Ink Removal From Soda Cans
183,719
877
131
About: Hello - I am the scientist formerly known as Naegeli and of course I was inspired by the artist formerly known as Prince. But in contrast to his royal badness I do not want be become the king of pop but the ...
Soda cans are involved in all kinds of "reuse" projects. If you have no idea just use the search bar on the instructable homepage desktop and type in "soda cans" and you received various results with projects where soda cans are reused.
However, if you need the can for some more decorative purpose the inprints on the outside wall of the can makes it useless. Therefore, this instructable demonstrates an easy method for ink removal on soda cans. As a result, you will end up with a can having a nice shiny outer surface as given on the picture. In this instructable a vase for flowers was built (see last step).
Step 1: Materials
Only few materials are needed for this project:
  1. Soda cans
  2. Nail polish remover
  3. Cotton pads
  4. Pressure cooker
  5. Hot plate
Please use various types of soda cans for your first project. Even so the procedure worked for almost all cans some did resist to the procedure.
Step 2: Method
Surfing through the internet you will find some procedure using sandpaper to remove the ink. However, with this procedure you will never end up with the polished shiny outer surface that you want for your decorative reuse project.
During the first attempts, various solvents were used e.g. nail polish remover or pure acetone directly. But as you can see in the attached video none of them did work.
Here is the trick: Put the cans in a pressure cooker for around 20 minutes.
Attention: ONLY ADD EMPTY CANS IN THE PRESSURE COOKER
Use the procedure that comes with your pressure cooker for sterilizing liquids. In my case I have to add a little bit of water to cover the bottom of the sterilizer. Then place all soda cans inside and close the lid. On the hot plate, I use maximum power to start (level 6 of 6). As soon as the pressure indicator reaches the second mark (2 of 2) power of the hot plate is reduced immediately to level 2 (level 2 of 6). Sterilize it for around 20 minutes.
After 20 minutes take away the pressure cooker from the hot plate and wait until the pressure is released. Then open the cooker carefully (hot vapor) and take out the cans.
Add some drops of nails polish remover to the cotton pad and start removing the ink.
Step 3: Make Your Reuse Project
As shown in the video the bottom part of the soda can was removed and the lid was opened using a tin-opener. A 300ml PET flask was found that fitted directly into the polished soda can. The PET flask was shortened to the correct length and then fixed into the soda can with hot glue.
I hope you like this creative reuse of a soda can which turned into a vase for flowers.
3 People Made This Project!
  • Tape Contest
    Tape Contest
  • Arduino Contest 2019
  • Trash to Treasure
    Trash to Treasure
131 Discussions
ardu11
Question 3 days ago
How did you convince your wife before using HER loved pressure cooker? Mine did not allow me?
1 answer
... sometimes you just have to start an experiment ... and you don't ask for permission. I guess if you are married for a long time you can anticipate the answer in advance and then act accordingly (smile)..... but you know my wife has a hard time with me anyway. I just recently had to buy my own fridge because she did not want to have the worms I need for fishing in the same fridge anymore ..... so compare this to the pressure cooker problem.....wish you happy family life - I am now married for 22 years!
Miniature_Music
1 year ago
I have done this except I didn't use a pressure cooker but lightly torched it with some flaming methylated spirits then use nail polish remover and it came out shiny as silver
... hey cool - after some many views to this instructable you are the first one presenting a constructive new way - I will definitely test it for shure .. thanks for your feedback
JerryL1206
1 year ago
However, if I remove all the ink, I can't get my deposit back!
AnthonypiquellJerryL1206
Reply 5 months ago
Actually I think you can get more back for them if you strip all the paint, you just have to go to the recycling center to turn them in tho
nancyjaneyoungJerryL1206
Reply 1 year ago
And, at 5 cents a tin, that really is a major consideration :) Your post gave me a good laugh. I was thinking of the price of purchasing the pressure cooker!!
RonGarzanancyjaneyoung
Reply 1 year ago
It's not tin (a cookie), Nancy (Mother), it's aluminum (a Fig Newton).
nancyjaneyoungRonGarza
Reply 1 year ago
Ron, I am a Canadian! I was trying to be funny as well... My thought process was the same as yours, but different!! In Canada the difference between commercials and advertisements is that commercials are watched while advertisements are read. Mostly I call them TIN CANS even though I know that they are made from aluminum . My cheeky reference to Nancy Mother was to point out that, in our convents [I am a Catholic} the leader is called Mother. So I commented the words should be inverted :) And finally, Fig Newtons are sold in Canada; but I do not like them \yuckkkie/ I think that, sometimes, my humour is only funny to me ???? It is better to hear my humour, rather than read it :)
Reply 1 year ago
Hi, Nancy. I understand, texts don't carry the intent like the spoken language does. Emoticons try to help but fall short. I WAS chaffing you on the use of the word "tin". BTW, we don't use the word chaffing (teasing) nor cheeky (brash) here either. I've traveled the world.
I endured 8 years of parochial school, Mother Superior and her gang of physical child abusers, et.al.
Also BTW, I found the Fig Newton TV commercial on Youtube; it's a hoot!
Laters, (I mean, Cheers!)
RonGarzaRonGarza
Reply 1 year ago
Nancy, I was trying to be funny. We (Americans) used to get an advert (we call them TV commercials here) where the child would justify to his mother that it was okay because he was not actually eating a cookie (a biscuit, across the pond). We use the word "can" instead of "tin", hence my It's not a cookie, Mother, its a Fig Newton (It's not a tin, Nancy, it's a luminum).
Reply 1 year ago
Well, am sitting in front of this computer, but I stand corrected....I do not like Fig Newton biscuits, so I would not even try to respond :). By the way, the Mother is written before Nancy in most cloistered convents!! like this: The Reverend Mother Nancy but just call me when the stew is ready to eat....
JerryL1206nancyjaneyoung
Reply 1 year ago
I'm glad I could put a smile on your face. Mission accomplished. ;-)
KISELINJerryL1206
Reply 1 year ago
Buahahhaa.... You gave me a good laugh :)) But couldn't You "reprint" the "bar-code" oooh..my bad.. e.g. my printer want print on round surface neither will it stick on aluminium :)) joke, joke, but true
The method will work for both. It depends how thick the plastic coating over the metal is. The thinner the plastic coating the easier it works regardless if aluminum or tin can. In case you find it hard to remove the ink after the pressure cooker, you can try steel wool additionally. As an examples see the pictures below with black currant tin or chocolate cans. I use this polished cans for arduino projects. Just try it and post your pictures please.
kathug55
2 years ago
Aren't the cans too hot to handle manually, after having been in the pressure cooker? How did you get round this?
I did not make this clear during the Video (sorry). But there is absolutely no need to work while the cans are still hot. Just let them cool down and then start working with the solvent (or nail polish remover)
