Installing Subwoofers in a Car
1,370,454
123
38
About: bmlbytes
In this instructable, I will show you the whole process of installing an amplified subwoofer into a car.
This process will work with most stock stereos, and all aftermarket stereos. It can be modified to work with all stock stereos, but you may need a few more parts. I will show you how to do this with an aftermarket head unit (stereo).
When you look at the pictures, realize that I am using an amplifier that is too small for the subwoofer. It is for demonstration purposes and it does not sound as good as it should.
Supplies:
Step 1: Parts
So what will we need to do this?
-Subwoofer box
-Subwoofer speaker (see next step)
-Amplifier (see next step)
-Wiring kit (or each of the following)
-10 Gauge or thicker, 20 foot insulated wire (for power)
-10 Gauge or thicker, 3 foot insulated wire (for ground)
-18 or 16 Gauge, 15 foot wire
-RCA cables, 15 feet or longer (you need 2 or one with both red and white)
-In-line fuse, 50 amps or higher
-Some speaker wire
-4 small wood screws
-Basic tools
For the power and ground wires, you will need thicker wires depending on how powerful the amplifier is. REALLY powerful amps could need as much as a 0 gauge wire.
Walmart sells amplifier kits (as do some other stores). The kits tell you how many watts they can handle.
Step 2: Choosing an Amp and Speaker
This can be a tricky step. You want to choose a speaker and amp that put out the most power, without blowing each other.
What you want is the RMS of both the subwoofer speaker and the amplifier to be as close as possible. The RMS is the amount of power a speaker can continuously have sent to it without going bad. The RMS is also the amount of power the amplifier can continuously put out without over heating.
When looking at speakers and amplifiers, do not look at the peak power. A speaker or amp can only be run on the peak power for about a minute before it goes bad or overheats. You want to be running your subwoofers on its RMS rating rather than the peak rating.
For best sound, keep the impedance (Ohms) the same too.
Lets take the Kenwood KFC-W3011 for example. Its ratings are:
-400w RMS
-1200w Peak
-4 Ohm Impedance
A good amp for this speaker (assuming this is the only speaker attached to the amp) might be the Rockford P400-2. This amp has the following ratings when it is in "bridged mode".
-400w RMS
-4 Ohm Impedance
Choosing a size for a speaker is also important. Smaller speakers like the 8 and 10 inch ones, are very quick to respond and punch better than bigger ones, but are not very loud. Bigger ones like 15+ inch ones, are very loud compared to smaller ones at the same wattage, but have slow response, and make the sound more mushy. The bigger ones also handle lower frequencies better too. 12 inch speakers are a good compromise for a basic system.
Make sure you buy a subwoofer box that has a hole the same size as your speaker.
Step 3: Run Wires
We will start with wiring the power from the battery. It is important to get the power from the battery and not the fuse box. Power from the fuse box often is "unclean" and you may hear your engine noise amplified through your speakers. You could also easily blow a fuse by using the little ones the fuse box has.
Start by finding an opening in the car's firewall. This is the metal wall under the hood of the car, closest to the windshield. The other side of the firewall should be the inside of the car. I chose a hole that was behind my glove box and was fairly easy to get to from the engine compartment.
Run the majority of the power cable through the hole in the firewall, making sure to leave enough wire to get to the battery.
Strip the insulation off of the wire at the end where the battery is. Wire the in-line fuse to this end (if it is not part of the wire already). You want the fuse as close to the battery as possible. Do not connect the wire to the battery yet. Make sure you tape the place where you wired the fuse to the wire, so you don't get a short.
Run the remaining wire under the cars carpeting or through a wire channel, if there is one. You want to get this wire to the trunk of the car.
While you have the carpeting loose, run the 16 - 18 gauge wire and the RCA cables from the trunk to as close to the back of the stereo head unit as possible, leave a little slack at both ends.
Step 4: Wiring the Audio
You now need to take the stereo head unit out. It usually requires you either take off the front of the center console, or you use a tool to slide the stereo out of special clips.
After you have the stereo out, look at the back of it. There should be 2 RCA connections. Run the RCA cables through the back of the center console and plug them into the 2 connections on the back of the stereo.
If your stereo does not have these connections, you will have to splice the wires into the rear speaker wires. Better yet, go out and by a new stereo that has RCA. They aren't very expensive any more.
Leave the stereo out for the next step.
Step 5: Wiring the Remote
You will need to run the 16 - 18 gauge wire through the back of the center console too. This wire tells the amp that the stereo has turned on, and that the amp should too.
If you look at all the wires coming out of the back of the head unit, there should be 1 or 2 blue ones. These are called the remote wires. If your wires are labeled they may be labeled as:
-Remote
-Rem
-Amp
-Amplifier
-Power Antenna
-Pwr. Ant.
-Antenna
or something similar to one of those.
If there are 2 wires, there should be one labeled Amp. If there is just one blue wire, you can use that. If you have a power antenna, you will have to splice into the blue wire for use with the amp too. What you need to do is connect the 16 - 18 gauge wire to the correct blue wire. When the stereo comes on, so will the amp.
If it is a stock stereo on a car without a power antenna and no blue wire, then run the 16 - 18 gauge wire to the fuse box, and connect it to a fuse that turns on when the accessories are on. Your amp will always be on when your car is on, but it shouldn't make noise, so its OK. If it does make noise (like from the engine), add a switch so you can turn it on or off.
Step 6: Put the Speaker in the Box
This is pretty self explanatory, but for those who don't know:
Put the speaker in the box, making sure the flimsy thin gasket thing is on it.
If the box has its own connectors on the outside, make sure they are wired to the speaker inside.
Screw the speaker into the box, using the holes on the outside rim of the speaker.
Set the subwoofer in the trunk of the car.
Step 7: Wiring Up the Amp
OK now we have most of the wires in place, we can wire up the amp.
Connect the power cable from the battery into the spot on the amp that has one of the following markings (do not connect it to the speaker positive):
B+
Batt.
Pos.
+12v
12v
Pwr
Power
Connect the 16 to 18 gauge wire into the spot that says:
Rem.
Remote
Ant.
Connect the 3 foot, 10 gauge wire to the one marked (do not connect it to the speaker negative):
B-
Neg
-12v
Gnd
Ground
Connect the other end of the ground wire to a nearby bolt that connects to the body of the car.
Connect the speaker wire to the + and - marked for speakers on the amp. There may be 2 channels. If there are 2 channels and you can bridge your amp, do it. I won't explain bridging but its easy and you can Google it.
Connect the other end of the speaker wire to the + and - on the speaker box. Try to make sure that the + from the amp is connected to the + on the speaker, and the same with the -.
Step 8: Adding Power
The final step is to go and connect the power cable to the battery. I just shove my wire between the battery clip and the post on the battery.
Make sure a large fuse is in the fuse holder.
2 People Made This Project!
  • Party Challenge
    Party Challenge
  • Arduino Contest 2019
  • Woodworking Contest
    Woodworking Contest
38 Discussions
KevRocker900
2 months ago
Thank you for the instructions and detailed post. Just a few things I'd like to add with respect to the original author: bmlbytes
A high amperage fuse between the battery and amplifier is absolutely necessary. I have seen those high amperage (+12) low gauge (a lower gauge number and very thick) wires come loose from amplifiers/powered subs and then make contact with either the adjacent ground wire/connection or the vehicle body and cause fires if not properly fused. Well, for that matter, if the amps ground wire came loose and/or anything else connected to the grounded vehicle body touched that un-fused +12 line connected directly to the battery, it would create a direct short. I think most of us have experienced the awful electrical smell and the after effect of that condition..
Some decks(stereos) also offer dedicated sub-woofer outputs. The benefits of using those outputs is the ability to adjust the output that is sent to amplifier and then to the sub. I prefer that method (if applicable) than adjusting the knobs (potentiometers) on either the amp or powered sub to match the desired speaker volume. I understand the need for the initial calibration settings on the amp, however it is convenient to have control over the sub-woofer independently, especially if you find yourself next to a member of the older population (we all get there eventually) who tend to not enjoy the wonderful sensation of properly tuned bass.
I also find, with years of experience, that using crimped and soldered (and heat-shrinked) round connectors on every screwed connection to be the safest and most secure way to go. I know it involves removing/installing the screw and getting out the soldering iron and heat shrink. If you don't want to use connectors, at least solder the ends of the wires for a solid connection that also prevents fraying. If you don't plan on removing the sub or amp often, why not take the few extra minutes?
This might not be too relevant, however I have also seen every single clear plastic amplifier cover melt if mounted in a spot that receives direct sunlight in hot cars.
I really appreciated the original post, I hope this helps anyone else thinking of installing an amp and/or sub-woofer.
vaja007
Question 1 year ago on Step 2
first time I am installing a subwoofer in my car and I need to connect outline converter in my car radio. I bought 2 channel outline converter from e bay and I need to tap into factory cable speakers but not sure with speakers I should tap. front or back? My front speakers have no Bass at all and rare speakers are batter and with some Bass. can someone please give me advice about which speaker cable I should tap to connect lineout converter please?
haydendicker
1 year ago
Hi Guys,
Can any of you help me. I have had my sub for a few years and recently I had a few things in my boot, as i went round a corner something fell and it pulled (ripped) one of my cables off my speaker (picture below). Is this something i can easily fix? and if so how?
Thanks
MykolasShaydendicker
Reply 1 year ago
i think soldering it back and wrapping a ton of electrical tape should do it
PhilR2
4 years ago on Introduction
After installing my amp and subwoofer into my 2000 jeep wrangler, my rear speakers (on the sound bar) are no longer working. Any ideas/sugestions?
115307adamk48
Reply 2 years ago
Passionfruit
3 years ago
Hooking up cadillac sts 05 amp and 10" sub would love some info on what wires to buy and where, thanks
obaker15Passionfruit
Reply 2 years ago
Check this out - it's a bundle, has everything you should need to do the job. https://www.amazon.com/gp/product/B01HUBLZA0/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
Bheki DuxF
3 years ago
hi guys
i have 2dvc comp 4d sub targa
i need to build a box for it pls help wat is the right size of the box
and im using star sound class x amp
Dmunegr
3 years ago
selecting speakers for amplifier. This article has a huge mistake. One should never match amplifier power with speaker power. Here is why. Amplifier power measuremnt is watt rms. Rms stands for square root of the average of square. The important thing here is AVERAGE. The speaker power is expressed as the maximum input. In electronic we call this the crete to crete value.
If you pick a speaker with maximum rated input of 100 Watt to connect it to an amplifier with average output of 100 Watt, then never crank the amplifier to max or you'll end up damaging the speakers. The good pratice is to pick a speaker rated for 170% of the amplifier power. A 100 watt rms output should never be inputed in a speaker with less thant 170 watt mximum input.
If you follow this guideline, you won't blow up you speakers and improve sound output quality !
DavidJ42
3 years ago on Step 2
Great guide! Makes it really easy to understand the basic concept. If you want to learn more about subwoofers and amplifiers head to http://inovah.net/under-seat-subwoofer/
ravranu
4 years ago
i got MTX THUNDER 4122 AMP nd subwoofer. anyone tell me how to install in car CHEVY impala.nd which gauge wires i need.???????
Phil Dodd
6 years ago on Introduction
Congratulations on the enthusiastic hard work of both the author and the many contributors to this instructable.
I have to make one comment, though, which anyone installing powerful subwoofers into an automobile needs to be aware of.
Around the year 2000, the UK national Fire and Rescue service issued a nationwide advisory about people who have done just this. It is a fact of life that under the carpets of most motor cars is moisture, brought in from the outside atmosphere and trapped by the carpet. This moisture causes the metalwork of the car to rust. As the car gets older, the rusting becomes worse. Installing powerful subwoofers into an older vehicle puts a big strain upon the metal panels of the car, and the welds holding the panels together. The welds in some such vehicles involved in crashes were found to have spilt along hairline cracks, introduced by the use of subwoofers, or by panels splitting at rust points.
I'm not claiming that this will happen to your vehicle if it is old and you install subwoofers; I'm simply saying that it has been observed to happen by the UK authorities. Be careful. Regards Phil
snakedz
7 years ago on Introduction
My 06 sentra came with a rockford fosgate surround sound system. My subwoofer has stopped working. I have checked all my fuses and have even opened up the amp case to see if i can figure out whats wrong but nothing looks ab normal. All my other speakers work fine. So if someone had a solution please help. Another question, I have a 15' rockford sub and an amp to go with it, i want to install it into my sentra, but i have found out the stock stereo doesnt come with RCA jacks so whats is the best way to go about this? PLEASE HELP!
The nerdling
what's with your profile pic?
are you and all rounder?(means you don't care which os you use)
darnilius
8 years ago on Introduction
hey so ihave the whole subwoofer package and amps and wiring, but idont even want to try to install it myself, ijust think imight mess up, so how much would a person who knows how to install them charge me, and i know it depends but ikinda need a price range??, and btw ihave a 99 malibu if that helps..?
vnguyen5darnilius
For the need to replace a stock radio, you do not have to do it all the time. What I have done is wired the speaker output, into the rear speakers. By doing this, you do not have to tie into the front radio, but there is also the being that all you are doing is "Upping the sound of your rear speakers and not really adding the subs to the music. From what I have seen happen is that the subs work in 2 main ways that I know of. Because some songs for example have 2 different base line so that when one you have tied in the speaker wires to the radio, you will hear something different from when you tie it into the rear speakers. Mostly I did my sound system into the rear speakers not only because I did not want to spend more time in wiring it to the radio, I was unsure on the connection to do it on, because I have an older model aftermarket radio that is already tied into a CD changer. There are other ways on doing this but from what I read from your posting, this would be the cheaper way on doing it.
bakermonitordarnilius
I you have a stock radio you will probly need to replace it. If you have a aftermarket already installed or to be installed look at the instructions that came with it if you can put in a sub it will show you how to wire it, plus the ones with the amp you will be fine the hardest part is runing the wires, and the second hardest part is making sure the posative and negative on the amp are right other than that it should just be plug and play as it says above. (you may need to turn on the sub from within the radio but thats the only odd part on some)
