IKEA Infinity Mirror
252,393
1,793
77
I decided to try building an infinity mirror after seeing this post here on instructables. I had the IKEA frame laying around and decided to try to use that, and it was actually a really god fit for this project.
You'll need:
  • IKEA Ribba Frame (ribba)
  • LEDs - I used RGB (WS2812B)
  • Mirror Film (film)
  • Mirror
  • Wire
  • LED Driver (Arduino or a kit that comes with the RGB LED strips)
  • 5V Adaptor
You could maka a simpler version by just using a single piece of LED strip and wrap that around the sides, but I had these LEDs laying around from another project.
The RIBBA frame is available in black which would save you the painting also.
Supplies:
Step 1: Drill Template
Everything is mounted on the inner frame which leaves the outer frame nice and untouched.
I made a simple drill template and glued it to the sides of the inner frame to get even spacing of the LEDs.
Step 2: Drill Holes
I drilled 8mm holes for the LEDs.
Step 3: Countersink
Drilled 12mm countersink holes that the LED will drop into, so that they fit between the inner and outer frame.
Step 4: Paint It Black
You don't want to see the fram inside of the mirror.
Step 5: Glue on the LEDs
Used some hot glue to glue on the LEDs.
Step 6: Wire It Up
These LEDs have positive (+5V), negative (GND) and a control pin. You'll just need to connect them in a long serie. These's a about 1mm of space around the inner frame, make sure the wire will fit inside the outer frame.
SparkFun explains it all on how to hock up the LEDs. ws2812 guide
Step 7: Hot Glue As a Diffusor
I cut small pieces of a hot glue stick and used that as a diffuser for the LEDs, to give it a nice soft lightbulby look. I glued them on infront of each LED.
Step 8: Add the Mirror Film
Add the mirror film to the inside of the frame glas. This was tricky, use a drop of soap in water and spray it on the glas before adding the film. (I'll probably redo this part again later, I ended up with a lot of small bubbles/imperfections. But they don't really show when the light is on)
Step 9: Drop in the Glas
Test drive with the one way mirror film in place.
Step 10: Add the Paper Letter
I added a paper letter (my sons initial) in the center which I got from the local craft store. here Which I think really add a nice personal touch to the project.
This is a nice instructable if you want to make your own.
Step 11: Drop in the Mirror
Drop in the mirror and add the protective back on it.
Step 12: All Done
Homemade Gifts Contest
Third Prize in the
10 People Made This Project!
  • Fandom Contest
    Fandom Contest
  • Party Challenge
    Party Challenge
  • Arduino Contest 2019
77 Discussions
RamiH10
1 year ago
Thanks for the clear instructable! I used it to create an infinity chess board :-)
AndrewB638RamiH10
Reply 5 months ago
May i ask how you went about creating the grid lines for the board?
RamiH10AndrewB638
Reply 4 months ago
I cut a large white sticker into thin strips and glued them on the (inside of the) glass panel.
MajesticDoge
2 years ago
Could I use this:https://www.amazon.com/12-Acrylic-See-Through-Mirror/dp/B017ONH3EG/ref=sr_1_2?ie=UTF8&qid=1493416571&sr=8-2&keywords=one+way+mirror instead of the mirror film
wesley35601
2 years ago
can you upload the code, im a beginner and have a nano board
Sergey Chernyshev
2 years ago
Planning to make one like that, maybe battery-powered though.
Made a 3D model of the RIBBA mirror in case somebody needs to plan their project:
http://www.thingiverse.com/thing:1752490
mprosek333
2 years ago
I'm planning to make one of these in the near future, but I just wanted to make a suggestion for the diffusers which I think might work: you could also possibly use clear bump-ons that are normally used for the back of picture frames, cabinets drawers, or the bottom of coasters! You can get them at hardware stores in the picture hanging hardware area, or craft stores. This is what they look like: https://www.amazon.com/3M-SJ5312-Bumpon-Blister-B...
If anyone else tries these, I'd love to know how it goes! (I probably won't be making my frame until September, but I'll post my notes when I do make it)
mprosek333
2 years ago
mprosek333
2 years ago
mprosek333
2 years ago
Heyup
2 years ago
This is one of the best I have seen, I made one a while back with just white led strip and it is "ok ish " but does not have much depth! any idea what I could have done wrong? Keep sharing your amazing talent, Thanks... John :)
mprosek333
2 years ago
mprosek333
2 years ago
safe_silence
2 years ago
awesome instructable! Instead of getting a custom mirror made, would the effect work with mirror film used for both he front AND back?
Orwa Diraneyya
2 years ago
Using sliced hot glue stick as diffuser is ingenious
MoK6
3 years ago
Are you sure that template is correct? I've printed it a few times, but it's too small. Using the 23cm square RIBBA frame.
ChristianS13
4 years ago on Introduction
Where did all you guys get the 23cm x 23cm mirror?
haven't found one online, so I will have to order a custom sized one...
thx for this idea, will start soon my first one and will report back...
