How to Control Servo With Play Station 2 Controller
33,185
504
23
About: Just an ordinary guy...working towards a B.Tech in computer science engineering.
I wanted an easy way to control my robots servo so i googled for a suitable solution but couldn't find one. so i decided to use my old ps2 controller for this purpose and it worked perfectly.
So here is a step by step guide for you to do the same..Hope you'll like it.. :)
Step 1: Thing You'll Need
1. Arduino UNO or any other arduino with pwm output x1
2. Breadboard x1
3. Hookup wires
4. Servo motors x1-4 (you can control upto four servo with this code)
5. Power source for Servos(arduino can't supply enough current,i used a variable voltage battery eliminator)
6. Play station 2 controller(I used wireless controller).
7. Soldering iron (For making a connector for ps2 controller,Skip this if you already have connector)
8. PC with Arduino IDE installed
9. Bill Porter's ps2x lib installed (Download it from here).
Step 2: Making the Connector
i'm not gonna explain this one in detail. Well i made my one with a broken ps2 multitap (luckily i found one laying around).So basically what i did here is that,i de-soldered the female connector from multitap and soldered some hookup wires and male headers with it
Step 3: The Circuit
Circuit here is pretty simple.just the connect the servo in the following manner :-
servo 1------------------> Arduino digital pin 9
servo 2------------------> Arduino digital pin 6
servo 3------------------> Arduino digital pin 5
servo 4------------------> Arduino digital pin 3
Now connect ps2 controller to arduino
Data-------------> Arduino digital pin 12
Clock------------> Arduino digital pin 13
Attention--------> Arduino digital pin 10
Command------> Arduino digital pin 11
Note- If you use external power source for the servos then don't forget to join GND of both arduino and power source.
Step 4: Arduino Code !!!
Now just upload this code to your arduino and you're ready to roll
Step 5: Troubleshooting
1. No controller Found -
check your wiring again or check this LINK for possible solutions
2. Servo jittering -
Try to feed servo with external power source.
Still have some issue???Feel free to comment and I'll try my best to solve it.
---------------->VOTE for my instructable in MIND FOR DESIGN contest if you like it<---------------------
2 People Made This Project!
  • Classroom Science Contest
  • Arduino Contest 2019
23 Discussions
Chineset
5 months ago
I met a problem like this: when the RX led is lightted, PS2 controller is useless and can not control the servo, I don't know the reason and waitting for your help~~, thanks
umani1
4 years ago
didnt understand the multitap point. kindly explain it in detail
MayankTiwari04umani1
Reply 4 years ago on Introduction
its very simple buddy, when I took out the female connector from the multitap I found 9 pins on the back side of it as you can see in the pictures then soldered wires on each of that pin along with male headers.That's it !!!
KyawMyint103MayankTiwari04
Reply 1 year ago
Hello,
MayankTiwari
i am a new user to arduino......can you provide arduino code for controlling six servo motors. i will really appreciate for it.
Science102
2 years ago
I tried to make this but I keep getting no controller found. I am using the lynxmotion ps2 controller (possible v2) with its receiver (a little black rectangle). I didn't use the connector that you showed above because I don't really understand what you did there.
The "pairing" light on my controller and receiver goes from blinking to solid after a little while. I assume this means that they are pairing properly. I would appreciate any help you can offer.
RexTexHM
2 years ago
Is it possible to control those 2 servos with a RC I salvaged from a totaled RC car? In other words, can this be radio controlled instead of wired with a remote?
PeterCo014
3 years ago
Hello,
Super your tutorial it made me much progress on my project.
I have a question, is it possible to control 6 servo motor.
4 with the joystick as currently and 2 by two buttons on the PS2 controller.
Can we vary the speed of the servo motor rather than the position because I need precision during movement.
I'm not very good at code all help is welcome: D, just give me the tracks if possible.
The project is to control a robotic arm with a clamp and a camera that can rotate left or right.
Thanking you in advance.
sushant panaskar
3 years ago
can you plz send me the entire code......
SEVENAMI1
3 years ago on Introduction
Hello, what about PS3 controller?. It´s posible create a file code to control 4 servos to a Drone?! Awasome !
well my code works only for ps2 controller, but yeah their are other instructables for ps3 controller as well ,you can give them a try. and with my code you can control up to 4 servo easily.
epitts2
I'd love to see if this could be expanded to control a houseboat with inboard screws and a gearbox to let them run independently from each other, to have it run like a zero-turning-radius mower or a tread hoe.
Kweekepitts2
Reply 4 years ago
pretty sure it could but that would be one ugly engraving.
mario59
Thanks for sharing this *REALLY NICE IDEA* ! ! !
I wonder if it could be used to drive a Laser engraver CNC!
really nice & useful tipo to recicle old devices!!!
pt_89
4 years ago
Hey thanks for sharing this project its really a nice project
