How to Build a Hot End.
5,734
43
11
I started in 3d printing or reprap as it's known with a purpose built hot end. It was the cause of many knightmares over the course of building the printer and getting some quality out of it. I resolved to replace it. Many commercially made ones are very expensive and people will get quite caught up in getting the latest model in the usually vain hope of improving their machines quality and capabilities with it. This is folly!
Hot end are really very simple devices and the basic parts are cheap and readily available. I'm using exactly this set up and it's cured the vast majority of problems I had with my machine.
I've tried to give a few basic guidelines and explain the purpose of the mysterious entity that is a hot end.
For this you will require:
1 Aluminium heating block
1 brass nozzle (sharp pointed)
2 26mm M6 'throats' (appropriate to your desired filament size)
1 small square of automotive heat shield (ask at your local repair centre for offcuts)
5 M6 washers about 4mm wide
6 M6 Repair washers about 20mm wide
3 Tee Nuts (see the vid for an explanation) or 2 M6 stud connectors
1 M6 Pnuematic push fit tube connector (for a Bowden Tube). This is optional depending on your extruder setup.
A small length of PTFE tube liner (appropriate to your chosen filament size and throat diameter. Again, see the vid for an explanation)
Kapton Tape
PTFE Plumbers/Gas fitters tape
1 Thermistor
1 Heating cartridge/resistor
Here's how to put them together.
    • Arduino Contest 2019
    • IoT Challenge
      IoT Challenge
    11 Discussions
    cliffyd
    11 months ago
    nice idea and good explaination.
    cyprian_poland
    2 years ago
    Do yoy have any printout examples out of this one??
    TheThinker
    3 years ago
    No video appears when viewing this Instructable on the Android ap. Please include a link. Thanks! And thanks for sharing!
    iFirefly
    4 years ago on Introduction
    Nice! I was wondering why you wrap PTFE on the hollow feed tube where it contacts the heat sink washer assembly, though - don't you want the best contact between them so they will conduct heat away from the tube? The PTFE would presumably block heat transfer from the tube to the washers.
    tiltmonkeyiFirefly
    Reply 3 years ago
    I tried both. I found that without it, the stored heat fed back in and caused the filament to melt too high in the tube. This happens especially on retraction.
    This way worked better. I think it's because it's the best way of blocking the most heat. I'm no expert though and others may experience a different effect.
    tiltmonkeyjlipavsky79
    Reply 4 years ago on Introduction
    Are you having a problem with the video? I build the whole thing in the video. If you're asking how to attach it to a printer, that depends on what kind of printer you have. That's why it isn't included.
