Huntsman Knife Part 2
3,620
37
4
About: Hello I made this account so I could show you how I have make some of my projectsI like wood and metal working I hope you enjoy my content and please follow or like also fell free to ask questions
This is part 2 were I make the handle
Supplies:
Step 1: Marking
I marked the knife on the wood also I did a few thing to the knife to make I look better
Step 2: Cutting
Use a saw or jigsaw to cut handle out then cut in half
Step 3: Glueing
Use two part epoxy on handle then apply pressure on knife and wait for dry
Step 4: Sanding
Use a wood file and sandpaper to make a handle to fit your hand
Step 5: Paint or Lacker
I painted the handle with black paint then after two days I decided to use lacker on handle
Step 6: Sharpening
Use a bench grinder first for a rough sharpening then use file and sandpaper for a nice sharp blade but I'm go going to have I bit blunt because I'm gonna use it for hacking branches
Step 7: Done
Please like and comment any ideas
    • Woodworking Contest
      Woodworking Contest
    • Arduino Contest 2019
    • Party Challenge
      Party Challenge
    4 Discussions
    McJarod_ImLovinIt
    3 years ago
    this guy has very simple tools, and he does it amazingly
    McJarod_ImLovinIt
    3 years ago
    SJLight
    3 years ago
    Hi,
    It's good to see you want to make knives but I would like to offer some tips.
    First, use a steel that will harden. All that work for a knife that won't hold an edge is a shame. I don't know what country you're in but if you let me know I'll mention some simple carbon steels that you can get there and can heat treat yourself.
    Second, spend more time on that blade before you move on.
    If you see what I've done here, and compare it to your's you can see what I mean.
    http://www.stewartjlight-knives.com/2011/03/kith-k...
    Although I've used a belt grinder you can do the same with a file or the flat side of your stone wheel. You don't have to go as high as I did on that one but take your time to get it even. Once you've done that then heat treat it to harden the edge and turn it into a usable tool.
    Third, the handle area. I bet that handle is not as comfy as it could be. It looks like it would fit the hand well if you rounded out the finger grooves. Next, drill some pin holes in the steel before you harden. The handle you've done, if it gets knocked to the side the glue might not hold up. Pins will stop that. Also, sand a shape the front of the handle scales before you glue it all together. Getting into that area when glued is so tricky.
    If you see this handle, it shows what I mean.
    http://www.stewartjlight-knives.com/2011/02/custom...
    Any questions, feel free to ask and I hope that helps you in your knifemaking.
    cronosamv
    3 years ago
    Great project mate the Huntsman is a great design. I've made one myself, was looking for a photo to share so you could see it but can't seem to find any photos on my HDD, I'll post when i find it. A few suggestions, you should have tried to heat treat the blade, for a blade that small u can use your coal BBQ ;) depending on the steel you used, with a bit of polishing you could get a nice hamon, also the lines on the handle are very sharp, a little more shaping would make the handle more ergonomic. Still great job.
