How to Make a Railroad Spike Knife?
84,058
790
36
Railroad spike, a special nail widely used in the railway industry, is an important component of rail fastening system. Among the railway system, the railroad spike is usually used to fasten the rail track. Besides fastening, the railroad spike can also be made into some metal artworks such as knife, bottle opener, furniture and so on with reprocessing.
Supplies:
Step 1: Heating the Railroad Spike
Step 2: Forming the Handle
Step 3: Rough Shaping the Blade
Step 4: Drawing Out the Blade
Step 5: Shaping the Blade Outline
Step 6: Forming the Blade Edge
Step 7: Curving the Handle
    • Woodworking Contest
      Woodworking Contest
    • IoT Challenge
      IoT Challenge
    • Party Challenge
      Party Challenge
    36 Discussions
    LouisC49
    2 months ago
    There are two kinds of spikes, the ones to look for have HC on the head, they maker a better knife
    Chis Thompson
    10 months ago on Introduction
    Did you get the artists permission to use the photo at the top of your article? Are you leading everyone to believe you made that knife and photo?
    newjorik
    3 years ago
    they call that the power of forging, it's kinda what this whole instructable is about
    deus ex
    3 years ago
    reminds me of improvised trench knives of world war 2 where soldiers would have a trench spike flattened into a double sided blade and have the rest of the bar folded into a hand guard.
    rpelletier1
    3 years ago
    can be found at McMaster - Carr or MSC I believe
    rpelletier1
    3 years ago
    Caseinite A product for case hardening steel. Comes in a can in granular form. just cherry the item to be hardened and stick in a couple times should do the trick. Also known as case hardening. made a cold chisel in junior high metal shop. worked well
    for years. case hardening is surface only. not sure of depth but should work.
    for years.
    Midgaardssmeden
    3 years ago
    Very nice letter opener.
    Unfortunately, that's all it is. RR spikes are classed as low-carbon steel, which means they can't be heat treated, which again means that they can't hold an edge. But nice work.
    ironsmiterMidgaardssmeden
    Reply 3 years ago
    2 weeks later, I think of a better "comeback" :-)
    For over 2000 years of bladesmithing history, BRONZE was the very best knife metal available. And it worked quite well.
    In terms of hardness, a good bronze is in the mild steel range.
    Reply 3 years ago
    agree and disagree, on many levels.
    COMMON railroad spikes(like they use in actual railways) are as you say. Though their edge retention is better than you may expect. Even low carbon, un-hardened steel can hold a pretty good edge for a usable length of time. And in the tradition of boyscout knives everywhere, a quickly dulling knife gives you great practice in sharpening. at least that's MY theory on why they make the official pocket knives out of whatever type of steel(possibly just really hard butter) it is.
    To add fuel to the fire, I know of at least one smith who got a hold of a die set for forging RR spikes and produced them in both 01 and 440 in small quantities, and then made knives from THAT. And also, at least on company in china that was making drop forged "china stainless" knives from barstock, that were then dressed and "sharpened" to LOOK like a hand forged spike knife.
    leeroystakeironsmiter
    Reply 3 years ago
    nice jobe mate. Im a suburbanite but have had some great results using a 20gal drum/concrete spiral forge out in the workshop with a blowtorch.
    raw spikes need a shedload of grinding to be up to scratch though.
    these would make an amazing steak knife set with some filing too!
    definitely got the skills that pay the bills.
    cronosamv
    3 years ago
    Great concept, beautiful and simple blade, well done!
    tecton47
    3 years ago
    I wish I had the equipment and skills necessary to do projects like this. It's a safe bet that my landlord would frown on me setting up a forge in my living room and the neighbors would complain about the constant banging. Blowing glass has always fascinated me too but again we have that forge problem.
    Pan Zijintecton47
    Reply 3 years ago
    Same, I don't have the space either. :/
    TimA13Pan Zijin
    Reply 3 years ago
    Sure you could try, I've heard of people using arc welders on a Harley in a unit before, nothing is impossible.
    Leathaldosetecton47
    Reply 3 years ago
    you don't need a forge for glass blowing, just a torch and some patience.
    ironsmiter
    3 years ago
    I have one I got as a Christmas present, and several I have now made.
    The biggest step from "neat knife" to "Holy Awesomeness" has been the addition of 2 passes of chrome-manganese weld bead onto the blade edge, before sharpening.
    Most railroad spikes are "steel" in much the same way re-bar is "steel", but not quite as bad. The addition of a hard-facing material to the blade edge takes only a few moments(mostly setting up the welding equipment) and gives an infinitely superior edge retention to the finished product. At least when used as a real tool, rather than a decoration or weapon(yes, weapons can afford softer blades. straighten and sharpen them after the fight, at your leisure, provided you win).
    You COULD forge-weld a piece of blade steel into a groove before shaping the blade bevel. A once common practice in ax making. Reserving the good steel for JUST where you need it. But a welding machine, and a proper rod are faster, and easier.
    In your finished product(first step) we see a nice standard twisted square handle, but in your final step, you are putting a curve into the non twisted handle. For the edification of non-smiths out there, would you add the twisting step in, and for the sake of completeness, an image of your finished curve-handle blade?
    P.S. Nice hammer!
    Vergaironsmiter
    Reply 3 years ago
    You can avoid that step by purchasing High carbon steel spikes. They are available on e-bay and have HC on the end.
    ironsmiterVerga
    Reply 3 years ago
    actually, no you cannot. The hc spikes are NOT knife grade high carbon steel.
    Non HC spikes are a MAXIMUM of 0.12% carbon.
    HC spikes are a MAXIMUM o 0.30% carbon.
    This, by definition, makes them both mild steel. Can they be case hardened? Sure. Will they ever be mistaken for a 'true' knife steel? No.
    Standard knife steel is between 0.8% and 1.5% carbon. Plus, the alloying metals will be different too.
    If ebay isn't your thing, McMaster-Carr still carries them. $2 per spike, in a 5 pack.
    TimA13ironsmiter
    Reply 3 years ago
    yeah the high low carbon thing, throw the hot nail in oil, called Bluing, that will increase the carbon.
    mjursicironsmiter
    Reply 3 years ago
    Where would I get chrome-manganese filler rod?
