How to Weather Wood FAST (Barnwood Effect)
12,027
191
9
This Instructable and video will show you how to achieve a QUICK weathered wood effect to simulate what would otherwise take months and years of water and sunshine to accomplish.
Supplies:
Step 1: How to Weather Wood (Barnwood Effect)
This is an old method I use for achieving a gray "weathered" effect in wood. I also show you how to use a wire brush for an even more pronounced effect.
Things you will need:
  • Steel Wool (#000 or #0000)
  • Vinegar
  • Wire Brush
  • Board (I use Pine, but also show the effect on Poplar and Red Oak)
  • Spare containers (small bucket, a couple of cups, etc.)
Steps:
  • Place one of the steel wool pads in a container large enough to hold it.
  • Pour vinegar into container until steel wool is fully submerged.
  • Let this sit for at least 24 hours.
  • (OPTIONAL: For best effect, use wire brush to prepare board. SEE VIDEO.)
  • Pour the dissolved mixture into a new cup. (Pour through a coffee filter to catch any small steel wool bits.)
  • Add water to dilute the mixture. (In the video I show 1-to-1 water-to-vinegar mix.)
  • Apply to wood.
  • Wait while the vinegar mixture reacts with the wood. It will gradually turn a grayish color.
    • Party Challenge
      Party Challenge
    • Fandom Contest
      Fandom Contest
    9 Discussions
    BeachsideHank
    3 years ago
    This look was popular in the late '70's in the Chicago area, I wainscoted my kitchen with pine barnboard to good effect, it also provided some insulative value too.
    n0ukfBeachsideHank
    Reply 3 months ago
    I assume you meant the wainscoat added to insulation, not the weathering itself.
    TheCrafsManBeachsideHank
    Reply 3 years ago
    I imagine that looks good! Especially with the barnwood wainscoat against drywall / solid background. I have used this on exterior cypress siding, to good effect. Vinegar is also a mild bug repellent. (Though only the carpenter bees seem to mess with cypress.)
    Treupp
    Question 7 months ago
    Hi there!
    Do you think that soaking wood in the mixture would also produce the same effect? I'm asking because I would like to use your idea in a small project of mine, for a gift, but this project also involves polishing a piece of wood until very smooth, and I'd rather not just get rid of the weathered layer.
    BLASTFEMI
    2 years ago
    I tried your formula and it worked fantastic! I used some pine stakes I wanted to age and made a sign post. Next time I will try aging it with a wire brush. I love that effect! Thank you for sharing!
    Mihsin
    2 years ago
    Very nice indeed. I imagine if you can install the wire brush onto an oscillating saw you can finish a wide area easily. My elbows & shoulders would not bear the scrubbing punishment.
    cnathan
    2 years ago
    Very cool!!! Definitely trying!! Thanks for sharing!
    noel.kuck
    2 years ago
    How long does it normally take for the graying to begin and to end?
    TheCrafsMannoel.kuck
    Reply 2 years ago
    I have seen it change the wood in a matter of minutes, when the sun is out and I use a fine mist, instead of soaking the wood. If you soak the wood, it can take a couple hours or so. Usually by the next day you see how it will really look, long-term.
