How to Produce a Time-lapse by USB Webcam & Raspberry Pi
10,083
73
7
About: We run YouTube channel and provide some video tutorials on electronics and programming and also videos on cool projects - how to make them, tech news and more. Subscribe to our channel. :)
Hello and welcome to Being Engineers.
we have came up with a new project this week. So in previous instrctables we showed you how to stream live video captured from a webcam in a local network. Someone asked us to make a timelapse by raspberry pi and a usb webcam. So this is the tutorial for it.
The process is very simple and straight forward. Before starting you have to know 2 things:
1. How to install OS in a Raspberry pi. ( link - https://www.instructables.com/id/HOW-TO-INSTALL-R... )
2.How to use your Laptop Screen a monitor for Raspberry pi. (link - https://www.instructables.com/id/How-to-Use-Window... )
We want to clarify that the process is not the only process to achieve this result. I am showing this to you because I found this most convenient to the user.
You can check out our YouTube channel - www.youtube.com/c/being_engineers1
Our Website - www.being-engineers.com
We have also made a video tutorial on this topic, you can also watch that video -
Now let's begin.
Step 1: Gather the Components
In this project, you will need the following:
  • Raspberry Pi 3 Model B (Any version will work, but in PI 3 we have the provision for WiFi that can make this server wireless)
  • USB Webcam (I will use my old Logitech Webcam. Use a better camera for better results.)
  • 5V 2A Power Source ( I will use my Honor 13000mah Power Bank )
  • Lan Cable ( RJ - 45 Cable )
  • Minimum 8 GB Class 10 SD Card ( I will use Sandisk 32GB class 10 SD Card )
  • Pen Drive or External Hard Disk ( previously formatted )
If you haven't install the Raspbian OS on the SD card, then you will need a memory card reader and checkout our tutorial on how to install the OS in Raspberry Pi.
Step 2: Set Up Your Raspberry Pi
We assume you have the SD Card with the raspbian OS installed.
Then insert the SD Card in the Pi.
Connect the USB camera to any one of the four available USB port.
Connect the ethernet cable aka LAN cable to your Pi and connect the other end to your router.
Connect the Pen Drive.
Then Power Up the Raspberry Pi.
The next step is only for Raspberry Pi 3 users. Others. go to step 4.
Step 3: Connect Your Pi to Internet Through WiFi (only for Raspberry Pi 3 Users)
Open the desktop of Raspbian and connect to WiFi by putting the correct password.
When the raspbian is connected to the network by WiFi, then shut down the system.
Now detach the LAN cable and restart. Then you must be connected to the Internet via WiFi only.
This will help to move your webcam and the pi anywhere without the RJ-45 cable.
Step 4: Know Your Raspberry Pi IP Address
Do the following steps to view Pi IP address.
  1. Open your browser on laptop or mobile. ( laptop or mobile has to be in the same network as the pi )
  2. Go to your Router settings by typing in the default IP address of your router. ( written somewhere on your router.)
  3. Find the list of connected devices.
  4. Find the corresponding IP address of the device named raspberry.
In our case, it is 192.168.0.105
Step 5: Connect to Your Pi by SSH Connection ( PUTTY )
Open up Putty and type in the IP address of your Pi and connect.
'pi' & 'raspberry' is the default 'login as' and 'password' in Raspbian.
It is always a good practice to Update and Upgrade the system as soon as you log in.
To do it, type in the command 'sudo apt-get update' and 'sudo apt-get upgrade' one at a time.
Step 6: Install the Software and Do the Necessary Settings
Type in the command 'sudo apt-get install motion ' to start the installation.
Now to make sure that the camera and the pen drive is correctly detected-
Type in the command 'lsusb' and enter. You should see the name of your camera. If it is NOT there, then there is some problem in your camera or the camera is not supported in 'motion'.
Now type in the command 'sudo cat /proc/mounts'. At the end you can see the name of your pen drive and the directory where the external storage is mounted. ( Follow the Screenshot ). Copy the path for later use.
After this, type in the command ' sudo nano /etc/motion/motion.conf ' and press enter.
Then you have to change some settings in the .conf file. It might be difficult sometimes to find the settings but use 'ctrl + w' to find it. So follow the steps: (All the steps are not necessary just for timelapse purpose, but of you do all these steps then you can also stream the video in the local network.
  1. Make sure 'daemon' is ON.
  2. Set 'framerate' anywhere in between 1000 to 1500.
  3. 'Stream_quality' should be 100.
  4. Change 'Stream_localhost' to OFF.
  5. Change 'webcontrol_localhost' to OFF.
  6. Set 'quality' to 100.
  7. Set 'width' & 'height' to 1280 & 720.
  8. Set 'Snapshot_interval' equals to 10. ( every 10 seconds 1 photo will be taken )
  9. Set 'target_dir' as the path that you have copied earlier.
  10. Press ctrl + x to exit. Type y to save and enter to conform.
Again type in the command 'sudo nano /etc/default/motion ' and press enter.
Set ' start_motion_daemon ' to yes. Save and exit.
Step 7: Start Taking Pictures
First of all restart your motion software by this command - 'sudo service motion restart'.
Again type in the command 'sudo motion' and press enter. Now your server is ready.
From now on in every 10 seconds a photo will be taken and will be saved in the pen drive.
Whenever you think you can power the pi off and take out the pen drive.
Step 8: It's DONE!!
When you have all the images then join the images to make a video and export that to your desired location. You can find many softwares to this simple task.
you can watch the timelapse that I created in the given video link on our channel - ( 7:10 onwards )
Hope you have enjoyed this tutorial. If yes then please do SUBSCRIBE to our channel Being Engineers. It really helps us a lot on seeing your support and interest towards our channel and don't forget to share :)
Channel link - https://www.youtube.com/c/being_engineers1
Peace.
    • Tape Contest
      Tape Contest
    • Arduino Contest 2019
    • Trash to Treasure
      Trash to Treasure
    7 Discussions
    sbjulian63
    1 year ago
    good job, made this and works fine with raspberry pi zero w. how do you make this start after boot. thanks
    MaRR10
    1 year ago
    Hi,
    can raspberry pi zero do the job? Thanks.
    MrLunk
    1 year ago
    Works great :) Thanks!
    Small note: USB drive / stick needs to be FAT formatted ;)
    frd1963
    2 years ago
    Nice instructable! I will be using this with my daughters to get them more comfortable with 'being engineers' ... the occupation, not you in particular ;) We discussed doing this to film a time lapse of the trees in our yard growing leaves this Spring.
    I do wonder why you decided not to use a pi cam though. Is it just that everyone seems to have at least one old USB webcam lying around? No complaints (I already have a Pi 3 and several old webcams collecting dust, so this saves me $25) just wondering if there were other reasons.
    Being Engineersfrd1963
    Reply 2 years ago
    Thank you. There is no other reason other than what you said. All of has at least one webcam lying around that we don't use. And secondly one of our subscriber asked us to do it with a webcam.
