In-drawer Knife Organizer
6,999
120
20
About: I'm16 and in my free time I control cockroaches, weld, make canoes from duct tape, 3D print, make helmets, light big pieces of wood on fire, and other awesome stuff
A good set of knives is always needed in any kitchen; but it's hard to use them if your drawer knife block is too small to hold all of them. My mom has had this problem almost forever; the cutting utensils have never fit in to the weird plastic and wood holder that we have and end up strewn every which way. I decided that I needed to set things straight! literally.
Supplies:
Step 1:
Items Needed
  • One piece of wood as big as the drawer you want it to fit in.
  • Router
  • Various router bits
  • Circular saw
  • Sandpaper
  • Can of clear coat
  • Stapler
  • Step 2: Cut It to Size
    The piece of wood I had was actually cut from my failed attempt at making a fire canoe. Since it was too big to fit in the drawer I measured how big the drawer was and made a paper "map" of it. I used the map to mark the edges on the wood, I tried to mark it so that I had a bit of a natural edge. Then, I used my circular saw to cut the edges off.
    Step 3: Plane
    I wanted the piece to be as flat as I could get it with the tools I had so I decided to use my router. If you have access to a planer that would be easier than using a router. I mostly eyeballed my way around to start out. After a while of that I soon decided to set up a little jig by screwing the router to a small piece of wood I had and moving it around on top of two blocks.
    Step 4: Drawing and Stapling
    I traced the knives on my "map" of the drawer from largest to smallest, which I thought looked the best.
    Step 5: Routing
    For most of the knife spots I used a 1/2 inch bit and plunged it about a quarter of an inch. Then I routed the rough shape of the blade part and did the same for the handle part only twice the depth.
    The bread knife is laid out differently so it was a little bit trickier.
    Once all of the knife spots were rough cut I put the actual knives in for a test fit. If they didn't fit very well I marked the spot with a pencil and used the router again.
    Step 6: Details
    Since the router bits make round cuts I used a chisel to make them into points and to remove any imperfections. Also, I used some medium grit sandpaper to remove some of the burn marks caused by the router and to round some of the edges.
    After test fitting it in the drawer I realized that the drawer handle bolts interfered with the piece of wood so I went back with the router and removed some material to make it fit.
    Step 7: Clear Coat
    After I removed the imperfections I clear coated the wood to bring out some of the color
    Step 8: Put Knives in It!
    If you liked this instructable consider following me or voting for this instructable in some of the contests I have entered it in
    Home Improvement Contest 2017
    Third Prize in the
    Makerspace Contest 2017
    Runner Up in the
      • Party Challenge
        Party Challenge
      • IoT Challenge
        IoT Challenge
      • Arduino Contest 2019
      20 Discussions
      jeanniel1
      1 year ago
      Pretty good for not CNCing it!
      KellyCraig
      1 year ago
      Rub some mineral oil on those knife blades and you'll be amazed how beautiful the wood is. Mix in some bee's wax and Carnuba wax and you have a down town finish.
      Another plus of the mineral oil is, those cracks may disappear, as the moisture lost from years of drying is replaced with oil.
      A small bottle of mineral oil only runs a couple bucks.
      Mine looked exactly like yours. Now, they are display worthy, as, I suspect, yours will be.
      I forgot to mention, you can run a search on the Net for "oil, bees wax wood treatments" and find formulas that will serve you till you are old and gray.
      mylesie
      1 year ago
      Great idea but just a thought! Would it not be safer to make two finger grips in the handle end of the knife sections for ease of withdrawing?
      cirano
      1 year ago
      Steps were easy to follow, I found the use of animated gifs added clarity to the descriptions. (I didn't even have to read the description to get the core of the idea). Thank you for that.
      Question: what does this do to the weight of the drawer (especially when it is pulled out completely)?
      bravoechonovember1cirano
      Reply 1 year ago
      thanks, I appreciate the compliment!
      It adds a little weight when you open and close the drawer but it doesn't seem to have any other effects.
      Irishintx
      1 year ago
      Nice up cycling idea!
      Nice work
      stevefah
      1 year ago
      An excellent job; took lots of patience. I wonder if this would be doable in styrofoam or the foam they use in cosplay.
      clazman
      1 year ago
      Great project right down to the gnarly piece of wood used!
      You got my vote!
      Stufasa
      1 year ago
      brilliantly simple; simply brilliant. Great idea. My wife wants to put in a new kitchen this year and I'm absolutely making this when the new millwork is installed.
      Thanks!
      If you do make it post a picture! I'd love to see someone else's spin on it.
      deluges
      1 year ago
      Beautiful and great pictures and gifs. Voted!
      Datawolf
      1 year ago
      Great !
      But I would add "easy-grip" holes.
      Yonatan24
      1 year ago
      Looks great!
      M3G
      1 year ago
      Great work!
