How to Make a Lightning Cloud
80,305
887
94
I really wanted to make a little cloud that would light up as though it was filled with lightning. After googling a bit, I stumbled upon "The Cloud" by Richard Clarkson. It's a beautifully executed concept and I wanted to see if I could make one too. There are lotsofexamples of "cloud lamps." What I like about mine is I built the shape of the cloud completely from scratch, so I wasn't left with a mostly round cloud (a common problem). I'm also really proud of the lightning animation I created.
This is the first of three steps. The second part of this project will be adding bluetooth control, so I can trigger weather patterns in the cloud via my phone. The third part will be automatically triggering weather patterns according to the day's weather report. I want an easy-to-use, "glanceable," aesthetically appealing weather indicator for my apartment. Plus I've heard cloud computing is the hot new thing.... :)
Stay tuned for those future Instructables!
Supplies:
Step 1: Gather Materials
1. Cardboard
2. Cotton balls
3. Polyester batting, 3/4" thick. It's easiest to pick out batting by going to a fabric store in person to find the right kind. You want batting that's about an inch thick. Something like this, but I'd need to see it in person to know if it was the right thickness. If you go to a fabric store, they'll let you cut a smaller amount. It should be about $6.99 per yard. I used about 2 square feet.
4. Boning (like the kind used for corsets). I used a yard and could have found use for more.
5. Needle and thread
6. Hot glue gun
7. Adafruit Neopixel LEDs. I used these "Breadboard friendly" ones. You can also buy them in packs of 4.
8. Wire
9. Soldering iron
10. Microcontroller (I used an Adafruit Pro Trinket with the little battery backpack soldered on)
11. Sewing pins
12. (Optional) a "large" capacitor. I follow the best practices recommended by Adafruit and used a 1000uf, 6.3V capacitor.
Step 2: Build Cloud Structure
Using a piece of cardboard for the base, glue the boning to make the basic outline of your cloud. You can make hoops with the boning - I found it was easiest to sew the two ends of the boning together, and then glue the hoop directly onto the cardboard. I also tried leaving one piece of boning pointing out into the air like ribs. Both methods worked fine.
Rip your 3/4" batting in half, and hot glue it to the boning and the cardboard in tasteful, cloud-like folds. At some points, it will be easier to gently sew the batting to the boning to keep it in place. Keep in mind how many lumps you want your cloud to have, and the overall structure. You can augment later with cotton balls, but this part will define the overall shape of your cloud.
Be sure to leave a little door in half of the cloud, where you'll place the electronics. Make the part of the batting that will become the door a little thicker than you might otherwise. It's nice to have the extra support.
Step 3: Add Fluff Texture
Gently pull apart your cottonballs. I pulled apart about 30 while my hot glue gun was heating up. The cottonballs themselves have a bit of a circular structure to them, and if you tear them apart carefully you'll preserve some of those whorls, which looks really cool later when the light shines through. You can also unroll cottonballs so they'll make longer, stringier clouds if you want.
Drip hot glue directly onto the outside of the batting, and gently pat your cottonballs into place. You don't need to completely cover the batting. Since the batting is white and a little fluffy, if some is showing that's ok. I preferred to vary the amount of cottonballs I was using so the cloud would be differing densities - it's nice if the light can shine through more in some places and less in others.
Step 4: Add Electronics
First, you'll need to solder your LEDs into a long strand. I usually
take the easiest route of soldering male-male jumper cables directly to the Neopixels. The wires are flexible, the connections are solid, and it's super fast and easy. No need to strip any wires! Test your connections as you go, so you can quickly fix any issues. The basic circuit for this project is very simple. I'm building mine on a breadboard for now, but for a more permanent project, you'll probably want to solder things together directly, or maybe use a little proto board. With only 5 LEDs, you probably don't need a capacitor, but I always throw one in anyway to be safe. The polarity of a capacitor matters. That means you need to plug it in correctly for it to work. There are several ways to recognize the polarity of your capacitor.
  • Look at the legs
    • Most capacitors will have legs with different lengths. The short leg is the negative side.
  • Look for a stripe or an arrow.
    • Most capacitors will have a light stripe down one side. That's the negative side of the capacitor
The negative side should be connected to GND. The other side attaches to PWR.
Connect power, ground, and signal from your microcontroller to your LED strand:
Arduino -------> Neopixel strand pin
#4 -------> Data Input pin
BAT+ --------> VIN
GND ---------> GND
As always, if you are new to soldering, I highly recommend Adafruit's Guide to Excellent Soldering.
Step 5: Upload the Code
Getting accurate lightning animation was super important to me for this project. I played around with lots of ideas before going with hand-picked data points and a simple moving average smoothing algorithm. I'm pretty excited about how it turned out!
https://github.com/molecule/cloud-lightning/tree/v...
You might need to update these two variables to match your setup:
https://github.com/molecule/cloud-lightning/blob/v...
You can also change these variables to make lightning strikes more or less likely:
Step 6: Put Everything Together
You can try different placements of the LEDs inside the cloud. I ended up adding some cardboard pieces on the inside, because I wanted some parts of the cloud to be a bit darker than other parts. I also left the animation playing for a while, and glued on a few more cottonballs wherever it felt right.
I wanted to be able to access the microcontroller, so I just temporarily hold the door closed with a pin through several layers of batting.
Make It Glow! Contest
Third Prize in the
Halloween Decor Contest 2015
Runner Up in the
9 People Made This Project!
  • Arduino Contest 2019
  • Fandom Contest
    Fandom Contest
94 Discussions
BrydenR
Question 24 days ago on Step 4
so I have all the parts and the code is on the trinket. I can see the right flickering pattern with one led connected but with a very dim red light. once I connect the next led I get no lights at all and am only getting 1.63v across each one. I noticed you have a capacitor but I would expect 1 led to work fine but still no luck getting the proper bright light. I assume they still work at 3v from the trinket despite being a 5v led?
1 answer
molecule13BrydenR
Answer 20 days ago
5V LEDs usually require 5 volts unless specified otherwise! (The LEDs I used above say: "can run at 3.5V" on their info page). What you're describing sounds exactly like you're not providing enough power, so since all the data fits the theory, I think that's your issue. Let me know if you have more questions!
rphutton
Question 3 months ago
This is an awesome looking project! I'm gonna try it out myself and I was just wondering if you think this would work with an adafruit gemma m0 rather than the pro trinket? I have one laying around that I want to get some use out of.
molecule13rphutton
Answer 3 months ago
Glad you like it! Please share a picture when you're finished :) It's always fun to see what people create!
In general, when assessing whether a project will work on a different piece of hardware, here are the questions to answer:
1. Will all the hardware connections fit and work?
2. Will all the software fit and work?
Since this project is only 3 pins, the Gemma should work just fine.
The Gemma M0 does have a new chip, though: ATSAMD21E18 instead of the Pro Trinket's ATmega328. The maximum sketch size on the Pro trinket is 28,672 bytes, which will definitely fit on the 256KB Flash of the Gemma M0.
So the last question is: will the software work? That's a question you can figure out through trial and error. First, you'll have to see if the Neopixel library has been updated to support this new board. Adafruit is super on top of things and their Neopixel library is one of the most popular ones they distribute so I would bet that it will work just fine! Best of luck!
rphuttonmolecule13
Reply 3 months ago
Thanks for the advice! The local MicroCenter had a trinket in stock so I didn't have to try to adapt it to the gemma.
AdamB476
Question 4 months ago on Step 2
Its shows a capacitor but its not in the list of items needed. What size do i need?
1 answer
johnriederer
1 year ago
I need help getting the program to load to my trinket Pro. I can load the "Blink" but when I try to load Cloud-Lightning I'm getting an error. "exit status 1 Error compiling for board Pro Trinket 3V/12MHz (USB)
What am I doing wrong?
molecule13johnriederer
Reply 1 year ago
Hmm, well you're getting a compile error (I can tell because the message you helpfully provided says "Error compiling for board"). That means that, as the compiler is trying to make the code into machine-understandable language, something went wrong. To understand what, we need more information! First, turn on the verbose messages for compiling in your IDE:
File->Preferences->Show verbose output during:. Tick boxes for compilation and upload.
Then try to compile again. You should get a LOT more information, and some of it will be useful :) In particular, I'm guessing you're missing one of the libraries you need to install (or you didn't restart the IDE after installing them). But we should be able to tell with more information.
johnriederermolecule13
Reply 1 year ago
Here is the full verbose compilation Thanks for the Help
Arduino: 1.8.3 (Windows 10), Board: "Pro Trinket
3V/12MHz (USB)"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs
-logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware
C:\Users\John\AppData\Local\Arduino15\packages -tools C:\Program Files
(x86)\Arduino\tools-builder -tools C:\Program Files
(x86)\Arduino\hardware\tools\avr -tools C:\Users\John\AppData\Local\Arduino15\packages
-built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries
C:\Users\John\Documents\Arduino\libraries -fqbn=adafruit:avr:protrinket3
-ide-version=10803 -build-path C:\Users\John\AppData\Local\Temp\arduino_build_269669
-warnings=none -build-cache
C:\Users\John\AppData\Local\Temp\arduino_cache_672861
-prefs=build.warn_data_percentage=75
-prefs=runtime.tools.avrdude.path=C:\Users\John\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9
-prefs=runtime.tools.arduinoOTA.path=C:\Users\John\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.1.1
-prefs=runtime.tools.avr-gcc.path=C:\Users\John\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2
-verbose C:\Users\John\Desktop\Lightning\cloud-lightning\cloud-lightning.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile
C:\Users\John\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder
-tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools
C:\Users\John\AppData\Local\Arduino15\packages -built-in-libraries C:\Program
C:\Users\John\AppData\Local\Temp\arduino_build_269669 -warnings=none
-build-cache C:\Users\John\AppData\Local\Temp\arduino_cache_672861
-prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Users\John\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9
Using board 'protrinket3' from platform in folder:
C:\Users\John\AppData\Local\Arduino15\packages\adafruit\hardware\avr\1.4.9
Using core 'arduino' from platform in folder:
C:\Users\John\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.20
Detecting libraries used...
"C:\Users\John\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++"
-c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections
-fdata-sections -fno-threadsafe-statics
-flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=12000000L -DARDUINO=10803
-DARDUINO_AVR_PROTRINKET3 -DARDUINO_ARCH_AVR
"-IC:\Users\John\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.20\cores\arduino"
"-IC:\Users\John\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.20\variants\eightanaloginputs"
"C:\Users\John\AppData\Local\Temp\arduino_build_269669\sketch\cloud-lightning.ino.cpp"
-o "nul"
-DARDUINO=10803 -DARDUINO_AVR_PROTRINKET3 -DARDUINO_ARCH_AVR "-IC:\Users\John\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.20\cores\arduino"
-o "C:\Users\John\AppData\Local\Temp\arduino_build_269669\preproc\ctags_target_for_gcc_minus_e.cpp"
C:\Users\John\Desktop\Lightning\cloud-lightning\cloud-lightning.ino:31:31:
fatal error: Adafruit_NeoPixel.h: No such file or directory
#include
<Adafruit_NeoPixel.h>
compilation terminated.
exit status 1
Error compiling for board Pro Trinket 3V/12MHz (USB).
Reply 1 year ago
Excellent! This is everything we need to figure this out. Typically, for compile errors, you want to look at the "first" error. Arduino helpfully puts that at the very end of the compile error, and I've copied it here for convenience:
That basically means that you haven't installed or successfully set up the Neopixel library! So Arduino has no idea where that code is. The good news is, it's super easy to fix this. Head on over to Adafruit's excellent (as always) tutorial on installing the Neopixel library and you should be able to get past this error! Here's the link:
https://learn.adafruit.com/adafruit-neopixel-uberguide/arduino-library-installation
Reply 1 year ago
Thanks but now I get this error:
Arduino: 1.8.3 (Windows 10), Board: "Pro Trinket 3V/12MHz (USB)"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\John\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\John\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\John\Documents\Arduino\libraries -fqbn=adafruit:avr:protrinket3 -ide-version=10803 -build-path C:\Users\John\AppData\Local\Temp\arduino_build_745192 -warnings=none -build-cache C:\Users\John\AppData\Local\Temp\arduino_cache_742529 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Users\John\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9 -prefs=runtime.tools.arduinoOTA.path=C:\Users\John\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.1.1 -prefs=runtime.tools.avr-gcc.path=C:\Users\John\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2 -verbose C:\Program Files (x86)\Arduino\libraries\Cloud-Lightning\cloud-lightning.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\John\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\John\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\John\Documents\Arduino\libraries -fqbn=adafruit:avr:protrinket3 -ide-version=10803 -build-path C:\Users\John\AppData\Local\Temp\arduino_build_745192 -warnings=none -build-cache C:\Users\John\AppData\Local\Temp\arduino_cache_742529 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Users\John\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9 -prefs=runtime.tools.arduinoOTA.path=C:\Users\John\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.1.1 -prefs=runtime.tools.avr-gcc.path=C:\Users\John\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2 -verbose C:\Program Files (x86)\Arduino\libraries\Cloud-Lightning\cloud-lightning.ino
Using board 'protrinket3' from platform in folder: C:\Users\John\AppData\Local\Arduino15\packages\adafruit\hardware\avr\1.4.9
Using core 'arduino' from platform in folder: C:\Users\John\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.20
"C:\Users\John\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=12000000L -DARDUINO=10803 -DARDUINO_AVR_PROTRINKET3 -DARDUINO_ARCH_AVR "-IC:\Users\John\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.20\cores\arduino" "-IC:\Users\John\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.20\variants\eightanaloginputs" "C:\Users\John\AppData\Local\Temp\arduino_build_745192\sketch\cloud-lightning.ino.cpp" -o "nul"
"C:\Users\John\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=12000000L -DARDUINO=10803 -DARDUINO_AVR_PROTRINKET3 -DARDUINO_ARCH_AVR "-IC:\Users\John\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.20\cores\arduino" "-IC:\Users\John\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.20\variants\eightanaloginputs" "-IC:\Users\John\Documents\Arduino\libraries\Adafruit_NeoPixel" "C:\Users\John\AppData\Local\Temp\arduino_build_745192\sketch\cloud-lightning.ino.cpp" -o "nul"
"C:\Users\John\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=12000000L -DARDUINO=10803 -DARDUINO_AVR_PROTRINKET3 -DARDUINO_ARCH_AVR "-IC:\Users\John\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.20\cores\arduino" "-IC:\Users\John\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.20\variants\eightanaloginputs" "-IC:\Users\John\Documents\Arduino\libraries\Adafruit_NeoPixel" "C:\Users\John\Documents\Arduino\libraries\Adafruit_NeoPixel\Adafruit_NeoPixel.cpp" -o "nul"
"C:\Users\John\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=12000000L -DARDUINO=10803 -DARDUINO_AVR_PROTRINKET3 -DARDUINO_ARCH_AVR "-IC:\Users\John\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.20\cores\arduino" "-IC:\Users\John\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.20\variants\eightanaloginputs" "-IC:\Users\John\Documents\Arduino\libraries\Adafruit_NeoPixel" "C:\Users\John\Documents\Arduino\libraries\Adafruit_NeoPixel\esp8266.c" -o "nul"
Generating function prototypes...
"C:\Users\John\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=12000000L -DARDUINO=10803 -DARDUINO_AVR_PROTRINKET3 -DARDUINO_ARCH_AVR "-IC:\Users\John\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.20\cores\arduino" "-IC:\Users\John\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.20\variants\eightanaloginputs" "-IC:\Users\John\Documents\Arduino\libraries\Adafruit_NeoPixel" "C:\Users\John\AppData\Local\Temp\arduino_build_745192\sketch\cloud-lightning.ino.cpp" -o "C:\Users\John\AppData\Local\Temp\arduino_build_745192\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\John\AppData\Local\Temp\arduino_build_745192\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Users\John\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=12000000L -DARDUINO=10803 -DARDUINO_AVR_PROTRINKET3 -DARDUINO_ARCH_AVR "-IC:\Users\John\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.20\cores\arduino" "-IC:\Users\John\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.20\variants\eightanaloginputs" "-IC:\Users\John\Documents\Arduino\libraries\Adafruit_NeoPixel" "C:\Users\John\AppData\Local\Temp\arduino_build_745192\sketch\cloud-lightning.ino.cpp" -o "C:\Users\John\AppData\Local\Temp\arduino_build_745192\sketch\cloud-lightning.ino.cpp.o"
C:\Program Files (x86)\Arduino\libraries\Cloud-Lightning\cloud-lightning.ino: In function 'void setup()':
cloud-lightning:85: error: 'simple_moving_average' was not declared in this scope
functionPtrs[0] = simple_moving_average;
cloud-lightning:86: error: 'random_moving_average' was not declared in this scope
functionPtrs[1] = random_moving_average;
C:\Program Files (x86)\Arduino\libraries\Cloud-Lightning\cloud-lightning.ino: At global scope:
cloud-lightning:127: error: expected unqualified-id before ')' token
Using library Adafruit_NeoPixel at version 1.1.2 in folder: C:\Users\John\Documents\Arduino\libraries\Adafruit_NeoPixel
exit status 1
Invalid library found in C:\Program Files (x86)\Arduino\libraries\Cloud-Lightning: C:\Program Files (x86)\Arduino\libraries\Cloud-Lightning
Reply 1 year ago
The three most important errors are shown at the bottom again, just like last time:
Those look.....strange. I encourage you to download the code again from my github account: this looks like a copy-and-paste problem.
You're also getting complaints from the IDE about your file structure. It looks like you have a folder called "Cloud-Lightning" in the Arduino/libraries folder. I am assuming Cloud-Lightning refers to the code for this project, in which case the "libraries" folder is not the right place for it! Move it up one level so it's just in the "Arduino" folder.
Reply 1 year ago
OK I think that the code loaded. It's not turning on the LED. I only have one connected right now. Two more questions:(for now) How do I know that it loaded correct and if I have the LED connected to Batt, 0 and Pin 4 is that correct? When "verify code after upload" is turned on I do see errors.
Reply 1 year ago
1. To know that it is uploaded correctly, you should see this message at the bottom of the print outs of your Arduino IDE: https://www.dropbox.com/s/hs6hnvu6xhmmn0p/Screensh...
If you don't see that confirmation message, you might not have uploaded successfully! But remember, I can't help you if you don't post the error messages you're getting...so if you want help, be sure to always include all the information! Also tell me what kind of Arduino board you're using.
2. Check out Step 4 for how to wire everything up! What you have does not sound correct to me.
Reply 1 year ago
Here's log log. It looks like it didn't upload clean.
Arduino: 1.8.5 (Windows 10), Board: "Pro Trinket 3V/12MHz (USB)"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\John\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\John\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\John\Documents\Arduino\libraries -fqbn=adafruit:avr:protrinket3 -ide-version=10805 -build-path C:\Users\John\AppData\Local\Temp\arduino_build_376360 -warnings=none -build-cache C:\Users\John\AppData\Local\Temp\arduino_cache_619687 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Users\John\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2 -prefs=runtime.tools.arduinoOTA.path=C:\Users\John\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.1.1 -prefs=runtime.tools.avrdude.path=C:\Users\John\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9 -verbose C:\Users\John\Desktop\cloud-lightning\cloud-lightning.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\John\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\John\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\John\Documents\Arduino\libraries -fqbn=adafruit:avr:protrinket3 -ide-version=10805 -build-path C:\Users\John\AppData\Local\Temp\arduino_build_376360 -warnings=none -build-cache C:\Users\John\AppData\Local\Temp\arduino_cache_619687 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Users\John\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2 -prefs=runtime.tools.arduinoOTA.path=C:\Users\John\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.1.1 -prefs=runtime.tools.avrdude.path=C:\Users\John\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9 -verbose C:\Users\John\Desktop\cloud-lightning\cloud-lightning.ino
"C:\Users\John\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=12000000L -DARDUINO=10805 -DARDUINO_AVR_PROTRINKET3 -DARDUINO_ARCH_AVR "-IC:\Users\John\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.20\cores\arduino" "-IC:\Users\John\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.20\variants\eightanaloginputs" "C:\Users\John\AppData\Local\Temp\arduino_build_376360\sketch\cloud-lightning.ino.cpp" -o "nul"
"C:\Users\John\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=12000000L -DARDUINO=10805 -DARDUINO_AVR_PROTRINKET3 -DARDUINO_ARCH_AVR "-IC:\Users\John\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.20\cores\arduino" "-IC:\Users\John\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.20\variants\eightanaloginputs" "-IC:\Users\John\Documents\Arduino\libraries\Adafruit_NeoPixel" "C:\Users\John\AppData\Local\Temp\arduino_build_376360\sketch\cloud-lightning.ino.cpp" -o "nul"
Using cached library dependencies for file: C:\Users\John\Documents\Arduino\libraries\Adafruit_NeoPixel\Adafruit_NeoPixel.cpp
Using cached library dependencies for file: C:\Users\John\Documents\Arduino\libraries\Adafruit_NeoPixel\esp8266.c
"C:\Users\John\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=12000000L -DARDUINO=10805 -DARDUINO_AVR_PROTRINKET3 -DARDUINO_ARCH_AVR "-IC:\Users\John\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.20\cores\arduino" "-IC:\Users\John\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.20\variants\eightanaloginputs" "-IC:\Users\John\Documents\Arduino\libraries\Adafruit_NeoPixel" "C:\Users\John\AppData\Local\Temp\arduino_build_376360\sketch\cloud-lightning.ino.cpp" -o "C:\Users\John\AppData\Local\Temp\arduino_build_376360\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\John\AppData\Local\Temp\arduino_build_376360\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Users\John\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=12000000L -DARDUINO=10805 -DARDUINO_AVR_PROTRINKET3 -DARDUINO_ARCH_AVR "-IC:\Users\John\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.20\cores\arduino" "-IC:\Users\John\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.20\variants\eightanaloginputs" "-IC:\Users\John\Documents\Arduino\libraries\Adafruit_NeoPixel" "C:\Users\John\AppData\Local\Temp\arduino_build_376360\sketch\cloud-lightning.ino.cpp" -o "C:\Users\John\AppData\Local\Temp\arduino_build_376360\sketch\cloud-lightning.ino.cpp.o"
Compiling libraries...
Compiling library "Adafruit_NeoPixel"
Using previously compiled file: C:\Users\John\AppData\Local\Temp\arduino_build_376360\libraries\Adafruit_NeoPixel\esp8266.c.o
Using previously compiled file: C:\Users\John\AppData\Local\Temp\arduino_build_376360\libraries\Adafruit_NeoPixel\Adafruit_NeoPixel.cpp.o
Compiling core...
Using precompiled core
Linking everything together...
"C:\Users\John\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\Users\John\AppData\Local\Temp\arduino_build_376360/cloud-lightning.ino.elf" "C:\Users\John\AppData\Local\Temp\arduino_build_376360\sketch\cloud-lightning.ino.cpp.o" "C:\Users\John\AppData\Local\Temp\arduino_build_376360\libraries\Adafruit_NeoPixel\esp8266.c.o" "C:\Users\John\AppData\Local\Temp\arduino_build_376360\libraries\Adafruit_NeoPixel\Adafruit_NeoPixel.cpp.o" "C:\Users\John\AppData\Local\Temp\arduino_build_376360/..\arduino_cache_619687\core\core_adafruit_avr_protrinket3_31f3447a2cf0685b03589d03627321e2.a" "-LC:\Users\John\AppData\Local\Temp\arduino_build_376360" -lm
"C:\Users\John\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\Users\John\AppData\Local\Temp\arduino_build_376360/cloud-lightning.ino.elf" "C:\Users\John\AppData\Local\Temp\arduino_build_376360/cloud-lightning.ino.eep"
"C:\Users\John\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-objcopy" -O ihex -R .eeprom "C:\Users\John\AppData\Local\Temp\arduino_build_376360/cloud-lightning.ino.elf" "C:\Users\John\AppData\Local\Temp\arduino_build_376360/cloud-lightning.ino.hex"
Sketch uses 5200 bytes (18%) of program storage space. Maximum is 28672 bytes.
Global variables use 144 bytes of dynamic memory.
C:\Users\John\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/bin/avrdude -CC:\Users\John\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/etc/avrdude.conf -v -patmega328p -cusbtiny -Uflash:w:C:\Users\John\AppData\Local\Temp\arduino_build_376360/cloud-lightning.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\John\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/etc/avrdude.conf"
Using Port : usb
Using Programmer : usbtiny
avrdude: usbdev_open(): Found USBtinyISP, bus:device: bus-0:\\.\libusb0-0001--0x1781-0x0c9f
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : USBtiny
Description : USBtiny simple USB programmer, http://www.ladyada.net/make/usbtinyisp/
avrdude: programmer operation not supported
avrdude: Using SCK period of 10 usec
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "C:\Users\John\AppData\Local\Temp\arduino_build_376360/cloud-lightning.ino.hex"
avrdude: writing flash (5200 bytes):
Writing | #######
avrdude: error: usbtiny_send: (expected 128, got -116)
#avrdude: 1 retries during SPI command
avrdude: 2 retries during SPI command
avrdude: 3 retries during SPI command
#avrdude: 2 retries during SPI command
avrdude: 5 retries during SPI command
#avrdude: 3 retries during SPI command
# | 100% 126.80s
avrdude: 5200 bytes of flash written
avrdude: verifying flash memory against C:\Users\John\AppData\Local\Temp\arduino_build_376360/cloud-lightning.ino.hex:
avrdude: load data flash data from input file C:\Users\John\AppData\Local\Temp\arduino_build_376360/cloud-lightning.ino.hex:
avrdude: input file C:\Users\John\AppData\Local\Temp\arduino_build_376360/cloud-lightning.ino.hex contains 5200 bytes
avrdude: reading on-chip flash data:
Reading | ###########################################avrdude: 1 retries during read
####### | 100% 0.25s
the selected serial port
does not exist or your board is not connected
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x0126
0x34 != 0xff
avrdude: verification error; content mismatch
avrdude done. Thank you.
Reply 1 year ago
Yep you're definitely getting an upload error. That can happen for a lot of reasons, and the folks most equipped to help you are the creators of the Pro Trinket, Adafruit. You'll have to head over to the Adafruit forums and ask about using the Pro Trinket on Windows. They should be able to help you out! Post the same information over there (always provide all the information you can, to help debug!) and they'll give you recommendations.
https://forums.adafruit.com/
DanielM972
1 year ago
So I used your code to put together a string of LEDs that I'm placing into a "lightning staff" for a halloween costume for my son. I'm trying to get the flashes to happen in a lot faster succession (think like something that's charged with electricity). I saw that you have in your code the variables to change the frequency of the lights going, but I'm not sure which way to modify them. Could you give me any pointers? Sorry... I'm not a coder at all...
molecule13DanielM972
Reply 1 year ago
Sure. The way this works is I set a "chance" variable to either 5 (high strike likelihood) or 10 (low strike likelihood). The chance variable gets passed into the "random" function. We can see in the arduino documentation[1] that when the "random" function takes one argument, that argument is the "maximum" value. So it'll return a random number between 0 and that maximum value minus one.
In other words random(chance) in English is: "a random number between zero and chance minus one". So if chance is set to 10 it'll return a random number between 0 and 9, and if chance is set to 5 it'll return a random number between 0 and 5.
Let's look at the whole line[2] and interpret it into English:
if (random(chance) == 3)
if ( the random number between 0 and chance is equal to 3)
...then do the next thing. So, if you want to make it more likely all you have to do is make that statement something that's more likely to happen. So if you want it to do a lightning strike 50% of the time, you might change it to:
chance = 1
if (random(chance) == 0)
The only options for a random number between 0 and 1 are 0 and 1! So 50% of the time (on average) you'll get a lightning strike.
The other thing you might want to change for a more "electricity" effect is the delay between strikes (make the number here smaller): https://github.com/molecule/cloud-lightning/blob/v1.0/cloud-lightning/cloud-lightning.ino#L104
Or the delay between the flashes in the ligthningStrike itself (make the max number here smaller too):
https://github.com/molecule/cloud-lightning/blob/v1.0/cloud-lightning/cloud-lightning.ino#L120
For this part, you'll really just have to mess around with the code until it looks like you want it to look! I don't have any special knowledge that lets me design this: I just played around until I liked it. I hope you'll share your changes with us when you're finished! I'd love to see a video of the completed project. Good luck :)
[1] https://www.arduino.cc/en/Reference/Random
[2] https://github.com/molecule/cloud-lightning/blob/c3af10c57ad2d1b4f775eebefa147384399d5827/cloud-lightning/cloud-lightning.ino#L90
Clayface18
1 year ago
I juat want to say thank you for your instructable.except for the actual programming part(installing/uninstalling drivers like crazy) everything went smoothly. Your code is amazing and thank you for sharing. Only question i have is there a way to adjust colors of neopixels so they flash different colors?
