Infinity Mirror Table
86,548
838
15
This tutorial will teach you how to make an Infinity Mirror Table. This table will light up objects that are placed on it, giving you a beautiful backdrop for your objects, but also force you to clean everything up before you leave the room, because the light will only goes off ones there is nothing left on the table. A one-way plexiglass mirror reflects LEDs into a two-sided plexiglass mirror, giving off the illusion of an infinite tunnel of lights.
Step 1: Tools Needed
- CNC Router
- Machine
- Miter Saw
- Sandpaper (120 grits)
- Soldering iron & solder
- Helping Hands
- Cordless Power Drill
Step 2: Materials Needed
- One-way plexiglass mirror (diameter: 22”)
- Two-sided plexiglass mirror (diameter: 22”)
- PLY wood & MDF wood (diameter: 22-3/8”)
- Metal Sheet (2 sheets of 24”x36”)
- Screws (#16 x 1-1/4”)
- Wood glue
Step 3: Circuit
- 1 Arduino Uno
- 1 Piezo with wires: http://www.adafruit.com/product/1740
- Adafruit NeoPixel Digital RGB LED Strip - Black 60 LED - BLACK - 2 meters: http://www.adafruit.com/products/1461
- 1 Lithium Ion Polymer Battery - 3.7v 2500mAh: https://www.adafruit.com/products/328
- 1 Adafruit PowerBoost 500 Shield - Rechargeable 5V Power Shield: https://www.adafruit.com/products/2078
Step 4: Wiring the Arduino
The NeoPixel LEDs are composed of 3 different outputs: Ground, 5V and Din. The NeoPixels LEDs need to be connected to Pin 6 on the Arduino board and the Piezo has to be connected to Analog 2. You will need to download files to get your library to work on the following website (this website will also explain you how to change the colors of the LEDs and more): https://learn.adafruit.com/adafruit-neopixel-uber...
The Piezo convert vibration to voltage or voltage to vibration. That means you can use this as a buzzer for making beeps, tones and alerts AND you can use it as a sensor, to detect fast movements like knocks. In simple terms, the vibration of an object being set on the table will trigger the Piezo sensor, a switch capable of detecting fast movements. Once the piezo is set off, the NeoPixel Digital RGB LED strip will turn white lights.
Step 5: Building the Table
This part describes how I built my circular table. However, this technique can work with tables of any dimension and shape. To create the tabletop I created a double-lipped ring. I used the CNC router to cut one 22-3/8” diameter ring, and two 22” diameter rings with 22-3/8” lips. Then I glued them together with wood glue and clamps. The lips are for the plexiglass mirrors to sit apart from each other and to create space in between for the LED strip. The base of the table is made up of two 22-3/8” diameter wood circles and eight 2”x4”x13-3/4” PLY wood slats. The slats are sandwiched between the two wood circles, creating a solid structure to support the tabletop.
Make it Glow!
First Prize in the
Make it Glow!
  • Woodworking Contest
    Woodworking Contest
  • Party Challenge
    Party Challenge
  • Arduino Contest 2019
15 Discussions
bseymour777
2 years ago
Hi! My group actually wanted to make this project in our technology class. We bought all the materials listed, but we cannot find the code for the piezo to be connected to the neopixel LED strip.. Can you help?
Ibrahim Rana
2 years ago
Hi :) I was thinking of making this for product design GCSE and I was just wondering the difference between one way and 2 way plexiglass mirror? This website says they are the same and im just so confused! http://www.cutplasticsheeting.co.uk/mirrored-sheeting/two-way-acrylic-mirror
Jeph Diel
4 years ago
this is awesome I definitely plan on making one. I would like to see a pic of straight down to see how long it makes the illusion tunnel look.
mcorbin
4 years ago on Introduction
love it, even though I'm in competition with you.
Laral
I've never seen a circular infinity mirror. That is cool. I'd like to see a minimalist version of this with just a thin tabletop. That would be really 'trippy'. You'd see an ethereal 'wormhole' floating in space.
SherpaDoug
Why does this make me want to build some infinity mirror covers for headphones?
Raitis
4 years ago
This has been on my to make list ever since I saw first of those mirrors! Nice work!
samalertRaitis
Reply 4 years ago on Introduction
me too ! i have gathered all my materials through the year but still its been pending. Same boat :)
OhYeahThatGuy81
4 years ago
Dude that is so cool! And in the one picture it looked like those books were hovering
AliDC
4 years ago
Nice work Lou!
You are brilliant!
Mielameri
4 years ago
Brilliant! Making it circular really adds to the effect
These things are so cool! I would be afraid to set anything on the table for fear of it falling into nothingness, haha. Amazing job!
