Interfacing LCD With Arduino Using Only 3 Pins
11,615
78
13
About: iam a B.E Electronics and Communication Engineer. I have great interest on electronics.I love my college life.Even though there are many sadness in my life.I find joy in making instructables.
To interface LCD we need six digital pins from Arduino. To save your Arduino pins and easy interfacing
IC 74HC595N Shift Register is used.Using this shift register we can interface LCD using 3 pins.
Step 1: Components Required
  • LCD 16x2
  • Arduino Uno
  • IC 74HC595N
  • 1K Potentiometer
Step 2: Operation of IC74HC595N
IC 74HC595N shift Register accepts serial input data and converts into parallel output.This shift Register contains 3 input pins and 8 output pins.By updating LiquidCrystal libraries the arduino generates serial data in single pin and give it to input data pin of IC74HC595N and the shift Register converts these serial data into parallel output and these parallel data is given to LCD.
IC 74HC595N contains 3 input pins
  • Data pin: Data is sent in serial mode.
  • Clock Pin: A clock runs on this pin
  • Latch Pin: This pin is used to toggle so that shift register shows 8 bit data on output.
Step 3: Updating Libraries
To interface LCD using 3 pins you need to Update the ARDUINOLiquidCrystal libraries.Which is located at the following location
Local Disk(C)-->Program Files-->Arduino-->libraries-->LiquidCrystal.
Open the LiquidCrystal folder and there are some files inside that folder.Cut and paste these files Some where on your pc. Because you need to use these files when you interface LCD using 6 pins.
Now Download and Extract the following libraries.Which is an updated Liquid Crystal libraries to use LCD with 3 pins.Copy the extracted files and paste it in the following Location
Note: open the folder of Liquid Crystal and paste it.
Now you have updated your Arduino Liquid Crystal libraries
Step 4: Schematic Diagram
I have also attached Schematic in RaR format.
Step 5: Program Code
#include <Wire.h>
#include <LiquidCrystal_SR.h>
// Defining LCD and Pins for interfacing.
LiquidCrystal_SR lcd(6, 5, 9); // Pin 6 - Data Enable/ SER, Pin 5 - Clock/SCL, Pin 9 -SCK
void setup()
lcd.begin(16,2); // Initializing LCD
lcd.home (); // Setting Cursor at Home i.e. 0,0
void loop()
lcd.print("3 Pin LCD"); // Print Something on LCD
delay(2000); // Waiting for a while
lcd.clear(); // Clearing LCD
lcd.print("INSTRUCTABLES");
delay(2000);
lcd.clear();
Note
I have attached the Wire library.Add the library before compilation of the code otherwise you will get error.
Step 6: Download Program Code
I have attached program in RaR format
Download and extract it and open it in Arduino IDE
Step 7: Video
    • Classroom Science Contest
    • IoT Challenge
      IoT Challenge
    • Party Challenge
      Party Challenge
    13 Discussions
    Spencer4
    11 months ago
    Flawless, but I personally couldn't see the display without the backlight: so I grounded the last pin on the LCD and put 5V through a 220 ohm resistor to the second to last pin on the LCD. The video does show the light being on, but I definitely didn't see it in the schematic. No biggy though.
    ChanaS1
    1 year ago
    Thank good job
    Mohamed SamyH
    2 years ago
    please help me for god sake with this error occured during verifiying:
    Arduino: 1.6.9 (Windows 10), Board: "Arduino/Genuino Uno"
    E:\Arduino\arduino sa3d we 3abd el ra7man\arduino-1.6.9\libraries\LiquidCrystal\I2CIO.cpp:35:26: fatal error: ../Wire/Wire.h: No such file or directory
    #include <../Wire/Wire.h>
    compilation terminated.
    exit status 1
    Error compiling for board Arduino/Genuino Uno.
    This report would have more information with
    "Show verbose output during compilation"
    option enabled in File -> Preferences.
    Rajkumar2506Mohamed SamyH
    Reply 1 year ago
    You need to install old IDE version of arduino software.That is
    1.0.6.Don't go to latest version of IDE.The wire.h command is available
    only in older versions like 1.0.6.Install the older version and try
    uploading the code.You will get that right.
    JarlGMohamed SamyH
    Reply 1 year ago
    Maybe not a solution, I just updated the I2CIO file and removed "../Wire/" and voila!
    Kunal Gehlot
    1 year ago
    I made it!, thanks for your support.
    ArifSae
    2 years ago
    I have tried it in past project, it works great, Latest development is you can get I2C board cheaply with LCD that takes care of hassle (just sharing info)
    Rajkumar2506ArifSae
    Reply 2 years ago
    I2C is costly when compare to 74HC595N.You can get the IC 74HC595N cheaper in cost
    ArifSaeRajkumar2506
    Reply 2 years ago
    no doubt about that, 595 costs around 8/Pkr while I2C 64/Pkr.
    prabakaranp
    2 years ago
    Very helpful to me
