How to Make an Arduino Powered CNC Machine
68,046
761
56
Step-by-step instructions on how to build a low cost CNC machine controlled with an Arduino Uno!
Step 1: Fabricating a Base and X-Axis Sled
Roller skate wheels will be used to create the X-Axis sled. A combination of 2in and 1in steel tubing will form the base of the machine.
Step 2: Building the Y-Axis
Using bearings from roller-skate wheels to create the Y-Axis sled. The gantry is built using 2in square tubing.
Step 3: Z-Axis
Fabricating the Z-Axis using drawer sliders found at home improvement store.
Step 4: Lead Screws and Motors
Installing two Acme lead screws for the X and Y axes, and a cheap threaded rod for the Z Axis. Mounting the stepper motors in position.
Step 5: Configuring Arduino, GRBL, Easel and Steppers.
Uploading and configuring GRBL on an Arduino Uno. Calibrating stepper motors and using 'Easel' as the g-code sender.
Arduino All The Things! Contest
Runner Up in the
    • Gardening Contest
      Gardening Contest
    • Arduino Contest 2019
    • Party Challenge
      Party Challenge
    56 Discussions
    amadikari
    2 years ago
    sir, It is a very nice project.I also like to do this project so can you send me the programming codes
    The Ideanatorgarethllewelyn
    Reply 3 years ago
    There's brazing (basically soldering), nuts 'n bolts, 80/20 is popular, even mapp gas/ally/those aluminum welding sticks might work.
    Get creative, that's what he did.
    Ralphxyz
    3 years ago
    I can not believe you do not use a mask or at least goggles when you are welding.
    RalphxyzAbsorberOfLight
    Reply 3 years ago
    obviously you are a experienced welder and know what you can get away with.
    There are a lot of of non welders that are looking at you for inspiration to learn welding and you are setting a horrible example for a new person just learning welding.
    I really appreciated the project, most of the videos seem to be repeats.
    markpsAbsorberOfLight
    Reply 3 years ago
    Welding without protective shades will give you several problems, from conjunctivitis to retinal scaring, and it is progressive. It may take years before you notice or end up developing cataracts.
    Also the repeated exposure of the invisible UV light from 200 to 400 nm can give you skin cancer on any exposed skin.
    RyanG10
    3 years ago
    Very nice instructable; I'm inspired to build one of my own. I'm just curious what kind of tolerances you are able to achieve with your gantry system? Have you tested this?
    bonymorales
    3 years ago
    Hello.
    I'm instructables member since 2009 and your CNC it's one of the best that I know. It's a wonderful project with great results. It could be possible to add some instructions ?. Would be very helpful to build one of these.
    Thanks a lot for sharing. Cheers from Mexico.
    bonymoralesAbsorberOfLight
    Reply 3 years ago
    I appreciate you taking the time to respond.
    I refer to written instructions (for someone like me who likes to read) and in my opinion will be the ideal complement for someone to replicate your CNC relying on the excellent videos that you published.
    Greetings from Monclova, Coahuila, Mexico
    Traducción al Español.
    Le agradezco que se tome el tiempo de responder.Me refiero a instrucciones escritas (para alguien como yo que me gusta leer) y en mi opinión será el complemento ideal para que alguien pueda replicar tu CNC apoyándose en los excelentes videos que publicó.
    Saludos from Monclova,Coahuila México
    stumitch
    3 years ago
    wow. I mean, seriously man. I have been messing with my home built cnc for months and you just answered almost every question I had. Well done!
