Huge Lens Flashlight Experiment XHP70
9,067
67
18
About: There is no greater harm than that of time wasted - Michelangelo Buonarroti
In this instructable I will show you one of my experiments with huge lens and powerful led. I hope you will like it :)
It is the second flashlight that I build, this second flashlight is a throw flashlight that can light the clouds. I tested it at 1,5 miles and the light was bright at this distance. The flashlight is build with powerful xhp 70 cree led powered by led regulator circuit and huge lens.
In the future I will test a monster 500w led and the huge lens that you can see in the last picture
Step 1: Materials
Lens - Optical Glass Plano Convex Condenser Lens
PVC pipe to fit the lens
PC processor cooler
LED
LED driver circuit
On/Off switch
12v Battery
Silicone
Thermal paste
Step 2: First
Start by cuting the PVC pipe at a distance to fit all the pieces, I cut mine about 40cm long.
Make holes in it for ventilation
Use clear silicone to glue the lens on the pvc pipe fitting.
Add a layer of plastic primer and few layers of paint for design :)
Step 3: Electronics
Make holes in the middle of the cooler plate and tap and die set to make thread.
Add thermal paste and attach the led with screws
Cut a round piece of wood and make a hole in the middle of it.
This piece must hold the led in the middle of pvc pipe.
Put it inside the pipe and secure it with screws.
Make a hole and attach the on/off switch.
I used xhp70 led, led driver and 12 v li-ion battery with BMS
The cooler fan need 12v (no need for voltage converter)
In the pictures you can see many wires and on/off switches because I wanted to use 5 led types to experiment with.
Step 4: Done
I hope this will help you :)
Sorry for my english!
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    • Arduino Contest 2019
    18 Discussions
    JohnC430
    3 months ago
    can you please post a link for the cooler? Thanks
    ImpactDIYBardP
    Reply 3 months ago
    . That is a good idea, it may work. I don't think that cooling is needed.
    KryptoTSD
    3 months ago
    Seeing as the lens is at the top of the list of components, and henceforth the most important, what diameter is it, and how thick is it in the very centre? This is an important detail that is missing from your instructable... Also, where did you get the lens and how much did it cost?
    ImpactDIYKryptoTSD
    Reply 3 months ago
    Hello, sorry to be late, the 3 lenses are Optical Glass Plano Convex
    Condenser Lens. There are three lenses size that I used. The first one
    is 13 cm diameter and I recovered it from a Krokus photo enlarger.
    Second one is 20 cm diameter. The big one is 32 cm diameter. The second
    and the third are recovered from old, broken theater reflectors. If you have more questions please ask, I am glad to answer.
    ImpactDIYLeigh Havard
    Answer 3 months ago
    FrozenInCND
    3 months ago
    The most important part of this build is the Lens, could you pleas tell us about it ( where you got it diameter......etc).
    ImpactDIYFrozenInCND
    Reply 3 months ago
    falcondob
    Question 3 months ago
    What was the diameter of the lens you used? (in mm please) Thanks!
    1 answer
    ImpactDIYfalcondob
    Answer 3 months ago
    Hello, sorry to be late, the 3 lenses are Optical Glass Plano Convex Condenser Lens. There are three lenses size that I used. The first one is 13 cm diameter and I recovered it from a Krokus photo enlarger. Second one is 20 cm diameter. The big one is 32 cm diameter. The second and the third are recovered from old, broken theater reflectors.
    JurajP1
    3 months ago
    you wrote XHP70, but on video is more powerful led...
    ImpactDIYJurajP1
    Reply 3 months ago
    Hello, there are 2 flashlights, the one in the first video has xhp70 ked, the one in the second video has 100w led. I also made one instructable for it , you can find it on my profile.
    waynoedm
    3 months ago
    Do you have sources for your materials? Primarily lenses and LED lightsource. Thanks. :)
    ImpactDIYwaynoedm
    Reply 3 months ago
    Hello :), led model is XHP70, you can find led and led driver on ebay, aliexpress etc. The lens are from a krokus photo enlarger (small one), and from theater reflectors (middle and big one)
    ImpactDIYEcoExpatMike
    Answer 3 months ago
    Hello, I used Optical Glass Plano Convex Condenser Lens
    formender
    3 months ago
    Das nenn ich mal ne "Taschenlampe"... :) Klasse Projekt. Bin gespannt, was als nächstes kommt. Meine Stimme haben sie. Frohes Schaffen und Gruß aus Hessen.
