I Built This Bike Trailer
27,936
162
17
I built this bike trailer out of an old jogging stroller.
Supplies:
Step 1: The Hitch Mechanism
Hitch mechanism made of 3/4" flat stock and a Quick Disconnect Type 3/8-24 Fine Standard Thread Ball Joint and Rod End. http://www.amazon.com/gp/product/B002HAUWCM/ref=oh_details_o01_s00_i00
$18 with shipping
I made some teflon washers to go against the bracket and tightened the backnut against the joint to allow a little slack for y-axis movement of the arm beyond the ball joint movement.
Step 2:
I made the mounting bracket from a zinc plated strut pipe clamp- $0
Step 3: The Tray
The wheels and from were from a jogging stroller that had been decaying in the back yard. The box is a spare drawer from our kitchen remodel. $0
Step 4: Tubing
The tubing was from the jogger handle. -$0
 I used stainless deck screws to fasten the tubing to the tray.
Step 5: In Use
The trailer loaded with 5 bags of ice, 12 pack of soda, and some misc groceries.
    • Woodworking Contest
      Woodworking Contest
    • Gardening Contest
      Gardening Contest
    • Arduino Contest 2019
    17 Discussions
    Dale_D
    6 years ago on Introduction
    Forgot to ask, what is the black bracket looking thing between the wheels? Is it part of the stroller wheels?
    zymieDale_D
    Reply 6 years ago on Introduction
    Yes, I used the jog stroller axle and part of the frame. I need to take some pictures of the underside.
    gnach
    6 years ago on Step 5
    How well does it track when turning? I see that it isn't rubbing the tire in the last image but what about while rolling?
    zymiegnach
    It tracks well. I was careful when I measured the mounting arm to make sure the trailer ended up centered behind the back tire. I've made some fairly tight turns without any rubbing.
    Bradinsc
    Great plan! I have a set of wheels like that, and some time on my hands....... I am going to make a similar cart for the back of my power wheel chair! That will help with shopping with the wife for sure! Thanks for the great idea! I like the hitch idea as well.
    Dale_D
    Great project & nicely done! I need to build a trailer for myself too. I have a set of 20" bicycle trailer wheels, but I like the smaller jogging stroller wheels better.
    Here is another resource for parts like the ball joint:
    http://www.mcmaster.com
    I found some on their that would have cost you less, but you have to watch out for their shipping. Some were made of Stainless Steel (& shielded), and they have one that doesn't need lubrication as well (won't squeak?). Maybe some upgrade possibilities?
    shumphrey1
    Love it, simple, easy to do by most with a bit of diy savvy!!! ;)
    zymiejawasan
    Thanks, I found that hitch after scouring Google for a simple solution. If I can find the original source I'll try to add the credit.
    zymierimar2000
    Your trailer project is very detailed! I found that hitch after scouring Google for a simple solution. If I can find the original source I'll try to add the credit.
