed down (closest to the board) and the plastic backing strip pointed up. Lock the cable to the connector by gently pushing the bar down. The locking bar mashes the bare metal of the FPC cable down against pins on the connector.
If your FPC connector matches the picture on the right, use your finger nail to slide the locking bar to the right. Insert the cable into the connector with the bare metal contacts pointed up and the plastic backing strip pointed down. The orientation is opposite from the first picture because when the locking bar is slid to the left, it pushes the cable up against pins on the top of the connector.
Connect a USB cable from the Teensy to the computer and wait 20 seconds for the Teensy to be recognized as a USB keyboard. This delay is in the code to make sure your computer is ready to receive numbers from the Teensy. If numbers are reported on the screen before any keys are pressed, these pins are shorted together and must be fixed. If you have an FPC cable with more than 26 signals, it may use some of the extra traces for grounds, back-lighting, or a track-pad. This may cause the test routine to register two pins as shorted. If this happens, you’ll need to do some code modifications to exclude these pins. The code normally scans all pins starting from pin 1 and ending at the last pin but you can adjust these variables to avoid shorts.
Step 11: Test the Keyboard
Press each key, one by one on the test keyboard as listed on the editor screen. The Teensy will send two pin numbers over USB that were connected when the key was pressed. The Teensy will then send a down arrow to position the cursor for the next key. After pressing every key on the keyboard and confirming that pin numbers were given for all, save the finished file for analysis. At this point you've created a very thorough keyboard tester.
The original key list on the left gives every key and the results are in columns for transfer to a spreadsheet. Marcel's key list on the right uses the PJRC key names to make it easier for his Python program to build the matrix. If a key is listed that is not on your keyboard, use your mouse or arrow keys on your PC to move the cursor to the next key. The Python program jumps over the unused keys so there's no need to edit them out manually.
Step 12: Determine Input and Output Pins
If you are using Marcel's Python program, it will automatically incorporate the basic "rules" given below. Make sure the completed key list file is in the same directory as the Python program when you run it.
The following manual procedure will determine the keyboard pins that will be Teensy inputs and outputs. This procedure is based around the Modifier keys; Control, Alt, Shift, GUI, and Fn. As a general rule, 8 of the keyboard pins will be inputs to the Teensy and the remainder will be outputs. The Modifier keys usually have an output row all to themselves which allows these keys to be held down while other keys are pressed. This avoids a sneak path which would cause ghosting. These “rules” are not always followed (especially by the Fn key) so you may need to do some trial and error as you build the matrix. I have lots of keyboard examples at my Github repo to help you out.
Control-Left and Control-Right will have a common pin between them. Example:
Cntrl-L 19 20
Cntrl-R 20 22
The common pin, Pin 20 in this example, will be a Teensy output, and 19 & 22 will be inputs.
Similarly Alt-Left and Alt-Right will have a common pin between them, just as Shift-Left and Shift-Right will also have a common pin. Example:
Alt-L 7 24
Alt-R 7 15
Shift-L 21 23
Shift-R 23 25
The Alt common pin will be a Teensy output, and 15 & 24 will be inputs.
The Shift common pin will be a Teensy output, and 21 & 25 will be inputs.
The GUI key is usually a single key as in this example;
GUI 9 26
Search all the other pins in the list to see if 9 or 26 are used on other keys. In this example, pin 9 was not used for any other key which means it will be a Teensy output and 26 will be an input. Sometimes both pins are used for other keys but one of the pins is used for common keys like letters and numbers and the other pin is used for less-common keys like page-up. In this case the pin used for common keys will be a Teensy input and the other pin will be an output. Note that the GUI key will still work if you swap the pins.
The Fn key is also a single key as in this example;
Fn 12 18
Using the same approach as the GUI key, search all the other pins to see if 12 or 18 are used on other keys. In this example, pin 12 was not used for any other key therefore it will be an output and 18 will be an input. If both pins are used on other keys, follow the same rules as the GUI example. Sometimes both of the Fn pins are used by common keys which means you can pick either pin as an input and the other as an output.
The eight input pins for the HP DV9000 example keyboard have been identified as; 15, 18, 19, 21, 22, 24, 25, and 26. All other pins will be Teensy outputs. Make a keyboard matrix table like the one shown above with the 8 input pins across the top in ascending order and all the other pins as outputs on the side, also in ascending order.
The orientation of the keyboard matrix is just my personal preference. You can swap the rows/columns and inputs/outputs if you want. Swapping pins may be necessary if you have a rare laptop keyboard that has diodes for each switch. With diodes, you need to make sure the cathode (first pin listed) is designated an output from the Teensy and the anode (second pin listed) is designated an input to the Teensy.
Sometimes only 7 pins can be identified as inputs because two modifier keys share the same input pin (usually the Shift-R and Control-R). If this happens, you’ll have to make an educated guess for the 8th input. For some keyboards, the input pins are grouped together (i.e., 17 thru 24) which makes it easy to fill in the missing pin. Other keyboards have no grouping of pins which means you’ll have to begin filling out the matrix with only 7 inputs. The missing input pin will reveal itself when some of the keys can’t be placed in the matrix.
Step 13: Fill the Matrix With Keys
To fill the matrix, place each key name at the row/column intersection of the pins as shown in the HP DV9000 keyboard example given above. The modifier keys are in bold to make it easy to see that they have a row all to themselves. This keyboard followed the “rules” exactly.
You don't need to fill out the matrix if you're using Marcel's Python program. The HP DV9000 results that were output from the Python program can be downloaded below.
The 8 FPC input pins and 18 FPC output pins are listed along with the corresponding Teensy I/O numbers.
There are separate matrix tables for the Normal keys, Modifier keys, and Media keys. Everything is formatted for easy cut and paste into my homebrew USB keyboard controller routine.
Step 14: Translate FPC Pin Numbers to Teensy I/O Numbers
Marcel's Python program automatically translates the FPC pins to the Teensy I/O's. If you are using the manual method, you will need to use the Teensy LC or 3.2 tables shown above.
Step 15: Load a USB Keyboard Routine Into the Teensy
A Deskthority post from "flabbergast" describes using the ChibiOS development environment to configure TMK for ARM based processors like those used on the Teensy LC and 3.2. A toolchain such as the GNU ARM Embedded Toolchain is used to compile the code for the Teensy LC or 3.2. You will need to install the ChibiOS development environment per these instructions. The teensy_lc_onekey example details the steps to create a working TMK build. The QMK keyboard routine is based on TMK and it also has ChibiOS support for the Teensy LC and 3.2.
The TMK/QMK keyboard software is very powerful with tons of features but it can be confusing, (at least to me). As an alternative, I wrote an Arduino USB keyboard routine using the Teensyduino “Micro-Manager” functions. There's just 1 file to load using the Arduino IDE and it's only about 375 lines with lots of comments. I'm a hardware guy so expect ugly code but it provides a basic keyboard controller with 6 key rollover that you can modify to suite your needs. The detailed instructions named "How to modify the Teensyduino LC code" and "How to modify the Teensyduino 3p2 code" describe the changes you need to make for your matrix. These instructions also detail how to use the results from Marcel's Python program.
Every keyboard listed below has a folder at my repo containing a pin connect list, key matrix table, and a Teensyduino USB keyboard routine giving you lots of examples to follow. Use the links to my repo to view and download these files. The 1525, 2100, and DV9000 folders also have Marcel's completed key list file and the results from his Python program.
Olga has modified my code for a Commodore 64 keyboard. The Teensy LC code, key list files and project description are in a folder at my repo.
Step 16: Non-Standard FPC Cable Connectors
If your keyboard has a non-standard FPC cable like the Lenovo connector shown above, the task becomes more challenging. If you can't find a mating connector at Aliexpress or any other site, your only alternative is to remove the connector on the laptop motherboard. A common method is to put flux and low melt solder on all the joints, then use a hot air rework station and tweezers as shown in this video. You will need to make a board layout that routes the Teensy I/O signals to your keyboard connector. I like to do a preliminary layout on paper first in order to place the parts and route the signals with the fewest via's. It's easy to assign the Teensy I/O pins in software based on whatever pin order makes the layout work best. It's tempting to make the layout next, but do the schematic first so your layout will have air-wires showing you how to route each trace. I didn't make a schematic for the keyboard scanner board because of the confusing front side LC/back side 3.2 routing. The downside of not having a schematic was the lack of any verification that the layout was electrically correct. I had to triple check everything before sending the file out for fab.
KiCad, PCBWeb Designer, EasyEDA, and DesignSpark PCB are some of the free layout tools that are available. I've chosen to use Eagle and I pay a monthly subscription of $15 for a commercial license. If you don't need a commercial license, you can download the freeware version of Eagle software. Sparkfun has excellent tutorials for Eagle schematic and layout. Also look at the Adafruit tutorial on creating parts in Eagle because you'll need to make a package and symbol for your connector. After you get your layout fabricated, you'll need to change the Matrix_Decoder software to work with the new I/O pin-out.
Step 17: Teensy 3.2 Controller for a Lenovo Thinkpad T61 Keyboard
A perfect example of a non-standard FPC cable is the 44 pin connector used on the Lenovo Thinkpad T61 laptop. There are at least three web sites that detail how to make a USB controller for a Lenovo keyboard. An Instructable from rampadc uses a connector board with some glue logic and wires to an Arduino. A later Instructable from rampadc uses a single board with an MSP430 microcontroller. Mark Furland from Tome uses a connector board with wires to an Arduino. Mark's web site states that a Digikey WM6787CT-ND connector will work with the keyboard FPC cable. This saved me from having to unsolder the connector from the motherboard. It was pretty easy to search online and find a schematic for this laptop due to its popularity. Without the schematic or the info from rampadc, I would have been doing a lot of probing with an ohm meter to determine the ground pins and narrow down which pins needed to be scanned for the key matrix. I really like the feel of this keyboard which made it worth the effort to design the Teensy 3.2 circuit board shown above. I modified the Matrix_Decoder scanning software to only scan the 8 input pins and 16 output pins from the matrix. You can use this scanner code as a guide if you have a keyboard with lots of grounds and more pins than your Teensy can handle. The scanning software produced a connection list that was turned into a key matrix table using the same steps described earlier in this Instructable. The Fn switch has its own two pins on the connector that are scanned separately from the key matrix. The Trackpoint on the keyboard needs PS/2 clock and data signals from the Teensy plus a reset signal when power is applied. The Teensy 3.2 is 5 volt tolerant so it can directly drive these signals. All of the T61 3.2 files are at my repo or can be downloaded with the buttons below.
Step 18: Teensy LC Controller for a Lenovo Thinkpad T61 Keyboard
I wanted to build a standalone T61 Keyboard on a block of wood but the 3.2 circuit board from the previous step needed the connector and Teensy re-positioned so the circuit board would be hidden underneath the keyboard. I figured while I'm at it, I should change over to the LC and save some money. The Teensy LC has fewer I/O signals and they are not 5 volt tolerant so I needed to make some design changes. I adding a TLV810 to generate a reset for the trackpoint plus a couple BSS138 FETs as level translators for the trackpoint clock and data. To save an I/O pin, I wired the Fn switch into an empty cell in the matrix so it can be scanned with all the other keys. There was one Teensy I/O pin left to drive the Caps Lock LED. All of the T61 LC files can be downloaded from my repo or use the download buttons below.
Step 19: Building a Keyboard Base
If you're not going to use the original laptop base for your USB keyboard, you can build a wood base like the one shown above. I used a chisel to pound out a cavity for the Teensy LC controller board that is hidden by the keyboard. You'll have to drill a hole into the cavity for the USB cable and glue rubber feet on the backside. If you have a wood router, you can inset the entire keyboard down into the wood.
Step 20: Conclusion
Converting a keyboard to USB is the most complicated piece of the laptop to get working. The LCD can be converted to VGA or HDMI using an M.NT68676 video converter card. I've got one of these boards driving an HP LCD that I mounted in a picture frame (shown above). The touchpad PS/2 signals can be converted to USB by the Teensy. I have written touchpad code that utilizes the Teensyduino USB mouse functions. I merged the touchpad code with the Dell Latitude D630 keyboard code to give you an example of a "USB Composite device".
In addition to standalone keyboards, picture frames, or Raspberry Pi laptops, another use for your old laptop is a portable VGA display with USB keyboard and touchpad. My friend troubleshoots servers at various locations and needs to connect a keyboard, video, and mouse (KVM) to the server rack. Instead of borrowing a display from his customer or leaving one in each server room, he carries a modified laptop that I built. The broken laptop motherboard was replaced with a VGA converter card that drives the LCD. The keyboard and touchpad have been converted to USB using the methods from this Instructable.
This KVM was so popular that I built a second one that also has a Raspberry Pi inside. Check out my Instructable that describes the steps to build a basic and a Pi KVM.
I hope you find this Instructable useful for re-purposing your old laptop. Leave a comment below or send me an email at thedalles77@gmail.com if you have any questions, comments, or corrections.
Good Luck
Frank Adams
  • Classroom Science Contest
  • Gardening Contest
    Gardening Contest
  • Woodworking Contest
    Woodworking Contest
21 Discussions
N0rka
7 weeks ago
Hi,
Great work !
If you would like - basing on Your work, I have rewritten Your code to support a list of keys without need to create a matrix, and with any key that can be set as modifier.
I have done it especially to support Commodore C64 keyboard; changing the list of keys will easily support Commodore C16 keyboard.
Tried to create pull request on your repo, but have no access rights.
Please contact me void@buntownik.pl if You are interested.
Cheers !
Frank_AdamsN0rka
Reply 7 weeks ago
Sounds great, I'll contact you by email to get the details.
Thanks
TomášJ58
3 months ago
Hi Frank,
thanks for a great tutorial!
Do you have a design pattern for the circuit board you use? I you do, you would spare the time going through measurement etc. I would like to have the circuit printed near by me.
Have you ever done 30pin keyboard? I would like to make external keys from dell 9370 keyboard. Maybe also bluetooth, if its possible.
Do you have any tips?
Feel free to contact me at jabaduba23@gmail.com :)
Thanks for the answer!
Frank_AdamsTomášJ58
Reply 3 months ago
Yes I created the design pattern for the circuit board and the Teensy 3.2 side of the board will work with a 30 pin FPC keyboard.
You can download the design pattern named Keyboard_Scanner.brd using the link at the bottom of step 6. Many circuit board manufacturers will accept the Eagle board file directly so you won't need to convert to GERBER format. If you install the free Eagle layout software from autodesk.com, you can take measurements and even make modifications or file conversions if necessary.
Your Dell 9370 keyboard FPC cable may have nubs on the side that are used to lock the cable in the motherboard connector. If you're using a generic 30 pin FPC connector, you will need to trim off those nubs. You could use a 34 pin FPC connector and center the 30 pin cable in the middle so you don't need to trim the nubs. This keyboard has a backlight and maybe some other circuitry with grounds so you may need to modify the Matrix Decoder software to exclude these pins otherwise the code will hang because it detects two pins as shorted and it will wait (forever) for the short to go away.
Sorry, I don't know of an easy way to add Bluetooth to this keyboard.
Let me know if you have any more questions.
Good Luck
TomasJ59Frank_Adams
Reply 2 months ago
Hi back! I overlooked the design patter.
Got the circuit printed in my area and soldered teensy on it. But ran into a problems. Like You said, 2 side pins are solid connected //=shorted. But neverthless the pins in the middle do not work as expected imo. I tried to test it - if I push the button on a keyboard, "del" for instance, I should get another shorted circuit between specific 2 other pins. Correct? But when I use ohm meter, there is no shorted circuit among any of the pins on the FPS (not counting 2 pernamently shorted side pins). How do I get the signal of key pressed from a keyboard like this? Can you think of any solution what to do?
There is also an extra FPC cabel with 4 pins (might be used only as 2, at least it look like so, see the attached image). But it's a keyboard with backlit, so I suppose its just for passing the power to lightning.
Thanks for reaction,
Tomas
Frank_AdamsTomasJ59
Reply 2 months ago
Hi Tomas, the code will hang when it finds a short and not proceed to scan any other pins so you’ve got to fix the problem. I’ve had lots of shorts and this is my method to finding (or excluding) them:
First make sure you have no shorts without the keyboard connected to the board. I’m assuming you have loaded my Matrix_Decoder_3p2.ino code into your Teensy 3.2. Open an editor on your PC and hook up the USB cable. After 20 seconds, if your board has any shorts, the connector pin numbers will be reported on the editor screen. I’ve had solder hairs that I couldn’t see but scrapping between the FPC connector pads with a dental pick, cleared the short. If you have no shorts on the board, make sure the code reports two pin numbers when you touch a wire between two of the Teensy I/O pins.
If the shorts only show up when you hook up the keyboard cable, try re-positioning the cable to make sure you have the connector pins aligned in the center of the FPC traces. If the two shorted pins are at the side of the FPC cable (which is what you have), they may be grounds and you will need to exclude at least one of them in the Matrix_Decoder_3p2.ino code.
An example would be if pin 1 and pin 30 are both grounds. They will be reported as tied together but they are not needed for scanning the key matrix. In this case, set the min_pin integer on line 44 to 2 and the max_pin integer on line 43 to 29.
This method works if the shorts are at the edges of the FPC cable. If you have grounds throughout the cable like on a Lenovo T61 keyboard, you will need to switch to the Matrix_Decoder_T61.ino program. It has a list of pins that are scanned instead of scanning sequentially from min to max.
I think you are correct that the small cable is for powering the backlight.
Let me know how things are going and I'll try to help you out.
You can send me an email with any test results or pictures.
Good Luck
Frank
tcaschy
3 months ago
Thank you very much for this! Works great!
Frank_Adamstcaschy
Reply 3 months ago
Glad to see you got it working. Thanks for posting a picture.
Solarcycle
5 months ago
This could lead to a revolution in DIY laptop builds! Bring the headphone jack back!
Frank_AdamsSolarcycle
Reply 5 months ago
More DIY laptop builds is exactly what I was going for. In addition to reducing waste, experimenting with a broken laptop is a great way to learn about electronics. And yes, you can "bring back the headphone jack".
SolarcycleFrank_Adams
Reply 5 months ago
I just created a 3D CAD tutorial on how to design your own product starting with creating a DIY laptop using product life management. Maybe we can collaborate to finalize a quality Open Source laptop design using existing hacks. If there's demand, more episodes to come.
https://www.youtube.com/watch?v=WVmlOatiAq0
Reply 5 months ago
Nice 3D CAD tutorial. I've never done any 3D CAD work (unless you count multi-layer circuit boards) so I'm not sure how much help I can be in that area. I have torn apart my share of laptops and have a good appreciation for the designers that manage to pack so much in such a small space. If there's anything I can do to help you, let me know.
Reply 5 months ago
Cool thanks! Is there a way to export from your PCB layout software to 3D CAD? I know that other PCB Layout CAD packages can export to EMN/EMP file types, which I can import in to 3D CAD. If I can get an accurate 3D Model from your software, I can easily find space for it on my end. Otherwise, I can try and reverse engineer it manually, but that will be much slower. I think Grabcad.com has some Lenovo keyboard models also, but it would be great to have your custom PCB too in 3D.
Reply 5 months ago
Awesome, I imported the STEP file and the holes and vias came through perfectly! When I get a chance to make another tutorial episode, I'll use boards like these to begin the final assembly. Thanks!
Reply 5 months ago
Eagle will export my Keyboard_Scanner.brd file to the following file formats:
DXF, Fabmaster, IPC, STEP
Let me know if any of these will work with your CAD software and I'll send it to you as an email. Is info@solarcyclepower.com a good way to reach you?
Reply 5 months ago
Cool, well I can design the battery pack. I think we've got all the necessary components now, especially with those NUC style all-in-one boards.
Frank_Adamsdkadams4
Reply 5 months ago
Thanks Dear. Now you know what I've been doing in my man-cave for the last couple months.
