IKEA Hack
699,918
1,486
62
About: My name is Randy and I am a Community Manager in these here parts. In a previous life I had founded and run the Instructables Design Studio (RIP) @ Autodesk's Pier 9 Technology Center. I'm also the author ...
The nice thing about IKEA furniture is that it is cheap and easy to hack. In other words, lets say that you were to buy two Gorm shelving units and assembled them to discover that one was crooked. Well then, it would be really easy to spend an afternoon converting the crooked one into a solid, stylish and symmetric bookshelf bench.
As you probably just guessed, this Instructable will show you how to convert a shelving unit into a bookshelf bench. With a few extra peices of hardware and a couple of basic power tools, you could be on your way to relaxation and organization all at the same time.
Update: You can no longer buy these types of shelves directly from Ikea, but you can still get them second-hand. Alternately, you can try converting one of Ikea's newer shelving systems.
Step 1: Go Get Stuff
Materials and tools that you will need:
(x1) Gorm shelving unit
(x1) 2x4
(x1) 92.75" x 12" x 3/4" piece of plywood (I inherited an awesome piece of bamboo plywood for this project)
(x16) 3/8" Crossdowels
(x16) 2-1/2" bolts (to fit crossdowels)
(x8) 2" woodscrews
(x1) 50 feet of rope
(x1) A tape measure and pencil
(x1) Circular saw
(x1) Sanding block and/or sandpaper
(x1) Power drill, 3/32" and 3/8" drill bit
(x1) Assorted hand tools
Fabric, foam and stuff for a cushion - see Step 13
Please note that some of the links on this page contain Amazon affiliate links. This does not change the price of any of the items for sale. However, I earn a small commission if you click on any of those links and buy anything. I reinvest this money into materials and tools for future projects. If you would like an alternate suggestion for a supplier of any of the parts, please let me know.
Step 2: Assemble Your Crooked Bookshelf
Assemble your Gorm bookshelf to realize that two out of the 4 posts are crooked. Stare at it in displeasure.
Resolve to take drastic actions.
Step 3: Cut a 2x4 Into 4
Cut four 12.25" lengths of 2x4.
Step 4: Drill Holes
With a 3/8" drill bit, drill holes in the ends of the 2x4 such that they are 3/4" in from each edge (top, bottom, left and right).
Also drill holes on the flat surface of the board that is 2" in from the far edge and is perfectly aligned with the hole you first drilled. In other words, this hole should intersect at a 'T'.
Step 5: Take Apart Your Bookshelf
Disassemble your horribly crooked bookshelf. Select the two prettiest and straightest beams to cut up for use as the supports for the bench. You will be able to make six supports with these two beams.
Using the two ugly beams, you should be able to get 1 support from each.
Step 6: Cut the Beams
Cut one of the nice-looking bookshelf beams starting from the bottom edge (edge that used to be on the floor) and cut it to a height of 18.25".
Next, take the first piece you cut and line up its holes with the holes on the new bottom edge on the board. Make a mark on the longer board at each end of the first cut beam. Using the two lines you just drew as cutting guides , make two cuts. You should now have a second beam. Now, use the first beam to line up to the holes on the opposite side of the board and make cut marks as appropriate so they are all the same size. Cut at these markings. You should now have 3 beams.
Repeat this process on the second pretty looking beam.
Next grab the two ugly-looking beams. Measure in from either the bottom or top edges (whichever edge looks best) of both ugly beams and make one cut on each to produce two more 18.25" beams.
You should now have eight 18.25" beams with all of the holes lined up.
Step 7: Sand
Sand and smooth any rough edges you may have from sawing and/or drilling the 2x4 or bookshelf beams.
Step 8: Insert Cross Dowels
Insert cross dowels into the four holes drilled through the surface of the 2x4 sections. Depending on the tolerance involved, this may require driving the crossdowels into the holes with a hammer. To push it in beyond the surface of the board, place a screwdriver or chisel atop the crossdowel and slightly tap it with the hammer. Make certain that the slots on the crossdowels are all facing the same direction inside the board.
Step 9: Build the Frame
Using the Ikea hardware, attach three shelves to the lowest holes in the bookshelf beams. Next, using your 2.5" bolts and crossdowels, attach the 2x4 sections to the topmost holes of the boards.
Step 10: Fasten the Seat
Flip your bookshelf bench upside down so that it is perfectly aligned over the top of your plywood.
Drill two 3/32" pilot holes in each of the 2x4s such that it goes all the way through into the piece of plywood.
Using your woodscrews, fasten the plywood to the 2x4. Make sure you apply a lot of pressure downwards while drilling so that the two surfaces are fastened tightly flush together.
Step 11: String It Up
Thread rope through the extra screw holes in the boards to serve as book ends and keep books from falling off the ends or through the cracks in the middle.
Basically, on the two ends, you should tie a knot and pass the rope through to form a rectangle. Once all the way through, pull it tight and tie the rope together so that the rectangle is closed.
The middle sections are slightly trickier, but basically you do the same thing, but rather than closing the rectangle by tying it shut, you start to pass it through again from the back to form another rectangle. Once done, you pull it tight and tie the end of the rope to the knot at the beginning. This will create two sets of two parallel ropes and two "vertical lines" in the front, which will aesthetically match the two ends.
Step 12: Add Books
Arrange your books on the book shelf. You may want to consider placing larger books towards each end to make sure the rope doesn't accidentally let smaller books slip through.
Step 13: Make a Cushion (optional)
Make yourself a nice comfortable cushion as outlined in the this Bench Cushion Instructable.
3 People Made This Project!
  • Arduino Contest 2019
  • Gardening Contest
    Gardening Contest
  • Trash to Treasure
    Trash to Treasure
62 Discussions
randofoKirstyM27
Reply 5 months ago
Dowels would be a nice solution. Very stable and classy looking.
LovesGadgets
2 years ago
We lost all our Gorm shelving screws in our last move! Worst thing that happened. Ikea sells 4 screws for $9.90 plus shipping, but need about 50. What size do I need as a replacement? Figure it must be metric.
Any help from the Instructables community is MUCH appreciated. Thanks.
LovesGadgets
Luziviech
2 years ago
if you need a shoe rack, replace the silly black screws by ~15cm long counter-sink bolts that run with their heads evenly into to the planks and use wooden angles cut to 45° (Pythagoras helps out measuring the longer sides of these trapezes) for stability of the construction before screwing all to a wall - i'm too lazy to write an ible for this; i build all my boards like this, cheaper than buying angles from the hardware store.
BartholomewH
3 years ago on Introduction
Dope flat pack hack you've done there! The crooked bookshelf you've assembled has turned out look absolutely awesome! Montage looks clean and stable, all steps are clear and easy to follow. This is how you do furniture assembly the right way! I myself would personally even change to bookshelf colour but RAW is beautiful as well!
Kind Regards!
Barth,
Fantastic Furniture Assembly
ninjachimp09
4 years ago
cool looks like I'm going to IKEA
raxas
4 years ago on Step 6
hahaha best assistant ever!
msharpe4
5 years ago
What weight will it support?
djabunDANCE
6 years ago on Introduction
I love this! but i need a specific size for my project (70"W x 20"H).
I didn't see the finished size anywhere (maybe i didnt look hard enough ;)
Seems 92.75"W x 18.25"H x 12"D to me...
Could you let me know for certain? Thanks!
_pstsh
Hello guys !
Im from France and I have to convert all those measures to european system.
Anyone knows what size of lumber in centimeters is a "2x4" ?
Is it 1.5 in × 3.5 in so 3,8 cm × 8,9 cm ?
Thanks!
tfm
7 years ago on Step 1
Could someone tell me the size of the heads on the hex bolts? Even Ikea doesn't know...I need to break some down in my storage space and I don't want to lug a full ratchet set.
Thanks!
shivika
7 years ago on Step 3
how do you get 4 12.25" pieces from a 48" piece of wood. doesn't that total 49". should it be 12" inches each?
