How to Make an IR Blaster
92,317
87
44
About: My profile is about making most use out of something and optimum utilization of resources available,dedicated to D.I.Y (Do it yourself) Projects.Easy Hacks,DIY Experiments, Myth Busters & More
Hi Everyone,
In this Video I'm Trying to make an IR blaster.
An infrared blaster (or IR blaster) is a device that emulates an infrared remote control to autonomously control a device that is normally controlled only by remote control key presses. ... Another common use is to extend infrared signals in order to place remote controlled products behind closed doors.
I'm going to Make a IR blaster for Smartphones which will connect to your device using a 3.5mm Jack
This a Myth-buster instructable to prove that does the IR blaster for the phone work?
There are lot of videos regarding this stating it works,some say it doesn't work.
Lets find out if there is any truth or its just a Myth.
Step 1: Parts Required
1x 3.5mm Aux cable ( I had broken one lying down so I used that, You can alos get a standalone 3.5MM which can be easier
2x IR leds
small Piece of 6mm heat-shrink tubing (optional)
You will need Hot glue gun & a Soldering Iron
Step 2: Understanding the Led
I'm sure if you have dealt with leds then you will know hot find out anode & cathode. Nevertheless
I will tell you how to find out alway the long lead is the Anode(+) & the short lead is the cathode(-).
For reference check the images
Step 3: Connect the Two Led in Series
Connect the two led in series where in positive(+ Anode) of led 1 should be connected to the negative(- cathode) of led 2 & positive(+ Anode) of led 2 should be connected to negative(- cathode) of led 1.
Check the image for reference.
Step 4: Connecting the Leds
Please check the Image on how to connect the Led to the 3.5 mm Jack
Step 5: Final Finishing
After you have soldered it it should look something like the image shown.
You can use some heat shrink to to give good finishing I did't feel like giving a finishing as this was just a test
Video
Step 6: Download the App
In order for this to work you the ZAZA remote App (https://play.google.com/store/apps/details?id=com....)
go to advance settings
Increase the Macro key sending gap to 1000 MS & turn on the audio reversal
TEST RESULTS
test results prove that it works However there are limitations. Like range & audio Drivers of the phone.
This is DIY IR blaster is not compatible with all the Handset if you have good sound driver in your phone it will work. For some reason it didn't work on my other sony phone.
My suggestion would be to try and make one and check if it works and then if you want you can buy
from the link
https://www.banggood.com/5Pcs-Portable-3_5mm-Andro...
https://www.amazon.in/gp/product/B01MS3ZTU7/ref=as...
You can check My Youtube Video for the making.
https://youtu.be/3-yvT13t8zU
Thank you......
    • IoT Challenge
      IoT Challenge
    • Woodworking Contest
      Woodworking Contest
    • Party Challenge
      Party Challenge
    44 Discussions
    why u don't use ground channel....and if i reuse led from an old remote control is it the ir will workable? plzz reply i have to finish my assignment about em wave.. i need ur help sir
    airl1
    4 months ago
    Hi!
    In the product sold, the head of the jack is made of plastic. Do not need all contacts?
    Regards
    Arik
    Clivaro
    9 months ago
    I've made it and it actually worked! Well done J.I.Y!:-) Only question is how to extend the range to be 5 to 10 meters?
    Jugaad it yourselfClivaro
    Reply 9 months ago
    Welldone. The it would be difficult.but I will do my research and check
    aleDotARClivaro
    Reply 5 months ago
    Soldering diodes with higher mW rates should increase the range or am I wrong? Sorry for my bad English. I hope you understand what I mean.
    ChibuikeU
    Question 7 months ago on Step 1
    What is glue green gun
    Shajirr
    Question 1 year ago on Introduction
    Why we need 2 or led.if for receiving and sending then in REMOTE WHY THERE IS ONLY ONE IR LED.PLEASE ANSWER.
    Jugaad it yourselfShajirr
    Answer 9 months ago
    In remote you have a PCB which designated remote for the particular appliance.and What I have done over here is connected head
    jack with LED and as I had explained it earlier two led in series will help in managing the polarity
    ClivaroShajirr
    Answer 9 months ago
    As tested you can still use one LED
    Answer 1 year ago
    As Leds have a + & - lead (leds don't work on reverse polarity) if you look at the wiring diagram i have connected the + lead of one LED to the - lead of the other led &
    - lead of the other Led to + of the other Led.
    So this way I can connect the two led without thinking about the polarity as other wise i will be little difficult to get the polarity correct
    UrielT4ArpitS55
    Answer 9 months ago
    Well, maybe try telling us why you're unable. What's troubling you with that step?
    UrielT4RishwaH
    Answer 9 months ago
    I just built it today, it worked! Just make sure the jack gets all the way in, as mine was having a hard time recognizing it because it wasn't all the way inside. I guess it's because I bought a generic one.
    glomborfoytRishwaH
    Answer 1 year ago
    I bought some 940nanometer infrared LED emitters and tried it and didn't work. I was about to buy one prebuilt infrared blaster but gave up because I assume the Moto G4 Plus has some faulty sound driver somewhere along the way.
