I Made a Hardwood Pokéball
9,834
78
9
About: Hey, This is Alpaca Studio.
Recently, I got a new wood lathe. So I decided to make this Pokeball.
The ball has four different parts, which are the top red section, the mid black section, the bottom white section, and the button. For each part, I used different woods to mimic the Pokeball color. The diameter of the final product is 70mm.
Supplies:
Step 1: Material & Tools
Material:
  • African Padauk (red part)
  • Ash, white (white)
  • black walnut black)
tools:
  • drill press
  • bandsaw
  • wood lathe
Step 2: Rough Cut the Material
The first thing you need to do is drill a hole in the middle of the wood. The hole should be the size which can fit your wood lathe. You should not go through either the red and white wood to achieve a half sphere. But you need to drill through the black section.
After that, you can roughly cut the wood to the round shape so that it can be easy to work on the lathe.
Step 3: Turn the Mid Section
This walnut piece is 65mm in diameter and 5mm in thickness.
Step 4: Turn the Red and White Parts
I didn't have any sphere jig to work with. So the shape might not be perfect.
Step 5: Glue Together
Get a wood stick which has the same diameter of the hole. Since you already have drilled the hole. You can just glue these parts together.
Step 6: Make the Button
Now it's time to make the little button. It has two parts. A walnut outside part and an ash inside part.
Step 7: Drill the Hole on the Ball
It's really hard to drill a big hole in the ball. So I made this jig. It's just two piece of plywood and three long screws and nuts. But its very useful for this kind of purpose. I clamp the jig to the workspace of the drill press. Make sure that everything is tight and not move.
Before drilled the big hole, you can pre-drill a smaller one for guiding.
Step 8: Insert the Button
Glue together these two parts and use a vise to press it to tight.
Step 9: Finish
Finish it with wax and oil. Enjoy your wood Pokeball and go catch some Pokemon!
    • Woodworking Contest
      Woodworking Contest
    • Gardening Contest
      Gardening Contest
    • Fandom Contest
      Fandom Contest
    9 Discussions
    Nick70587
    5 months ago
    Very nice! I especially like the jig for holding the ball while drilling. I had the same problem with one of my projects (https://www.instructables.com/id/Home-Defense-Mace...) a while back and used a five sided box a tiny bit bigger than the diameter of the ball and put screws in the center of each side with the top open for the drill. It worked pretty well but my final product was going to have holes in it anyway so the screws didn't matter. Maybe you could find some modifications if your looking for a different way. I didn't even think of trying your jig method but I will try it in the future. Good Job!
    Alpaca StudioNick70587
    Reply 5 months ago
    Nice Jig dude. You could also put towels between the jig and the ball to add more friction. That will also prevent the jig from leaving marks if the ball is not hard enough.
    attosa
    5 months ago
    Jumping on the "thats a beautiful red" train. Wow!
    rayp1511
    5 months ago
    I'm going to have to get a lathe, so many things you can do. Nice work on the Pokeball.
    theguymasamato
    5 months ago
    I learned something new.
    Thanks for sharing your "ball-drill-jig".
    Folded Shirts
    5 months ago
    I agree with EveW12. Lovin' that red.
    EveW12
    5 months ago
    That is a neat red color
